JayW Posted May 9, 2021 Share Posted May 9, 2021 Wow Wow Wow!!!! Realism to the inth degree Peter. I love it! Derek B and airscale 2 Link to comment Share on other sites More sharing options...
DonH Posted May 9, 2021 Share Posted May 9, 2021 10 hours ago, airscale said: onto the upper wing where it will get dull for a bit Dull? Are you trying to be funny? There is nothing about this build that will ever be dull. In the words of U2 - even better than the real thing. Brett M, Derek B and airscale 3 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted May 9, 2021 Share Posted May 9, 2021 This precision is not of this world. Well, not of the world I'm living in, anyway. Each and every update is a revelation. Simply phantastic work, Peter. Cheers Rainer Derek B and airscale 2 Link to comment Share on other sites More sharing options...
Thunnus Posted May 11, 2021 Share Posted May 11, 2021 Jaw-droppingly beautiful work as always, Peter! I love the subtle grain on the prop! Derek B and airscale 2 Link to comment Share on other sites More sharing options...
cmayer Posted May 12, 2021 Share Posted May 12, 2021 "...it looks overscale here..." Well, to be fair, the prop looks overscale on the 1:1 version as well. This build is just wonderful to watch. I admit to not having much previous knowledge about the Fury; but learning about this beautiful little Golden Age and Pre-war wonder through your build has been a thrill! My largest take-away on the lines of the machine: you can really see the family lineage from Fury to Hurricane. Especially the vertical stab, the cockpit area to the cowling, and that two-bladed wooden prop looks just like the prototype Hurri. Brilliant work, Peter, and a pure joy to watch. Thank you for sharing it all. Best, Chris KiwiZac, USMC Herc, Derek B and 1 other 4 Link to comment Share on other sites More sharing options...
wpierson Posted May 14, 2021 Share Posted May 14, 2021 On 4/5/2021 at 1:33 PM, KUROK said: Sublime work! I was wondering, do those metal panels keep their shine or do they oxidize quickly? Hi, I'm late to this thread, but I'd like to suggest a product. It's called Renaissance Wax, it's a fine crystalline wax that jewelers and museums use to keep their metal displays from oxidizing. Sometimes clear coats will dull a polished panel, but if you can keep the air from reaching the metal, it'll stay bright for a very long time. I dabble in jewelry and love the stuff! KUROK, airscale, Kagemusha and 1 other 4 Link to comment Share on other sites More sharing options...
Radders Posted May 14, 2021 Share Posted May 14, 2021 Amazing work Peter... simply jaw dropping. airscale and Derek B 2 Link to comment Share on other sites More sharing options...
airscale Posted May 16, 2021 Author Share Posted May 16, 2021 well thank you for so many kind words you guys are too kind I have finished up all the panels around the radiator, but that will have to wait until next time as there is bigger news... guess what this is... ..it's the build jig for one of the upper wings - I translated (& corrected) plans, interpreted photo's and drawings and drew up my own plans - this is the underside of the wing - the most critical part as this is where all the strut mounts, rigging mounts and spacing needs to be super right to mate properly with the lower wing and cabane struts.. ..the lines represent the ribs and a block & carrier are at the leading edge to hold half round stock up above the plan where it needs to meet the nose of each rib - keeps it all straight too.. speaking of which, there are 41, thankfully all the same profile (apart from at the tips..) here they have been made by using a brass template with two holes at the spars that are a tight fit for big press pins to pin stock plastic to balsa and cut each rib's outline. There are a lot of them & once done they are broken out and put together like this for block sanding.. ..I started with the centre section, by now the pin holes in each rib have been enlarged to be a tight push fit on the brass tube spars ..thicker end ribs were added and card fills in the spaces to give torsional stability, also little bits of tube added for strut mounts.. ..the wings are the same method except a black card tip is cut to shape & let into the structure - black so I can see the centreline when shaping later.. ..I bent the few degrees of dihedral into brass rods and used the centre section slid on to the wing structure before the rod spars were fixed to get the relationship to the wing right ..a small square brass sub spar was added to the top where the aileron is and again stock filled up the gaps.. ..times two - soon had the entire upper wing done.. ..I made up a stiff card jig that maps the relationship between the fuselage and wings - it sits on the lower wing and sets the exact position of the upper wing (or it will when I come to make struts & fit it), but useful to see what it all looks like.. ..we have my first biplane ..looooong way to go, but thats a big step forward.. TTFN Peter Starfighter, patricksparks, Greg W and 25 others 27 1 Link to comment Share on other sites More sharing options...
JayW Posted May 16, 2021 Share Posted May 16, 2021 Awesome! I cannot tell - do you have the leading edge on there, or is that still to come? airscale 1 Link to comment Share on other sites More sharing options...
Derek B Posted May 16, 2021 Share Posted May 16, 2021 It looks stunning Peter, even at this stage! Derek airscale 1 Link to comment Share on other sites More sharing options...
tomprobert Posted May 16, 2021 Share Posted May 16, 2021 Wow. And wow again! A master scratch-builder at work. Derek B and airscale 2 Link to comment Share on other sites More sharing options...
sky Posted May 16, 2021 Share Posted May 16, 2021 It's just a pleasure to see this coming together and the techniques used. And I will say it again - the technique itself is not rocket science, neither are the planning, preparation and realization. But golly from the outside looking at the pictures at time it does feel a lot like it, like "ok what planet is Peter from? Parallel Earth?" I have a question though after looking at the pics and reading the text going with it. In the first pic I thought it was brass formers on the outside with balsa ribs inbetween, but later it looks more like plastic and not balsa-y at all. Also the text talks about brass, plastic and balsa. Hm... I would probably have used balsa unless that would have turned out too fragile even with the brass tubes for reinforcement. Derek B and airscale 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 16, 2021 Share Posted May 16, 2021 Excellent work as usual, Peter! Reminds me of building balsa kits when I was a kid. Kev airscale and Derek B 2 Link to comment Share on other sites More sharing options...
DonH Posted May 17, 2021 Share Posted May 17, 2021 Wonderful. Words have failed me again. Derek B and airscale 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted May 17, 2021 Share Posted May 17, 2021 Great problem-solving and execution. Sincerely, Mark Derek B and airscale 2 Link to comment Share on other sites More sharing options...
