Hey Gaz - I think you are going to pull a rabbit out of the proverbial hat, and the end product will show no evidence of the trial sand tribulations you are experiencing.   It's going to look awesome.
Thank you for the great support my fellow LSP'ers.
There is perhaps only one moment more gratifying than when your significant other admits:  "You were right."
And that, my friends is when you lift all of your masks and get absolutely ZERO paint lift.
I decided to fix the no-walk strips with masks instead of covering them up with paint.  They're not perfectly straight.  But they'll have to do.  I can change my mind later, if I want.
The off-white I chose for the Nat'l markings is too close to late war RLM 76...  but I can fix that up with weathering.
And I think the dark strip under the exhaust stubs may have extended all of the way down the wing root...   So a little more masking to do.
Hasta la Vista, Babies!
Edited by Gazzas
Comrades...   no, not in the Bolshivist sense...
I know some of you are curious as how things will go now...   a bunch of photos to give you an idea what the rivets look like immediately after sanding the rivets.  But the story of the rivets doesn't end here.  I hope to use enamels or oils to make them fit better into their environment.  You will also get a sense of how I modulate paint colors.
&*$@^#!!!  Another piece of carrier film missed until I hit it with sanding sheet.  Embarrassing.  Speaking of sanding sheet...   The most aggressive you want to use is 4000 grit.  Using 6000 or 8000 is even slower.  Water with a drop of liquid dish soap to lubricate as you sand.
Happy trails!
Hi Gary, I just finished reading through the entire thread.  You are doing a masterful job with this build and I admire your preserverence dealing with the issues that have come up during the build; and solutions/corrections that you have come up with and made.  Your 109 is looking quite good now and I am sure it will be something you can be proud of when you are finished.  I have this kit and have taken notes based on the excellent information you have given in your build thread.  Thank you!
Ernest
Man that is one impressive camo scheme.  No paint lifting - must be nice.  I have found that (as I suspected) the downside of aluminum skinning is the painting.  Even with etching primer, the specter of paint lifting is there.
