Rick Griewski Posted November 19, 2022 Posted November 19, 2022 Hmmm I do not think or feel that I am a “bleeding heart” but I could be wrong if I was told directly. Anyway a question for a Hurricane special interest person. If the wing has more or less gun openings in the wings for the intended type, does adding a gun hole change ammunition loading panel configuration on the top of the wing. I do not want to correct that error.
Kagemusha Posted November 19, 2022 Posted November 19, 2022 1 hour ago, Rick Griewski said: Anyway a question for a Hurricane special interest person. If the wing has more or less gun openings in the wings for the intended type, does adding a gun hole change ammunition loading panel configuration on the top of the wing. I do not want to correct that error. There were two spent ammo ejector holes in the undersides. This how Fly tackled the issue, vinyl masks to scribe the panels/ejector holes, and resin gun barrels, but no bomb racks included. LSP_K2, MikeC, Rick Griewski and 3 others 5 1
VMA131Marine Posted November 19, 2022 Posted November 19, 2022 1 hour ago, Rick Griewski said: Hmmm I do not think or feel that I am a “bleeding heart” but I could be wrong if I was told directly. Anyway a question for a Hurricane special interest person. If the wing has more or less gun openings in the wings for the intended type, does adding a gun hole change ammunition loading panel configuration on the top of the wing. I do not want to correct that error. The Mk IIb has additional panels for gun an ammunition access for the extra outer two .303s on each wing. There are additional cartridge case ejection ports on the wing underside. Rick Griewski 1
Troy Smith Posted November 21, 2022 Posted November 21, 2022 2 hours ago, coogrfan said: For us non-Hurricane boffins, how much work would be required to backdate this to a BoB Mk.I? Quite a lot. See below. Note, there were a few Mk.IIa's used from September 1940, which could be done very easily from the kit, if you want a BoB machine. Here are the Hawker production figures for Mk IIs built during 1940: Aug. 12 Sept. 34 Oct. 24 Nov. 47 Dec. 54 Total 171 B of B casualties from the early batches were: Z2308 111 Sqn damaged in combat 9.20 am 4 September (A/c repairable) Z2309 111 Sqn FTR from operational sortie circa 9.15 am 4 September (P/O J.Macinski MIA) Z2315 111 Sqn F/landed following combat with Bf 109s at 9.00 am 4 September (A/c repairable) coded JU-E Z2345 421 Flt F/landed due to unknown cause at 4.55 pm 26 October (A/c repairable) coded LZ-H Z2352 421 Flt F/landed due to unknown cause at 2.51 pm 19 October (A/c repairable) coded LZ-U If memory serves, the LZ code of 421 Flt was hyphenated. And some other Mk II trivia: F/flight of prototype (P3269) 11 June 1940" see The nose is shorter, but the length change is in the panel in front of the cockpit, and the front wing fillets are different as well, and the radiator is shallower with a different intake and a smaller carb intake. the kit spinner would only be good for some late build Mk.I's. The tailwheel and radiators are Mk.II standard items. The drawings are wrong, the air intake has a faring at the rear, rather then moving back. this is Mk.I extended into a Mk.II and before, showing the cut line, this is the underside of the nose, the red lines are the engine bearers, coming off the main spar, the area in this triangle is flat. this shows the engine bearers thisshows the flat area, and how the bearer is at the bottom of the fillet Also of note is the radiator, which is the Canadian type. The British type is more of a rectangle, as seen below Fly do a 1/32 Mk.I, which while not the easiest of builds, maybe not much more work than hacking about the kit, and does have all the relevant bits. Also, the Hurricane Mk.I is much more complex in detail than is usually realised, like 6 different props and spinners..... https://www.britmodeller.com/forums/index.php?/topic/234980181-hawker-hurricane-propellers-and-spinners-a-modellers-guide/ does need a rewrite, but does cover all the variations.. @Radub can you tell Revell that the vast majority of Mk.IIB's are interally aluminium paint excpet for the cockpit rear bulkhead and upper cockpit walls. The Austin built MkIIbs look to be all grey green though. This is from, the films of the production line, linked in the link below see https://www.britmodeller.com/forums/index.php?/topic/234963507-all-the-hurricane-questions-you-want-to-ask-here/page/2/#elControls_1682406_menu needs a rewrite, but covers gives an idea of what batch had what. Links to the factory film, these are IIb' s (so same as Revell kit) from the 300 built by Austin, most went to Russia, but a few ended up in SEAC. 1 - https://youtu.be/YBugc28Eqj0 2 - https://youtu.be/ay6xmfMnBZ0 3 - https://youtu.be/X-N3raGe9p0 note this link to time of serial and roundel application https://youtu.be/X-N3raGe9p0?t=182 4 - https://youtu.be/kN7bbFRUSCY For those wondering about other variants wing types https://www.britmodeller.com/forums/index.php?/topic/234963507-all-the-hurricane-questions-you-want-to-ask-here/page/44/#elControls_3069353_menu A final note. Hurricane are poorly documented in the kind of detail modellers want, the Mk.I is very well covered in the Wingleader Photo Archive, https://www.wingleader.co.uk/shop/hurricane-mki-wpa3 but the Mk.II and in particular the IID/ Mk.IV are not well covered. In particular DO NOT trust Valiant Wings Airframe and Miniature book, it's frequently wrong in many of the details, eg the drawing don't show the Mk.II air intake and are particularly bad on the Mk.IV and Canadian built Hurricanes. HTH Kagemusha, Tolga ULGUR, Archimedes and 18 others 11 10
mozart Posted November 21, 2022 Posted November 21, 2022 (edited) And there was me planning to build the prototype……! but I'll definitely be modelling this one: since my father flew her. Edited November 21, 2022 by mozart Archimedes, npb748r, Paul in Napier and 14 others 17
Rick Griewski Posted November 21, 2022 Author Posted November 21, 2022 Wowa Mozart, your father must have be a very, very young man.
quang Posted November 21, 2022 Posted November 21, 2022 16 minutes ago, Rick Griewski said: Wowa Mozart, your father must have be a very, very young man. You would have known him as Amadeus Sr Alain Gadbois, Martinnfb and Paul in Napier 3
Troy Smith Posted November 21, 2022 Posted November 21, 2022 55 minutes ago, mozart said: And there was me planning to build the prototype……! Ah, the prototype..... as initially flown, and seen in the above image, had a different wing, being straight, this was brought up on Britmodeller, as being noted by James Goulding in his book Interceptor. https://www.britmodeller.com/forums/index.php?/topic/235061223-hurricane-prototype-in-148th-where-do-i-start/page/2/#elControls_3475399_menu Images online are not that clear, I recently found a shot from below of the prototype in an old model magazine, a Scale Models from 1974, which confirms this, helpfully with another underside shot for comparison.... it doesn't mention this of course, but it's very clear once you know. This also means that this is an error in the Bentley drawings. Note (and not much use unless you consider 1/48th Large Scale) but the 1/48th Monogram kit has this straight leading edge wing.... Not much use for anything else but it has this as starting point. Anyway, making the prototype as first flown is a major amount of work, in any scale. Regarding Max other choice, this is the other side discussions on the RATG Hurricanes https://www.britmodeller.com/forums/index.php?/topic/234950889-hurricanes-of-the-ratg/ more photos and discussions.... Isar 30/07, LSP_Kevin, D.B. Andrus and 4 others 7
mozart Posted November 21, 2022 Posted November 21, 2022 29 minutes ago, Rick Griewski said: Wowa Mozart, your father must have be a very, very young man. 21 to be precise Rick. Jeff, Martinnfb, thierry laurent and 2 others 5
Archimedes Posted November 21, 2022 Posted November 21, 2022 (edited) 1 hour ago, Troy Smith said: Ah, the prototype..... as initially flown, and seen in the above image, had a different wing, being straight, this was brought up on Britmodeller, as being noted by James Goulding in his book Interceptor. https://www.britmodeller.com/forums/index.php?/topic/235061223-hurricane-prototype-in-148th-where-do-i-start/page/2/#elControls_3475399_menu Images online are not that clear, I recently found a shot from below of the prototype in an old model magazine, a Scale Models from 1974, which confirms this, helpfully with another underside shot for comparison.... it doesn't mention this of course, but it's very clear once you know. This also means that this is an error in the Bentley drawings. Hi Troy - are you referring to Sheet 2 of the 4 sheet series that Arthur Bentley produced? It is Marked as K5083 and you are correct the wing is drawn with the same small sweep back as the Mk1 which photos show, as first flown, had a straight wing with no sweep-back to the leading edge. Wasn’t this changed later in the prototype’s life to have a marginally swept back wing which became the Mk1 configuration? I am interested to learn your thoughts on this. Kind regards, Paul Edited November 21, 2022 by Archimedes mozart 1
Troy Smith Posted November 21, 2022 Posted November 21, 2022 42 minutes ago, Archimedes said: Hi Troy - are you referring to Sheet 2 of the 4 sheet series that Arthur Bentley produced? It is Marked as K5083 and you are correct the wing is drawn with the same small sweep back as the Mk1 which photos show, as first flown, had a straight wing with no sweep-back to the leading edge. Wasn’t this changed later in the prototype’s life to have a marginally swept back wing which became the Mk1 configuration? I am interested to learn your thoughts on this. Kind regards, Paul Hi Paul the Bentley drawings are rightly regarded as the best done, see the cutting from when they were first published in 1980 below. Yes, I'm talking about the drawings of K5083, which do show all the prototype changes, and development... except the wing. The straight wing leading edge on the initial prototype was mentioned in the linked thread and was the first I had heard of it https://www.britmodeller.com/forums/index.php?/topic/235061223-hurricane-prototype-in-148th-where-do-i-start/page/2/#elControls_3475399_menu I then got the Goulding book, and went on an image hunt, it was only last week when I was looking by chance through an old Scale Models I found an underside shot of the prototype, with no sweep. I've just not got around to posting it. There may well be images of the prototype when fitted with gun wings that then have the sweep, which was standard for all versions, which would make sense, as the link suggest this was done for centre of gravity reasons. If I sound vague, it is because this is an area that is vague, and I'm surprised it was missed by Bentley. People have been kind enough to call me "an expert" , which is flattering, but I'm not, but what I really do is collate available data, and I spend a lot of time searching about and I have often been surprised at what gets missed, including things I have looked at many times myself..... I intended to get up to the RAF Museum library in Hendon in late March 2020...but that got postponed for some reason! Anyway, the story of the Bentley drawings.... and why others often have had problems, a case in point was the Airfix 1/72 Hurricane IIC kit from about 2010, which used some awful plans, but in a respected book... sadly seems no-one at Airfix bothered to looks at the photos in the book..... I think this information was only ever published in Scale Models when the drawings were first published. HTH LSP_Kevin, Archimedes, Isar 30/07 and 4 others 7
LSP_Kevin Posted November 21, 2022 Posted November 21, 2022 3 hours ago, mozart said: And there was me planning to build the prototype……! Me too, Max! Using the old Revell kit... Kev mozart 1
mozart Posted November 21, 2022 Posted November 21, 2022 Talking of “all things Hurricane”, this has just arrived in the post: My 75th birthday present…..sooo looking forward to it! Flight of a lifetime. TorbenD, TAG, Rick Griewski and 14 others 17
Troy Smith Posted November 21, 2022 Posted November 21, 2022 4 minutes ago, LSP_Kevin said: Me too, Max! Using the old Revell kit... Kev Given the amount of hacking needed, plus all new cowl panel lines, a raised detail kit maybe a better start, as at least you don't need to fill existing panels lines! I think the basic shape is decent. Possible the old Revell has made a mistake (I'd seen a post on BM suggesting this) and made the canopy to deep, which would be right for the prototype, which has a deeper canopy, or did initially. I've not examined the kit closely, though I have the remains on one I built age 9, and another I was going to open up as teenage project... they are "somewhere" in the house..... Maybe worth looking into 1/32nd rib tape decals for the fabric wing, and some flying model maybe the source of that two blade prop, I think the original prototype one was different to the two blade unit used on initial production. Perhaps worth a thread of it's own. HTH mozart, scvrobeson and LSP_Kevin 3
geedubelyer Posted November 21, 2022 Posted November 21, 2022 20 minutes ago, mozart said: Talking of “all things Hurricane”, this has just arrived in the post: My 75th birthday present…..sooo looking forward to it! Flight of a lifetime. Wow Max, that’s brilliant What marque is the two seater? I can see a second Revell kit on the horizon converted to your ride in a similar way that Iain converted the Spitfire. Hope you get the opportunity to take loads of photos on the day. Have a fabulous time mozart and Stevepd 2
