LSP_Ray Posted November 18, 2018 Posted November 18, 2018 And the magic continues! JayW and airscale 2
TorbenD Posted November 18, 2018 Posted November 18, 2018 Great to catch with you at Telford Peter, and, as ever, see this beauty coming together one miniature marvel after another. Superb work! Torben airscale, JayW and daHeld 3
jenshb Posted November 18, 2018 Posted November 18, 2018 No detail seems to be too small to be a model in it's own right... Jens airscale 1
dodgem37 Posted November 18, 2018 Posted November 18, 2018 Sure puts a smile on my face. Welcome back. Good show. Sincerely, Mark airscale 1
scvrobeson Posted November 18, 2018 Posted November 18, 2018 Too cool Peter! The work is just at an incredible level of precision. Matt airscale 1
airscale Posted November 25, 2018 Author Posted November 25, 2018 thanks folks & good evening ,,a bit more done over the weekend.. ..this is the sidewall of lopes Hope - as you can see there is lots going on, so pert of the process is deconstructing what you see into small assemblies.. I had most of the structural work done, so time to prime with etch primer.. ..one side.. ..and the other - this is the side you see above in the real one.. ..after painting green, I started to add some of the fittings and decals including the pedestal... ..and on the other side, some of the switchgear.. ..a couple of small control units were needed so I made these and prepared a number of watch parts for the fittings... ..making these convinced me I needed a 3D printer from santa this year as I could have just knocked them up... ..I also made and added these inner parts to the main longeron at the cockpit sill - the brass 'H' section I used was 0.5mm too small and that was enough to mean all the decals along the side didn't fit - so I took the drawings and scaled these I could just laminate to them.. ..that meant I could really start to add in all the decals and placards... ..and a check to make sure all the subassemblies go together to make the cockpit pod.. ..should be moving onto the floor, rudder pedals and control stick next... TTFN Peter LSP_Kevin, KiwiZac, patricksparks and 21 others 24
tomprobert Posted November 25, 2018 Posted November 25, 2018 That's it. I give up Insanely good - it looks as if you could climb in and power her up - superb! Tom daHeld and airscale 2
Troy Molitor Posted November 25, 2018 Posted November 25, 2018 Well done Peter. Just terrific work and attention to small details going on here. I hope the ZM folks call upon you when they start their 1:32 scale efforts. Love all the updates. Troy airscale and daHeld 2
R Palimaka Posted November 26, 2018 Posted November 26, 2018 (edited) This made me smile. I was looking at the cockpit photos of the real Lope's Hope you posted above and I wasn't sure if it was the real thing or your model. Had to check the captions. Absolutely astonishing work. And as others have said, a valuable reference for anyone building or researching the P-51B/C. Edited November 26, 2018 by R Palimaka daHeld and airscale 2
LSP_Kevin Posted November 26, 2018 Posted November 26, 2018 That is ridiculously good! Kev daHeld and airscale 2
Marcin_Matejko Posted November 26, 2018 Posted November 26, 2018 Perfect, almost like the real 1/1 daHeld and airscale 2
dodgem37 Posted November 26, 2018 Posted November 26, 2018 GREAT! show, Peter. What did you use as a cable tie? Thank you. Sincerely, Mark daHeld, airscale, chukw and 2 others 5
Padraic Conway Posted November 26, 2018 Posted November 26, 2018 Utterly spellbinding! I've just found this thread and spent the last 30 minutes completely speechless! Truly inspirational work Peter airscale and Out2gtcha 2
Out2gtcha Posted November 26, 2018 Posted November 26, 2018 Wow Peter. Your ability to amaze should not amaze me anymore but it does at every turn. airscale and daHeld 2
