airscale 11,982 Posted October 17, 2020 Share Posted October 17, 2020 mojo noun informal a quality that makes you successful and full of energy: · He's definitely lost his mojo. · He needs to get his mojo working if he's going to finish that model Well, I lost mine over the last few months in a big way. For many reasons I just lost interest in my Fw190 and so it has been shelved for now. It's one of those inexplicable things, those that remember the 1/24 Tigercat maybe know I have form in this area .. Instead, I have found a new source of mojo which has seen me back at the bench, enjoying my modelling which is what it is all about right? This is new for me, I don’t think I have ever built a biplane, certainly not scratchbuilt so it will be a journey of discovery I hope to share The Hawker Fury needs no introduction from me, all I can do is show you the picture that set me thinking and ultimately on this path… ..look at that beautiful form, the polished metal nose panels, the state of the art in it’s day. I don’t know yet which airframe I will model, but likely it will be a Tangmere bird as that was but a few miles from my childhood home. I gained the confidence to take the plunge from John Alcorn’s books ‘Scratchbuilt’ where various masters show how they achieve the impossible in relation to fabric covered structures such as those shown below – if you don’t have the books, get them, they are superb.. Need fuselage stringers? A few methods are shown.. Wings? Just like the originals.. I started with the Westburg plans, four sheets sourced from a 1970’s RC Model magazine I found as a PDF that my printer scaled for me.. ..these are widely acknowledged as the most accurate out there.. ..and so onto building & making a start.. ..the first element I thought would be a rigid structure that supports both the landing gear and the cabane struts atop the fuselage. This would need to be very strong and so was made of brass parts.. The very first of which is here – the main gear mount.. ..then the transverse rods that link to the main gear trailing arms and the mounts for those mounted on the mainspar tube.. I used (badly) my new Proxxon mini milling machine for those.. ..all the parts were made up over the plans and ultimately soldered together, including spigots for the cabane strut mounts.. ..the firewall looking square is to add rigidity and the hole is the prop datum that will carry forwards into the nose.. ..more of the fuselage framework was constructed of carbon fibre rod – this stuff is super stiff and easy to work with – I used an RC modeller trick in pinning the rods to a scaled plan to get everything lined up.. ..soon I had both halves (at least the bits that can be seen) which will dovetail into the brass frontal assembly.. ..the real airframe is bolted together with some quite rudimentary brackets – that’s good, I can do rudimentary.. ..I should have made these from PE, but such was my renewed enthusiasm I made them by hand with the resultant rudimentary outcome.. ..the structures were primed and painted with black MRP enamel and the assembly plates added.. ..whilst I didn’t take any construction pictures, I did make up the seat based on the few pictures I have (that’s a problem I will come onto later..) …essentially I drew parts as templates and cut them from litho, annealing & shaping them and bordering with fine solder wire.. ..to finish up for now, the work to date dry fitted together… ..now for the appeal – I have zero drawings apart from the plans, I have the one Mushroom book I could find and that is 80% about the Nimrod, not the Fury and about 5 cockpit pictures all from the same angle from the internet.. I have written to both operators of existing Furies in the hope they have drawings they can share, but if anyone out there knows of any good reference, please let me know – drop links in here or PM me perhaps So that’s it – a change in direction, for me the main thing is being motivated to pull up to my bench and enjoy myself and that I am now doing ..hopefully this one will see a competition table in a few years TTFN Peter D.B. Andrus, Sepp, Starfighter and 37 others 40 Link to post Share on other sites
Iain 13,770 Posted October 17, 2020 Share Posted October 17, 2020 I can't love this enough - this will be a stunner in this scale, and built by the Maestro! Iain airscale 1 Link to post Share on other sites
jumpjack 47 Posted October 17, 2020 Share Posted October 17, 2020 And there was me hoping for a Wyvern TF1! Should it come to making brass look like steel/aluminium, I guess you know about 'immerse tin powder@ used for cold tinning? Les airscale 1 Link to post Share on other sites
Out2gtcha 36,393 Posted October 17, 2020 Share Posted October 17, 2020 Wow!! airscale 1 Link to post Share on other sites
mozart 13,296 Posted October 17, 2020 Share Posted October 17, 2020 You've got my attention straight away Peter, surely one of the most elegant and beautiful aeroplanes ever built. Can't wait to see you work your magic on this one, especially that cowling. Kagemusha and airscale 2 Link to post Share on other sites
wunwinglow 5,675 Posted October 17, 2020 Share Posted October 17, 2020 Wonderful. Just wonderful! airscale and mozart 2 Link to post Share on other sites
Fvdm 679 Posted October 17, 2020 Share Posted October 17, 2020 Great subject Peter, have fun building it. I see you using carbon fibre rod. Do you glue this with regular CA? Or are you using something else? airscale 1 Link to post Share on other sites
brahman104 2,806 Posted October 17, 2020 Share Posted October 17, 2020 For someone that lost their modelling mojo for a few months, you seem to have half a plane built already!!!!!!! Great start on the project so far Peter! I love all the little gusset plates as well, how do you do all the little internal cuts in the litho, is it just scribing with a pin then snapping out like normal? LOVE all the brass work too, you'll definitely need it for this one! Craig airscale 1 Link to post Share on other sites
dodgem37 8,566 Posted October 17, 2020 Share Posted October 17, 2020 Nice start. Great show. Wonderful book. Excellent reference. What scale? Thank you. Sincerely, Mark airscale 1 Link to post Share on other sites
Anthony in NZ 6,199 Posted October 17, 2020 Share Posted October 17, 2020 (edited) Guys.....dont let Peter fool you! This clearly is NOT a model and he is building a real one. Nice try Pete, but you cant fool us! Edited October 17, 2020 by Anthony in NZ Kagemusha, airscale and MARU5137 2 1 Link to post Share on other sites
tomprobert 3,398 Posted October 17, 2020 Share Posted October 17, 2020 Wow. This is going to be epic! Great choice of subject too. I know exactly what you mean about the mojo. When a model becomes a chore it’s time to put it away. That’s why I’ve got about a gazillion projects on the go at any one time and as you rightly say modelling should be fun - and it looks like you’re having a blast. I can’t wait to see more! Tom airscale 1 Link to post Share on other sites
chuck540z3 9,772 Posted October 17, 2020 Share Posted October 17, 2020 Peter, you could build a pick-up truck and I'd still follow- and still be blown away by your skilled work. Looking forward to this, because I'm contemplating a Bi-Plane for my next build as well. As they say, model-on! Cheers, Chuck airscale 1 Link to post Share on other sites
vvwse4 578 Posted October 17, 2020 Share Posted October 17, 2020 Just great!! airscale 1 Link to post Share on other sites
LSP_Kevin 32,475 Posted October 17, 2020 Share Posted October 17, 2020 Can this be real? Kev airscale 1 Link to post Share on other sites
geedubelyer 1,430 Posted October 18, 2020 Share Posted October 18, 2020 Yep, you've got my vote Peter. Nice start. I'll definitely tag along for this adventure. airscale 1 Link to post Share on other sites
