JayW Posted January 10, 2019 Share Posted January 10, 2019 One more thing Peter - there is a vertically oriented blade of sorts that is situated right on the centerline of the scoop, and right on the nose of the transition fairing you have so skillfully created. Most know of this feature, but most do not know that it pierces upper skin of the scoop and continues right up into the fuselage. Provide for it on your scoop. Drawing number for the blade is 102-31080, and its installation shows up on wing install drawing 102-10001 (see zone A8). Out2gtcha, airscale and daHeld 2 1 Link to comment Share on other sites More sharing options...
Marcin_Matejko Posted January 10, 2019 Share Posted January 10, 2019 Master airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted January 10, 2019 Author Share Posted January 10, 2019 evening ladies 5 hours ago, JayW said: One more thing Peter - there is a vertically oriented blade of sorts that is situated right on the centerline of the scoop, and right on the nose of the transition fairing you have so skillfully created. Most know of this feature, but most do not know that it pierces upper skin of the scoop and continues right up into the fuselage. Provide for it on your scoop. Drawing number for the blade is 102-31080, and its installation shows up on wing install drawing 102-10001 (see zone A8). ..exactly why i need you on the team Jay - I saw the little blade in the intake, but had not seen it actually goes right through to the fuselage - what a wierd little structure... ..thanks for pointing it out - will be a devil to fit but will give it a go.. so I have skinned the front fairing of the intake.. first the inner liner was added and rough cut to the edge, this was later sanded & filed flush with the intake lip.. ..then the outer skin, I thought the best way was to try and wrap it as near as possible and try to get the join out of sight at the bottom... ..the skin had one good straight edge along the panel line of the first part so this was the reference point from where everything else must follow - this was taped down so as not to move in the beating process.. ..at this point the ali is coaxed to follow the compound curves with a mini ball pein hammer - this is a long process of tapping all the creases into flats... ..ultimately the metal gives way and the shape is good enough to stick down. I use contact adhesive and in this case was lucky I could unfurl the metal so as to hinge via the adhesive tape along that top panel line - that way it just folds back perfectly into position. Then more tapping and cutting and the result is a rough leading edge, but good enough to work with... ..this is then rough sanded & filed to get near to a finished surface... the photos show where I still need a few tweaks, and will try and add a sliver at the join line, but overall a tricky part is done.. ..until next time.. TTFN Peter TAG, GMK, LSP_Kevin and 18 others 21 Link to comment Share on other sites More sharing options...
R Palimaka Posted January 10, 2019 Share Posted January 10, 2019 (edited) Incredible work as usual. A hammer...I've often thought of using one on my models, but not to build anything... Richard Edited January 10, 2019 by R Palimaka BiggTim, D.B. Andrus, BlackCanopy and 5 others 3 5 Link to comment Share on other sites More sharing options...
JayW Posted January 10, 2019 Share Posted January 10, 2019 The radiator / oil cooler scoop is a signature feature of the Merlin P-51. You have to get it right. You have represented it in great fashion. daHeld and airscale 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 10, 2019 Share Posted January 10, 2019 Every time I think I've seen it all, you come along and up the ante, Peter. Kev daHeld, airscale and BiggTim 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 11, 2019 Share Posted January 11, 2019 Jebus man! Do you have any limits?! BiggTim and airscale 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted January 11, 2019 Share Posted January 11, 2019 Haaaayyy , that looks eeeeasy ! airscale and BiggTim 2 Link to comment Share on other sites More sharing options...
ungoliat Posted January 11, 2019 Share Posted January 11, 2019 Hi Following this thread is like following a TV series. There remains one hoping that it will happen in the next chapter .... Beer and popcorn, to wait for what follows of the show.. Greetings from Colombia daHeld, airscale, KiwiZac and 1 other 4 Link to comment Share on other sites More sharing options...
airscale Posted January 12, 2019 Author Share Posted January 12, 2019 does anyone know if a factory WW2 CBI Mustang would have the interior of the belly intake painted like this one? ..all the scoop images I can find are resto birds in which it is white or silver I am stuck.... TIA Peter Out2gtcha, daHeld and Uilleann 3 Link to comment Share on other sites More sharing options...
JayW Posted January 12, 2019 Share Posted January 12, 2019 Peter - good question on the interior paint of the scoop. It applies to many interior features. It's my understanding that as the war progressed, less and less use of paint and primer were done at the factories. That is a simple statement that is probably more complicated than that. I think though that the inside of this scoop was just natural metal. I looked for good scoop pics on Upupa Epops, which is in Paul Allen's Flying Heritage Collection, and which is the most accurate restoration I know of, but couldn't find anything. Also it's a D-model. Here is a great walkaround video of Cripes a Mighty 3 (also a D-model), which is purported to be a pretty accurate restoration. About 15 minutes in, they get all inside that scoop, and it's silver in there. daHeld, Out2gtcha and airscale 1 2 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted January 12, 2019 Share Posted January 12, 2019 Hi Peter, this pic comes from the manual I think, not sure if it is a B/D model I personally would think it was left bare metal cheers daHeld 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted January 12, 2019 Share Posted January 12, 2019 also this one ww2 era picture cheers Out2gtcha, daHeld and airscale 2 1 Link to comment Share on other sites More sharing options...
richdlc Posted January 12, 2019 Share Posted January 12, 2019 truly inspirational Peter, as always!! daHeld and airscale 2 Link to comment Share on other sites More sharing options...
airscale Posted January 13, 2019 Author Share Posted January 13, 2019 evening & thanks chaps Been working on the air intake and the exit duct - after wondering if the interior was painted I found this shot of another aircorps P51 and can see where there is closed airframe it's painted and where there is airflow it's natural metal so thats what I went with... inside the underwing airscoop is an oil cooler (I think) that is oval and sits in the formed fairing seen above - behind that is a big square radiator (I think) - I made the radiator from scored black card and litho framing (from a plan, and oddly the dividing bars are offset like in the pic) and I made a balsa form to vacform the fairing the oil cooler sits in... ..this was the skinned while still in the form - I left it in and just cut away what I didnt need later on - vacforming over balsa causes the plastic to virtually bond with it as there are so many airholes in it... ..I have started to tap in the indentation with the ball end of my ball pein hammer.. ..I forgot to have the oil cooler made in my etch run so I had to make it - I just used pipe screens but had to join two down the middle.. ..and the finished assembly - this sits nicely in the airframe... ..the exit duct on the model was out and it was hard to make sense of where the internal skinning is so I just made a pack of parts from the plan so I knew it was right.. ..some ultra violence was then committed... ..to make the two interface together... ..this was then rough filled with P40.. ..another exit duct was needed so this was laid out... ..and a bit of primer to see what's what... ..lots more work to do as the exit duct especially is quite a complex collection of shapes & fillets... TTFN Peter daHeld, Out2gtcha, Trak-Tor and 16 others 18 1 Link to comment Share on other sites More sharing options...
