CruZz Posted June 27, 2022 Share Posted June 27, 2022 Hello, good luck. Here is my build. https://www.facebook.com/media/set/?set=a.110087347381854&type=3 Maybe as a small inspiration. Martinnfb, John1, CODY and 2 others 5 Link to comment Share on other sites More sharing options...
chrish Posted June 27, 2022 Author Share Posted June 27, 2022 17 hours ago, CruZz said: Hello, good luck. Here is my build. https://www.facebook.com/media/set/?set=a.110087347381854&type=3 Maybe as a small inspiration. That’s freakin awesome! mine will never come close! Martinnfb 1 Link to comment Share on other sites More sharing options...
chrish Posted July 1, 2022 Author Share Posted July 1, 2022 Inspired by Cruzz's link to his build, I've added a few bits of wire to the payload bays. Not to the level of detail of his but a bit more than the kit. This is mostly wire left over from the build of my house when the builder brought in "phone land lines" and glued into the model; the intakes seams seem pretty good and my other project, brought about by a failed heat exchanger in my radiator allowing coolant into the transmission fluid necessitating a rebuilding of the 4T65E in my old monte carlo...like a model but bigger, dirtier and heavier Thanks for looking LSP_Kevin, blackbetty, daveculp and 21 others 24 Link to comment Share on other sites More sharing options...
monthebiff Posted July 1, 2022 Share Posted July 1, 2022 Now that is very impressive Chris, very neat work with all of that cable work! Regards. Andy GreyGhost and Martinnfb 2 Link to comment Share on other sites More sharing options...
Alex Posted July 1, 2022 Share Posted July 1, 2022 5 minutes ago, monthebiff said: Now that is very impressive Chris, very neat work with all of that cable work! Regards. Andy Heck, the transmission is squeaky-clean too! Both are very impressive. Martinnfb and GreyGhost 2 Link to comment Share on other sites More sharing options...
Marcel111 Posted July 3, 2022 Share Posted July 3, 2022 Wow, blown away by your work on the bays! Marcel Martinnfb 1 Link to comment Share on other sites More sharing options...
Neo Posted July 3, 2022 Share Posted July 3, 2022 (edited) Great work on this one! I do have to say the intake design on this kit is smart! Having the seam in the corner vs runing down the middle of the side walls is so simple yet as been missed by most kit manufacturers!! Fun fact even the new trumpeter kit did it the old way! Edited July 3, 2022 by Neo Martinnfb and chrish 2 Link to comment Share on other sites More sharing options...
chrish Posted July 14, 2022 Author Share Posted July 14, 2022 Im back. enjoying the warm weather and tinkering on the Lightning in the evening. the intakes and engine are a very snug fit, a bit of sanding trimming was done to ease the fit. upper and lower dry fit in progress; upper and lower glued together; Thanks for looking johncrow, GMK, mgbooyv8 and 21 others 24 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted July 15, 2022 Share Posted July 15, 2022 Looking lovely so far Chris! Your work on the weapons bays is simply impressive! Got the same kit and taking notes from your build! Martinnfb and chrish 2 Link to comment Share on other sites More sharing options...
chrish Posted July 21, 2022 Author Share Posted July 21, 2022 a splash of color, a sheet of white plastic is seen at the top with some trial sample colors till I found something I liked; Thanks for looking LSP_Kevin, Alex, Fanes and 15 others 18 Link to comment Share on other sites More sharing options...
themongoose Posted July 21, 2022 Share Posted July 21, 2022 Dang I remember how much work it was to mask all that. Yours is looking really sharp man you ought to be ecstatic about this Martinnfb and chrish 1 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted July 27, 2022 Share Posted July 27, 2022 Very impressive work, the colours seem to change quite a bit depending on the light on the real aircraft, when I come to build mine, I'm also going with what looks right. Link to comment Share on other sites More sharing options...
chrish Posted July 30, 2022 Author Share Posted July 30, 2022 Another model off the bench. Canadian (false so far) markings used, just for fun. Calling this one finished,the canopy is only set in place, not glued down as yet. Thanks for looking Rockie Yarwood, GMK, LSP_Kevin and 11 others 14 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2022 Share Posted July 30, 2022 Nicely done, Chris! Kev Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted July 31, 2022 Share Posted July 31, 2022 Looks great! Link to comment Share on other sites More sharing options...
