JayW Posted September 10, 2018 Posted September 10, 2018 Yeah - kind of glad to see this excellent work. I am in the middle of a really tough build myself in 1/18. And sometimes I get a little sloppy and accept less than the best - mostly because I know that we (we meaning serious modelers) can on our worst days far outperform most model manufacturers when it comes to accuracy and detail. But for me, my best effort is so much better than my sub-par efforts. So you help me be more patient and more meticulous. Keep up the good work. airscale and daHeld 2
ungoliat Posted September 11, 2018 Posted September 11, 2018 HI At the end would you fly this thing?... Sure it can fly... airscale 1
Hacker Posted September 11, 2018 Posted September 11, 2018 A wealth of information here. I am keen on seeing how this cockpit is coming together and how it is suppose to look vs what you are given in kits Hacker.....after seeing this should l hang up my airbrush? airscale 1
Out2gtcha Posted September 11, 2018 Posted September 11, 2018 This is certainly another best of show/Telford winner right here. Im not sure there is a modeler on the planet that wouldnt be impressed by some aspect of this build. daHeld and airscale 2
brahman104 Posted September 11, 2018 Posted September 11, 2018 Wow Peter! You've certainly been making some solid progress on this! I can totally appreciate how much of a PITA getting that rear bulkhead in position must've been! Your etching work is absolutely incredible, and to see it for the most part all line up is a testament to your skills! Stunning as always Craig airscale and daHeld 2
Starfighter Posted September 14, 2018 Posted September 14, 2018 So good it almost hurts... absolutely stunning, Peter! KUROK and airscale 2
airscale Posted September 15, 2018 Author Posted September 15, 2018 thanks chaps - very kind :) so next in the God knows how many parts I have to make is the fuselage fuel tank - for this I have a few pictures of the actual tank fitted in Lopes Hope and made a few mental notes about what needs to be done in terms off construction. First thing is clear, it is quite an organic shape, being made to sit tightly in among all the formers in the fuselage behind the pilot (more of which later..), second, it has a quite uneven surface where various fittings are added, and lastly it looks like a round pole framework at the top over which the bladder sits.. ..having trouble with photobucket so will add that pic in later.. the first step was to make a balsa blank and add the profiles scaled from the factory drawings - here is the bottom plan.. ..then the top profile with all the fittings added and starting to shape it.. ..then the top was recessed and the tubular frame added.. ..to get the finish I wanted I decided to try tissue - this is at least 30 years old from a Guillows kit.. several layers were applied and washed in with diluted PVA.. ..the fittings had strengthening doublers so these were added from bare metal foil.. ..something I had already worked out was that the complete tank would not fit in the assembled fuselage structure as it has to thread through the fuselage formers, so I cut it in half and then painted it black.. (Tamiya semi-gloss with a drop or two of future..) ...I am quite pleased with the results and I can.now start to add the detailed parts safe in the knowledge it just about squeezes through.. ..and slotted into place .. ..and with the seat mocked up in position.. ..that's it for now - having fun with this one :) TTFN Peter Fooesboy, TaffyMan, KiwiZac and 13 others 16
TorbenD Posted September 15, 2018 Posted September 15, 2018 Toptastic stuff! As ever, really enjoying the following along as you’re having your fun Peter :-) Torben Out2gtcha and airscale 2
LSP_Kevin Posted September 15, 2018 Posted September 15, 2018 I'm already out of words! Kev daHeld and airscale 2
Barry Posted September 15, 2018 Posted September 15, 2018 Awesome stuff here Paul! Your build/approach reminds me of years of actual aircraft production. As I've migrated more of my builds especially details to scratch building I've discovered that my brain is the key to my modeling. Finding the right medium, material or tool to solve a building need brings light to more and more possibilities. Quite often I find that I have to make the tool or fixture before I can determine what will be used. Keep up the spectacular work. Barry daHeld and airscale 2
LSP_Ray Posted September 16, 2018 Posted September 16, 2018 Oh, that is sweet, Peter! Great simulation of the tank! One would have thought you put 30 parts into that thing. airscale and daHeld 2
dodgem37 Posted September 16, 2018 Posted September 16, 2018 DUDE! That is BOSS! Sincerely, Mark airscale 1
