rtwpsom2 Posted September 2, 2018 Share Posted September 2, 2018 (edited) 18 hours ago, airscale said: ..to me it looks undersized so am just trying to check if there were two versions or if it is just a trick of perspective in the photo of the real cockpit.. back soon TTFN Peter If you look at assembly 102-53028, you'll see why it looks short to you. The first thing to note is the map case is flush with the inside flat part of the longeron and the inside flange of sta 131.5, it is not mounted to the fuselage skin. Secondly 102-53028-2 is an L shaped sheet that goes behind the map case but is also flush with the inside face, it takes up the space below and behind the map case. The map case itself is in a pair of channels mounted to the front of that sheet and can actually be lowered about 4-5 inches for some extra storage space behind. Edited September 2, 2018 by rtwpsom2 airscale 1 Link to comment Share on other sites More sharing options...
Kais Posted September 2, 2018 Share Posted September 2, 2018 Peter, Speaking of tricks of perspective; the roll over bar seems to be leaning towards the nose. Is that throwing your dimensions? airscale 1 Link to comment Share on other sites More sharing options...
TaffyMan Posted September 2, 2018 Share Posted September 2, 2018 Wow Peter - taking this one to the next level - If that is even possible!!!!! Even the Jig looks amazing Keep at it - Taff airscale 1 Link to comment Share on other sites More sharing options...
JayW Posted September 3, 2018 Share Posted September 3, 2018 Looks like a full size build! airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted September 7, 2018 Author Share Posted September 7, 2018 On 9/2/2018 at 6:18 AM, rtwpsom2 said: If you look at assembly 102-53028, you'll see why it looks short to you. The first thing to note is the map case is flush with the inside flat part of the longeron and the inside flange of sta 131.5, it is not mounted to the fuselage skin. Secondly 102-53028-2 is an L shaped sheet that goes behind the map case but is also flush with the inside face, it takes up the space below and behind the map case. The map case itself is in a pair of channels mounted to the front of that sheet and can actually be lowered about 4-5 inches for some extra storage space behind. well thanks again rtwpsom2 - very useful guidance :) I have tried to interpret what I see in photo's and the drawings and have now mounted it - hopefully this is near the mark? got a main switchpanel up near the IP to start on next... TTFN Peter Uilleann, LSP_Kevin, MikeMaben and 12 others 13 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 7, 2018 Share Posted September 7, 2018 Holy cow man.............nuthin left to say but model on! airscale 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted September 8, 2018 Share Posted September 8, 2018 So awesome seeing this unfold before our own eyes. One of my favorite aircraft coming together one bolt at a time. Thanks for sharing your talents with us Peter. Troy airscale 1 Link to comment Share on other sites More sharing options...
DonH Posted September 8, 2018 Share Posted September 8, 2018 2 hours ago, Troy Molitor said: So awesome seeing this unfold before our own eyes. One of my favorite aircraft coming together one bolt at a time. Thanks for sharing your talents with us Peter. Troy Yep, I agree. And he even makes the bolts!! airscale 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted September 8, 2018 Share Posted September 8, 2018 Nice stuff, Peter. Love the edges. Sincerely, Mark airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted September 8, 2018 Author Share Posted September 8, 2018 11 hours ago, Troy Molitor said: So awesome seeing this unfold before our own eyes. One of my favorite aircraft coming together one bolt at a time. Thanks for sharing your talents with us Peter. Troy Thanks folks & thanks Troy - that is exactly how I like to see it - one bolt at a time I have made what is listed as the 'Right Switch Box' - it's this bit here.. ..one of the advantages of making your own PE is that you can pre-think how to render shapes. In this case, the actual switch box is a simple rectangle with holes & details, but the circuit breaker cover plate is a structure i decomposed and 'folded flat' so I could try and fold it up in PE.. ..with some folds & bends, I have a scale reproduction with all the angles juts right as they are from the drawing of just this part... ..made a base shape from thick card and assembled the laminate of the switch panel itself. It has a small dial so I added the decal and a sheet of glass to the back structure.. ..then other components were folded or added and the switch handle made from bits.. ..all sprayed with semi gloss black.. ..and with the addition of the custom decals the component is complete.. ..and this is where it will sit.. ..more boxes & bobbins to come to carry on with the sidewall.. TTFN Peter TaffyMan, patricksparks, D.B. Andrus and 14 others 16 1 Link to comment Share on other sites More sharing options...
DonH Posted September 8, 2018 Share Posted September 8, 2018 That is beautiful. Great job and it is fantastic to see each box, plate and dial grow from scratch. airscale 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted September 8, 2018 Share Posted September 8, 2018 Dude! That is downright killer! Sincerely, Mark airscale 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 8, 2018 Share Posted September 8, 2018 Thanks is for taking the time to document all this Peter......its modeling at it's very best. OUTSTANDING stuff man. airscale 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted September 9, 2018 Share Posted September 9, 2018 Are looking at pics of the full size restoration again??? Amazing, Peter! Damn, I just realized I typed that on the Spit build, too! I should just cut and paste from now on... Out2gtcha and airscale 1 1 Link to comment Share on other sites More sharing options...
JayW Posted September 9, 2018 Share Posted September 9, 2018 My gosh - what a wonderful build! airscale 1 Link to comment Share on other sites More sharing options...
