Cees Broere Posted November 20, 2022 Share Posted November 20, 2022 Morning all, The 1/32 Manchester is progressing very well now I have a set of 3D printed Vulture nacelles. The model is getting very heavy and I think the HK Models landinggear parts are not strong enough. I was thinking about using aftermarket ones and noticed SAC does a set. But what about strength? Does anyone know? TIA Cees BiggTim 1 Link to comment Share on other sites More sharing options...
Lancman Posted November 20, 2022 Share Posted November 20, 2022 Hi Cees, I bought a set for the Trumpy Hurricane and found they are poorly made and soft white metal. So I wouldn't think they would hold your Manchester. Graham kalashnikov-47 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted November 20, 2022 Share Posted November 20, 2022 1 hour ago, Cees Broere said: Morning all, The 1/32 Manchester is progressing very well now I have a set of 3D printed Vulture nacelles. The model is getting very heavy and I think the HK Models landinggear parts are not strong enough. I was thinking about using aftermarket ones and noticed SAC does a set. But what about strength? Does anyone know? TIA Cees Forget it! They are just useful for 1/72 kits, barely for 1/48 models and totally useless for large scale. D Bellis, Cees Broere and LSP_K2 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 20, 2022 Share Posted November 20, 2022 Marry Snog Avoid. At all costs. You may as well replace the kit landing gear with spaghetti. Aerocraft does a proper brass set, but they're currently listed as out of stock: https://aerocraftmodels.bigcartel.com/product/avro-lancaster-undercarriage-set-for-the-hong-kong-model-kits Perhaps contact Ali and see what's up with that? Kev LSP_K2, D Bellis, Cees Broere and 3 others 5 1 Link to comment Share on other sites More sharing options...
Iain Posted November 20, 2022 Share Posted November 20, 2022 As others have said - personally, I'd avoid. The ones I've had have has less strength than the plastic parts they are meant to replace. Iain LSP_K2 and Swatto 2 Link to comment Share on other sites More sharing options...
Rick Griewski Posted November 20, 2022 Share Posted November 20, 2022 Wow those Aerocraftmodels gear are very impressive. Thanks for posting Kev. LSP_Kevin, Iain and kalashnikov-47 3 Link to comment Share on other sites More sharing options...
Cees Broere Posted November 20, 2022 Author Share Posted November 20, 2022 Thanks for the advice chaps. Link to comment Share on other sites More sharing options...
cbk57 Posted November 20, 2022 Share Posted November 20, 2022 i used a set on the Tamiya corsair and had to replace them because they were worse than the plastic parts. Everyone complains about the larger scale sac part, it mystifies me that they don't fix this. I certainly will not trust them until we see something definitive that they are changing their materials but they have sold the same useless produce for years. Link to comment Share on other sites More sharing options...
Sabrejet Posted November 20, 2022 Share Posted November 20, 2022 SAC parts are just copies of the kit parts and in my experience no stronger than the plastic parts. I'd save your money. Swatto 1 Link to comment Share on other sites More sharing options...
AlanG Posted November 20, 2022 Share Posted November 20, 2022 Bought a set for for a 1/32 Revell Tornado. Absolute garbage. Ended up selling them again. Will never buy any again no matter what scale i need replacements for Sabrejet 1 Link to comment Share on other sites More sharing options...
John1 Posted November 20, 2022 Share Posted November 20, 2022 (edited) As others have said, these parts are nothing but copies of the kit bits using soft lead. Complete garbage. The funny thing is - if you go to another common modeling site, the site owner routinely publishes "reviews" about pretty much every SAC set that comes out, gushing about how they are such an improvement over the kit parts. Pathetic.... Edited November 20, 2022 by John1 AlanG 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted November 20, 2022 Share Posted November 20, 2022 Our own LSP_Ray has reviewed several sets here, and his conclusions are always the same;... don't bother. Iain and John1 2 Link to comment Share on other sites More sharing options...
MikeC Posted November 20, 2022 Share Posted November 20, 2022 I used a set on the Meng 1/32 Dr1 as one of the kit struts broke and it delayed the model for a while. They work, but are very bendy, and fitting the undercarriage was "interesting". I used a set on the Revell Hunter, and they seem OK, albeit that they appeared to my eye to be identical to the kit parts, but they do seem to support the weight of that large model. chrish 1 Link to comment Share on other sites More sharing options...
Jack Posted November 20, 2022 Share Posted November 20, 2022 Cees, PM inbound Link to comment Share on other sites More sharing options...
LSP_Ray Posted November 20, 2022 Share Posted November 20, 2022 4 hours ago, LSP_K2 said: Our own LSP_Ray has reviewed several sets here, and his conclusions are always the same;... don't bother. Not quite true. They are typically, though not always, copies of the kit parts. If the aircraft has pretty spindly gear, the SAC gears will bend easily. If the gear is pretty beefy, the SAC gear is strong enough. Of course, if the gear is beefy, the plastic gear will be fine, too. The combination of no extra detail, sometimes rough casting, and difficult cleanup as well as using pretty soft metal makes them only useful if you break the originals. If they would use a better metal it wouldn't be so bad. BloorwestSiR, MikeC, coogrfan and 1 other 4 Link to comment Share on other sites More sharing options...
