Rick Griewski Posted December 6, 2018 Share Posted December 6, 2018 I made a template to fix the P-40 B cockpit depth so I will dig that out and go from there. We are always fixing sumting dumb on most kits. Rick Troy Molitor and Harold 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted December 6, 2018 Share Posted December 6, 2018 When I see that kit with shortcuts and stupid errors jumping from another kit that is more than ten years old, I cannot stop wondering if that kit is really new... It is new from a release perspective but as the P-40 family was announced many years ago, I would not be surprised to discover the CAD was made years ago. Weird! Even if I'm not really fond of the Hasegawa kit, I think I will rather rely on the Hasegawa/Greymatter/Zotz combination. Assembly will not be easy but at least correction surgery will not be required. It is a pity as the Trumpy kit looks to have some positive assets; one example being the seat that looks far better than the Hasegawa one. Link to comment Share on other sites More sharing options...
corsairlada Posted December 6, 2018 Share Posted December 6, 2018 11 hours ago, Jan_G said: the first camouflage "209" is right for the long hull Quote Link to comment Share on other sites More sharing options...
VMA131Marine Posted December 7, 2018 Share Posted December 7, 2018 On 12/6/2018 at 5:51 AM, thierry laurent said: Well, I do not know if my eyes are fooling me but do I see quite shallow cockpit sides/rear bulkhead and a flat floor...? Please tell me I am wrong! You are not wrong! And the nose on this model is also very wrong. KUROK 1 Link to comment Share on other sites More sharing options...
VMA131Marine Posted December 7, 2018 Share Posted December 7, 2018 (edited) On 12/6/2018 at 5:21 AM, rafju said: Can't wait, I'm ready ;-) Compare the line of the upper cowl in this image to that of the kit parts and the Trumpeter colour profiles. Notice how the line is essentially straight past the forward-most exhaust and only curves slightly between that point and the spinner backplate. Then look at what Trumpeter did. They could easily have got this right but they just don't care! Short-tail 'F' Long-tail 'L' Edited December 7, 2018 by VMA131Marine Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 7, 2018 Share Posted December 7, 2018 Yes, you can see from the photo above how straight the top of the cowl should be, until just before the spinner. Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 7, 2018 Share Posted December 7, 2018 If the box art is any indication, Id not get my hopes up. That is some of the worst box top art Ive seen on a model kit in a long time. The perspective just looks really off. phasephantomphixer and LSP_K2 1 1 Link to comment Share on other sites More sharing options...
mhorina Posted December 8, 2018 Share Posted December 8, 2018 (edited) No parts for the'long tail'. Only short tail kit. Not accurate for decal option, Tiger mouth 209 Mike Horina Edited December 9, 2018 by mhorina Link to comment Share on other sites More sharing options...
MikeMaben Posted December 9, 2018 Share Posted December 9, 2018 On 12/7/2018 at 12:34 PM, Out2gtcha said: The perspective just looks really off. I've seen worse , you're right tho , it is more about perspective. Looks like a direct copy of this photo (posted earlier by Kevin). Even the prop blur is identical. They just put it way too close to the ground. Probably another team effort at Trumpeter. Troy Molitor and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Mikester Posted December 9, 2018 Share Posted December 9, 2018 I think it's safe to say that some people have an axe to grind with Trumpeter. Some companies seem to get much more slack when it comes to errors. Revell's Bf 109G-6 cannot be built into an accurate kit without a replacement upper cowl deck and Beule. BTW they did hire a team of experts to consult on it and it still wasn't perfect OOB (the bean counters won). There are other kits they've in done that have issues but they seem to get a pass because they're less expensive than other brands. I typically only buy kits on sale anyway so price doesn't really factor in for me and Revell aren't cheap everywhere either. Then again some are exceptional kits that very accurate, just like Trumpeter. I'll continue to judge each kit on it's own merits rather than condemning it out of hand, regardless of who makes it. I'll most likely get this kit, a little work with a sanding stick should help flatten out the upper cowl and it may require a little aftermarket to get up to speed but that's true of most kits in my stash. Link to comment Share on other sites More sharing options...
Dave Williams Posted December 9, 2018 Share Posted December 9, 2018 I don’t see that people specifically have an axe to grind with Trumpeter. They make some good kits, and even their “A Team” kits aren’t perfect, but usually not much is said about them. However, many times when Trumpeter does screw up, it’s fairly big and obvious, and it’s usually those specific “B Team” kits that get most of the grief. I see the criticisms being more kit specific than company specific. In this instance, I think that the P-40F cowl shape and too shallow cockpit (repeat offense) are probably more egregious issues than the issues with the RoG 109. LSP_K2, rafju and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
Mikester Posted December 10, 2018 Share Posted December 10, 2018 3 hours ago, Dave Williams said: I don’t see that people specifically have an axe to grind with Trumpeter. They make some good kits, and even their “A Team” kits aren’t perfect, but usually not much is said about them. However, many times when Trumpeter does screw up, it’s fairly big and obvious, and it’s usually those specific “B Team” kits that get most of the grief. I see the criticisms being more kit specific than company specific. In this instance, I think that the P-40F cowl shape and too shallow cockpit (repeat offense) are probably more egregious issues than the issues with the RoG 109. OK, if you want something more egregious we can move over to the Revell Erla 109G-10. The cowl is off to the point that it pretty much requires a whole resin replacement if you want it to look right. I agree that there's really no excuse for the shallow cockpits though, should have been corrected. nmayhew 1 Link to comment Share on other sites More sharing options...
VMA131Marine Posted December 10, 2018 Share Posted December 10, 2018 6 hours ago, Mikester said: I'll most likely get this kit, a little work with a sanding stick should help flatten out the upper cowl It's going to take more than a sanding stick to fix the cowl on this kit. The excessive curvature means the centerline of the prop is too low. If you move it up you'll have to add height to the radiator intake. In short, it will take major surgery to correct. David66 1 Link to comment Share on other sites More sharing options...
Gerhard Posted December 10, 2018 Share Posted December 10, 2018 Are those PE Hinges for the flaps? Please dont say so. Link to comment Share on other sites More sharing options...
thierry laurent Posted December 10, 2018 Share Posted December 10, 2018 Indeed, forget the idea to sand to correct the nose. You would need at least a 2 to 3 mm thick plastic nose just to flatten the line and this would not solve fully the geometry issue. I did not see anybody in this thread who bashed the kit because it is a Trumpeter product as such. Negative points were based on the sprues we saw. Nothing more. However, it is fully true to say that, as a plane model scale company, Trumpeter may be very frustrating for one reason: they do not have a coherent learning curve. For instance, I do not remember one review of the P-40B that did not stress the too shallow cockpit for the last 15(?) years. This did not prevent them to repeat the same error. Observing that is not Trumpeter bashing. Alas, this is just a fact... Alburymodeler, GeeBee, David66 and 2 others 5 Link to comment Share on other sites More sharing options...
