Hello LSP!    I've never posted here before, but I have been at Hyperscale, Brit Modeller and ARC over many years. Anyway- here we go!
Spitfire Mk XVI SL721 AU-J was a veteran of the RAF and has been kept flying until the present day.  Right now she is in Belgium, registered as OO-XVI.  Another member here "red Dog" has done  a terrific job on this example previously on this forum.  More on red Dog later....
This aircraft was previously owned and operated by Vintage Wings of Canada and the Mike Potter Collection in Gatineau Quebec, close to Ottawa here in Canada.  This kit was obtained by a fellow named Graham C, a member of the VWoC and he had hoped to build it. He decided, however, that it was beyond his ability to do it justice and decided to donate it to VWoC if someone would volunteer to build it.  I said I'd give it a crack and here it is.
I won't go into detail on the 1/32 Tamiya kit as it has been covered many times but will try to focus on the modifications and extras I attempted.
First off SL721, AU-J  reg C-GVZB as she was in Canada.2KDD8V9Y7ZFWdOWbvK4aRzXndp5PKAweznQzSMKC
I decided to start with the engine firewall.  Using as many photos as I could collect I added piping and lines.j_BiQMZmZM5Hjwl5E7Aio_eO0u9EzwfXwhLKpKA1
rSXM7sEa9AzooUiHJCbVoeNPaW8nsu0MYDyX9OES
Next up the engine was assembled and base coat of X18 semi gloss black.
DoQTNWzpPnp5Kx858uLT5kHjxDHoY-2z1AnBRgaf
The left side received spark plugs and wires.  These are VERY thin wires with most of the insulation stripped, leaving just a little on the end to represent the spark plug boot.  The yellow would be painted over later.   Some oil lines were added using lead wire and the and the ignition wire tube was made from plastic rod.ELMLGRejpkJ08WwU-DRsijCNz3kzQDkQKGRwyd8y
The right side..
.matqmqc1Wpk1GvAtU5M4cII8xR_l9u2j4Nwe2KXZ
The supercharger...
2K55K5oC1RAar48_XmmSiSpgooJIxhgaJkGQxVLv
And underneath...
2SEh45gl6iWFzRREUYP0pW6Ksz_Kjdyp10Xv5oOX
That's it for today.  Next I will show the upper (inside) ignition harness, both the first and second versions....
Edited by Bill Bunting
14 hours ago, Greg W said:
Welcome to LSP!
Stellar work on this Bill! This is a follow for sure.
Where do you get your lead wire?
Thanks.   The silver wires are solder, which is very easy to bend but is also eady to scar.  The copper and brass were from a craft supply store in the jewelry area. A bit of brass pipe was from the good old hobby shop.
