mhorina
LSP_Members-
666 -
Everything posted by mhorina
Hey, Jay I would recommend Damian's Synthetic Ordance here on LSP for his landing gear legs for your 47. Check him out. Mike Horina
To all,l thank you so much Mike Horina
Short tale, after 40 years of building 48th scale aircraft kits with about 50 finished kits on the shelfs along came my dream kits. 32nd scale kits started to arrive as did this site ,how to build them and discuss these kits. I'm one of the earliest members of this site . Build them or sell them ? Some time you don't get a chance to do what you want. After retiring with home paid for .Children all married,Grandchildren going to collage I thought I'd be able to go to the stash and just build and buy anything I wanted. I did for 13 years. then early onset dementia and alzheimer's ruined my plans. Not everyone gets to be happy.Only trying to be happy. I don't like to sell from my stash but ,as my wife told me,sell what you can. The kids love you they won't have to threw that many away. mhorina Mike Horina
Has anyone converted Hasegawa Bf 109F-4 to a G-2 or 4
mhorina replied to oyoy5's topic in LSP Discussion
Agree with getting a G-4 kit Mike Horina -
1/32 Hasegawa Bf 109G-14 Hartmann Double Chevron
mhorina replied to Thunnus's topic in Works in Progress
Thunnus, Back in the day Bruce Radebaugh of Parts-R-Parts made a resin part to correct the alignment of the oil cooler on the Hasegawa 109 G6 and 14 kits. You would cut the whole ring on the nose and replace it with his correction part. Mike Horina -
What is the oldest original kit in your stash?
mhorina replied to LSP_Mike's topic in General Discussion
Airfix 1978 109F-4 Mike Horina -
2020 Tamiya Nuremberg reveals new 1/32 F-51D.
mhorina replied to Kahunaminor's topic in LSP Discussion
Dave in your post above. Thought it was for the new release.Sorry Mike -
Parts show up on instruction sheet for the camra instal.Parts are in the Pacufic release I don't know anything about whats needed in the cockpit . Mike Horina -
How to order? I tried and PM said cant send Mike Horina
Yep I don't see the air scoop in that picture Mike Horina
Plumbing diagram 110 gallon paper tank P-51
mhorina replied to mhorina's topic in Aviation Discussion & Research
TAG, thank you for this picture. Along with the previous picture it is just about all anyone could want or need. Mike -
Very close and it will help. Thank you. If possible, if anyone can show how the pipes are on the tank itself that would be appreciated also. Thanks again Juggernut. Actually I think it shows what I was looking for. Mike -
mhorina posted a topic in Aviation Discussion & Research
I am in need of a diagram that shows the plumbing for the P-51 Mustang with under wing pylons using the 110 gallon paper fuel tanks. Thanks for any and all help. Mike Horina -
Not happy to hear they are for the Revell G-6 kit. Still have too many Hase 109s left. Maybe these new parts can be used or modified to get something useful for the Hase kit. I think AIMS has the right idea of improving both the Hase and Revell kits, helping both kits with parts for both of the kits Mike Horina
I will be there. Thursday& Friday Mike Horina
I would try adding Tamiya Clear Blue to whatever version of Aluminum paint you are going to try and use. HTH Mike Horina
Any interest in F4U-5N decals? AVAILABLE last info
mhorina replied to blackbetty's topic in Vendors Board
Karl thanks. Count me in. Mike Horina -
What is the best base kit to make a Bf-109G-6AS from
I'm just about to start on mine. As Thierry said start with Hase G-10. I am using the nose parts from the G-10 and the fuselage parts off a G-6 kit. Cutting the G-10 kit parts that would attach the G-10 fuselage off and using the fuselage cut from the G-6 kit. If you have a G-14 kit available you could use the tail parts from that . I will cut the G-10 tail off at the trestle hole and do the same with the G-6 fuselage to so as to use the tall tail fin. Or if you have a spar G-14 kit that tail could also be used, and just use the instructions from the G-6/G14 Good Luck. Or if you can get a Revell G-6 cheap you could usethe rear fuselage from that and use the Hase G-10 kit as above. Mike Horina -
Ray and RBrown,thank you both . The info was just what I was looking for. Thanks again. Mike Horina
Can someone point me to the various camo patterns used by various manufacturers of the Me 109G/Ks late war ? Thanks in advance for any help. Mike Horina
Very nice job. I like how you used a variety of AM parts and got them together so nicely. Your paint job looks great. I would like to ask you or anyone who could answer a question. On the Hase 109G-10 kits there is a different belly cover (sorry don't know the tech name) then what is used in the G-6 and G-14 releases that has a thin cover slot that can be cleaned out to open a slot for clearing out the used shell cases. Sorry to ask here, but I saw that your build uses the larger gun ,but there is no slot for the shell cases. Of course maybe the Erla G-10s did something else. Again great build an sorry to have asked the ? here. Mike Horina
Wegner , No I didn't remember or I didn't remember seeing it Thank you that proves some of what i thought. Scott, Thank you Mike Horina
I am using an AM interior set for a 109G kit, There are wire bundles in a couple of areas. What color would these be. Instruction sheet not that informative. At one time I never even did interiors just used kit parts. However that being said I thought I ask and try to fine some accurate info. Once upon a time, I can remember doing them White, not sure so I'm asking for help TIA Mike Horina
I'm in . I think the masks are a great way to make this happen. Again count me in. Mike Horina -
Painting not gone well - have you had this?
mhorina replied to Stevepd's topic in Painting & Finishing
How do you power your AB ? Maybe something went wrong a/c outside temperature. Air tank to cold, compressor moisture?
