517 -
Days Won
8
Posts posted by Antonio Argudo
yes, many drawings and kits represent this wrongly, this happens when copying from wrong reference, 1/48 accurate miniatures P51 kits represent correctly the size of the ammo panel, as you can see the length of the ammo panel allines with the panel of the wing light as reference point, cheers
Hi mate, I can guarantee you Tamiya's model is wrong, and also those drawings... I have the NAA blueprints for the "B" model, plus it is quite obvious in ww2 pictures that indeed the ammo panel is smaller, also this relic from a B model, here is the reference material, also keep in mind B/C models had only 2 machine guns on each wing that's why the ammo panel were smaller and increased in the D model to provide more rounds to 3 machine guns, cheers
- R Palimaka, D.B. Andrus, dodgem37 and 6 others
- 7
- 2
nice job so far, watching closely, cheers!
amazing work on those wing rivets John , something about that rectangle panel, not sure if it was a repair made in the restoration and hasegawa copied but have not seen it on ww2 Dora's pictures, if someone can confirm this? cheers
absolutely brilliant, off to a masterpiece mate, cheers
wow, looking awesome Fabio, I like your approach on the hump!! what will be you using for the transparent parts?
makes me come back to my p51B conversion also lol
cheers
- adameliclem and levier
- 2
13 hours ago, James Rademaker said:
Really great craftsmanship on the cockpit. Did you fabricate the seat cushion? It looks very realistic.
Jim
thanks Jim, yes I used magic sculpt resin, my fav material for this , cheers
11 hours ago, Brett M said:Very nice scratch, love the cushion too.
thanks Brett, I sculpt the early style which is more interesting than the later one
10 hours ago, Jack said:Yep, for sure this will turn into a splendid looking B model, nice approach you did to get this far.
I've tried this "conversion" with an old Revell B fuselage untill the firewall, and pasting a Hasegawa D nose onto it, but stalled it a while ago.
Will follow this very closely, great job.
Jack.
thanks Jack, there is always a risk on these projects, I resuscitated this one after a few years, hope you get back too yours, cheers
some more work on the seat cheers
On 9/10/2020 at 1:16 AM, James Rademaker said:
I’m really liking this build, can’t wait to see more updates. Great work!!
Jim
thank you James, I'm very glad you are following this build with interest cheers
lots of dry fit and trim for fitting the cockpit is what been happening lately, done sculpting on the cushion.
cheers
51 minutes ago, James Rademaker said:
Very nice conversion. I applaud your fearless kit bashing of several good kits to make a good B Mustang. I am assuming you are using the Hobbycraft windscreen and other “clear glass” for the cockpit.
Jim
thanks Jim, well, originally I was not going to use the hobbycraft parts and save the kit, was going to scratch all the canopy parts making a mold and vacuformed transparents however as I have no experience on that took the decision to use the donor kit and build this one quicker, the rear canopy windows also need to be lifted slightly in position, that's what I did today, now filled with black ciano and sanding and polishing ahead, cheers
On 9/4/2020 at 3:19 AM, LSP_Kevin said:
Fascinating approach, Antonio! I'll be following along for sure.
Kev
thanks Kevin. hoping the effort will be worth it to make a "B" eventually, cheers
18 hours ago, MikeMaben said:thank for following Mike, cheers
11 minutes ago, Troy Molitor said:Looking good Antonio. I donated a Hobbycraft kit for this exact purpose to a fellow LSP'er. The lines on a P-51B are just the Bee's knees. Following with interest. Once your -51B is completed Maybe just maybe, we'll see this one come to life!
thanks Troy, I was hoping not to chop the Hobbycraft kit but was the best option if I want to finish this project, I had to lol, I agree with you about the "B" lines and curves
cheers
canopy sacrifice surgery Hobbycraft P51 A as donor, it was quick she didn't suffer
cheers
- Troy Molitor, Alex, Starfighter and 17 others
- 20
I'm resurrecting this project I started a couple of years ago, using the Revell "D" downgrading into a "B" model.
some 1/32 Mustang kits on the bench for comparison measures
the revell kit is the best option as a base for this operation, here without the main D features
the leading wing was transformed using milliput
some magic sculpt on top of that hump, tomorrow more sanding....
so this is it so far, many uncertainties yet on the way to come...
cheers
On 8/31/2020 at 5:02 AM, Basta said:
You get as much credit for taking this particular plane on as a WIP here as you do for the execution. You parried all the experts' thrusts with aplomb while building an impressive replica. Bravo.
Thanks for your kind words Basta, glad you are liking it, cheers
On 8/31/2020 at 5:58 AM, fastterry said:Really nice job. Interesting to see how the oil streaks are biased towards the starboard side, must have to do with prop wash.
TRF
thanks mate, yes that can be the reason, also the left strut was over pressured because the torque of the prop made it to suffer more at take off and landing , so it is slightly taller on the left side!
Drop tank has been glued down, early type with metal protector end, which I should touch up that pointy tip end, and no monster red stencils, cheers
On 8/29/2020 at 3:18 PM, dodgem37 said:
I like that.
Sincerely,
Mark
thanks Mark, yes these birds could get quite dirty if not cleaned between missions
cheers
On 8/29/2020 at 4:00 PM, chuck540z3 said:You are doing a terrific job Antonio. Bravo!
I miss your Mustang though. Shelf of Doom, or just a time out?
Cheers,
Chuck
Thanks Chuck , hopefully will come back to the Mustang after this one
cheers
gear doors added and wing radiators, made them in dropped position, cheers
before weathering... need to add that separation part between them still
thanks for following, cheers
- chuck540z3, turbo, chrish and 3 others
- 6
started with the under surfaces weathering , some inspiration references
cheers
18 hours ago, chrish said:
Beautiful work! And also very exacting.
well done
thanks Chrish, I'm very glad you are enjoying this build, cheers!
17 hours ago, dodgem37 said:I like that color contrast. I haven't noticed it before. Nice eye.
Sincerely,
Mark
thanks mark, seems like you can find 76 or 02 landing struts on the 109's , cheers
porps painted, picture don't show the green quality of the 70 but it's there, I promise cheers
1/32 P-51B conversion from Revell 1/32 P-51D early
in Works in Progress
Posted · Edited by Antonio Argudo
no problem mate it's going to be a beauty Mustang, keep the good, cheers
Also found this diagram comparison from the NAA manuals
