559 -
Days Won
9
Posts posted by Antonio Argudo
On 3/26/2025 at 12:26 PM, Roy Noras said:
Considering your information, is it safe to conclude that this backrest was mandatory equipment in ALL G's and K's, regardless of manufacturer? If so, it's a pity that it has been omitted both by Hasegawa and Revell. Trumpeter has their own interpretation, which is not correct.
the answer is yes and even the F-4 model, here is a picture from a recent lake recovered Friedrich featuring it, cheers
3 hours ago, Radub said:
The photo pposted by Mike shows the angled rear bulkhead without the back rest in place
correct!
5 hours ago, nmayhew said:can you comment on the seat shown in Mike’s post?
what Radub said, another example without the seat installed showing the plain bulkhead
On 3/22/2025 at 10:09 PM, Chek said:
whats really needed for all the Tamaya 1/32 Phantoms is a revised rear fuselage
the Tamiya kit has more a few shape inaccuracies, that one been one, I don't think it would be easy and viable to make a correction set for that, best way would be adding plastic or material under and sanding to shape it up! cheers
- Tony T, Martinnfb and Anthony in NZ
3
3 hours ago, Mark P said:
Well...now I understand the issues with the Tamiya F-4E. It does appear you offering the later era gun fairing. Will we be seeing a Vietnam era gun configuration too? In addition, if one has an E with the earlier clear parts for the nose (as I do), will this fit the F-4E kit too? I assume it will...
Mark Proulx
Mathieu is the Belgian guy behind LFD not me, to your questions, yes! early short cannon nozzle will be included, the windscreen is still in development as we can see in the test shots he has published, cheers
1 hour ago, Tony T said:
Not only is the E seemingly OOP, it has only the clear plastic nose halves and gun fairing; the F-4EJ release retained those and added the key nose parts in much friendlier grey plastic. The EJ also has the stabilator doubler plates provided as self-adhesive foil, for upper and lower sides (the former came along circa 1974 and the latter ten years later).
The Tamiya J can still be found in the UK in the Navy boxing for about £90 (the Marines one, with the bombs and MERs/TERs about £20 more). This may become plentiful as a prev owned item as Red Pill Models get their F-4B and F-4J to market, before disappearing the way the F-4C/D, F-4E and F-4EJ appear to have done.
And tail fin pod + rear cockpit parts.
Tony
Exactly Tony!
cheers
1 hour ago, scott_t said:
an F-4G nose would be sweet
sure! who wouldn't like to have a 1/32 "Wild Weasel" 😀
2 hours ago, Mark P said:
Well...FWIW....I did do a little snooping on ebay. Yes, the F-4E from Tamiya can be found there. I must admit to being a little shocked though at the price being asked for it. The F-4E being sold for much higher amounts than the F-4C/D or J.
Mark Proulx
that's why, impossible to find one under 200 €, they are out of production long ago, similar case with the F-16C Thunderbirds with small air intake, you will have to pay high if you want one, so that's why the LFD comes to the rescue for the long nose Phantom lovers 😉 cheers
18 minutes ago, Mark P said:
Gotta ask, if so much needed to make an E from the base J kit, why not just buy a 1/32nd scale Tamiya F-4E kit to begin with?
Mark Proulx
well, try to look online for the E or EJ Tamiya kit and you will have the answer, the other option in the market is the Revell/academy kit which the nose is simply very far from the word "accurate"! this set will be super handy for many, including me 😁
cheers
5 years later since I started this post about these plywood relics, Chandos Publications has published its second issue with an article about the pilot Habermehl in which the mystery and circumstances has been solve by a research team during these years, not only that, finally the pilot's remains finally rest in a tomb with his real name which was misidentified all these years, something I couldn't never even imagine of it would be possible when I built the model also, amazing story, very recommended read, cheers
On 10/10/2024 at 2:31 AM, John1 said:
Impressive work. I’ll be following along.
thanks john, I enjoyed your phantom thread a lot, very inspiring work! a wolfpack one is on the plans too someday
On 10/10/2024 at 5:04 AM, themongoose said:Lov’n it! Gonna be watching intently
thanks mate, so hold on tight because this one will take some time lol
On 10/10/2024 at 9:05 AM, alain11 said:hi
I will follow with interest , there is a lot of work to get a detailed cockpit ......
thanks Alain, you are 100% right, my main focus of detail and work will be in the cockpit, not any aftermarkets for the EJ versions that's why i will have to 3D print my own panels, so yes, lots of work ahead! cheers
8 hours ago, Biggles87 said:Also following.
Interesting collection of seats.
John
thanks John, talking about seats, I will say that the Sparkit ones are the best in proportion and details, however the big downside was the visible 3d printing lines over the top part surfaces and the seat cushion/ belts, the rest was alright. to solve this issue I used this scribing/carving tool very effectively and with some fine paper sanding the effect has been reduce, here are some pics, cheers
the kit:
I am using Tamiya 1/32 F-4J model as a base, lucky a fellow modeller gave me the transparent nose included in the EJ model, so I chopped the nose and insert the long nose
Chopping time
I painted with grey the interior side of the nose
The Subject
RF-4EJ Phantom II "433" from the 501 sq. JASDF
- Zola25, alain11, Anthony in NZ and 11 others
14
Another interesting detail we can see on the wings of Mustangs that were ferried to England, as can see in the manuals also, is the separation of the wingtips, therefore the panel line is visible when reassembled, there are pictures of later "D" models been ferried without wingtips separated and they don't show this panel line
1/18 Scale P-51B 3D Print Build
in Works in Progress
Jay wonderful work on that tail, you nail it! now I'm starting to feel sad because this amazing thread is in its ending phase... 😪😅
