Brett M Posted August 25, 2022 Share Posted August 25, 2022 Wow. Impressive, and beautiful, work! Thanks for sharing the steps. airscale 1 Link to comment Share on other sites More sharing options...
brahman104 Posted August 25, 2022 Share Posted August 25, 2022 Fantastic update as always Peter! I'm just about to do the fillets on the tail of the B-17, so your post is a timely dose of inspiration/motivation for me! Cheers, Craig airscale 1 Link to comment Share on other sites More sharing options...
easixpedro Posted August 25, 2022 Share Posted August 25, 2022 I'm out of superlatives Peter. Excellent tutorial as always. Appreciate you taking the time to show us how it's done. What I love about this place - people taking the time to share so we're all learning. What does impress me is how much you've improved the process since the earlier builds. Makes me think you need to try a NMF monster like the B-17 or Liberator. Or maybe a B-25, but something that has enough data for the amount of detail you can produce. Easy for me to say and recommend of course, I'm not building it! -Peter airscale and zaxos345 2 Link to comment Share on other sites More sharing options...
zaxos345 Posted August 25, 2022 Share Posted August 25, 2022 20 hours ago, chuck540z3 said: A few thoughts: Your progressive pics really tell the story of how you accomplished such a nice final product. This stuff isn't easy I think a lot of us would have bailed after seeing the first few pics of the aluminum skin, which looks very stressed and messy Your experience with same kept you at it, with wonderful results I think your fillets look better than the real deal! Cheers, Chuck Totally agree with my friend Chuck!! The best way to express my feelings!!! John airscale 1 Link to comment Share on other sites More sharing options...
KiwiZac Posted August 25, 2022 Share Posted August 25, 2022 On 8/25/2022 at 10:28 AM, airscale said: ...enjoyed that Me too!! airscale 1 Link to comment Share on other sites More sharing options...
Nighthawk Calling 1 Posted August 26, 2022 Share Posted August 26, 2022 Impressive work on the tail fillet, she is starting to look the business now she is getting her skin. Will she make it to Telford this year or will it be next year. airscale 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 26, 2022 Share Posted August 26, 2022 Lovely, lovely stuff Peter. IainM and airscale 2 Link to comment Share on other sites More sharing options...
airscale Posted August 28, 2022 Author Share Posted August 28, 2022 evening ladies On 8/25/2022 at 2:16 AM, JayW said: And thanks for that good explanation for the fillets. Peter they look...well, perfect. It won't be all that long where I will take a shot at the equivalent parts on the F4U. I am curious - you say you hate painting. What is the paint job on this one? Hi Jay - as little as possible! it's a pre-war NMF with old style USAAC markings and a nice striped rudder... ..I just can't bring myself to paint them.. (yet...) On 8/26/2022 at 2:27 AM, Nighthawk Calling 1 said: Impressive work on the tail fillet, she is starting to look the business now she is getting her skin. Will she make it to Telford this year or will it be next year. Hi Nighthawk - thank you it will be at Telford I expect - on the LSP stand as a WIP - will be putting the P51C in the comp and this one probably the year after.. so, to skin the nose area the anchorpoint is the exhaust panels so these absoloutely need to be in the right spot. I had made a PE panel for the stainless steeel panel that surrounds the exhaust outlets and used it to mark out the correct position of the aperture. I had made one earlier but it turned out it was in the wrong spot so I just filled in the hole and did it again.. ..the panel is taped down and the corresponding one on the other side put in exacty the same position.. ..the panel outline was scored so I could position it later... ..the exhaust pipes were made up from brass tube and filler to make a master to cast copies in resin - the actual outlet is an oval so it was compressed with pliers.. ..and as each side is different (they curve upwards on the V1710) two had to be made ..and with refining two masters were finished and put in rubber.. ..casting 12... ..the ports themselves were ground out with a dremel so the pipes are more hollowed and deeper and the whole lot primed.. ..used the panel positions to fix the exhausts after a base paint coat.. ..added the small rods between each one - there is a metal fairing in here too on the real one, but so little can be seen I skipped it... ..and then fixed the panels in position.. ..now that is done I can start on the nose area..:) TTFN Peter Out2gtcha, Antonio Argudo, Derek B and 27 others 30 Link to comment Share on other sites More sharing options...
scvrobeson Posted August 28, 2022 Share Posted August 28, 2022 I don't know how you do it, but you find new ways to top yourself with each build. Just stunning craftsmanship Matt airscale 1 Link to comment Share on other sites More sharing options...
brahman104 Posted August 28, 2022 Share Posted August 28, 2022 And just when you thought that old school methods were dead! Great to see the casting work Peter! I assume you considered a 3D print as well, but went with casting instead? They came out very nice indeed! Craig airscale 1 Link to comment Share on other sites More sharing options...
monthebiff Posted August 28, 2022 Share Posted August 28, 2022 Absolutely stunning work as ever Peter, and here she is sat quietly in the hanger last night not taking part in the Duxford evening airshow which was spectacular! and a few pictures of the P-36 for you Peter as they pulled her back in between the crowds close to the end of the show The sun was going down as she looked spectacular! Looking forward to more of your superb P-40 but just in case you were thinking of a future project Regards. Andy scvrobeson, Brett M, MikeMaben and 10 others 12 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 28, 2022 Share Posted August 28, 2022 Superbulous! Kev IainM and airscale 2 Link to comment Share on other sites More sharing options...
Paulpk Posted August 29, 2022 Share Posted August 29, 2022 Peter, Really great work! Thanks for sharing your techniques. I am familiar with the litho sheet process but it still amazes me the burnishing process works so well. You have sparked an interest in trying this technique, just need to clear a few projects off the desk. Is 1/32 too small a scale for this litho process in your opinion? regards, Paul IainM and airscale 2 Link to comment Share on other sites More sharing options...
IainM Posted August 29, 2022 Share Posted August 29, 2022 Absolutely superb! Loving your techniques Peter...and the execution! airscale 1 Link to comment Share on other sites More sharing options...
SwissFighters Posted August 30, 2022 Share Posted August 30, 2022 (edited) Love the work Peter. It is delightful and a constant source of inspiration. One small detail: Is it my imagination or is there a bigger gap between the third and fourth stack on the starboard side than between the others? That might be completely scale, but I don't see quite the same gaps on the port side. Just that you mentioned fixing the exhausts in place. Thanks for receiving 'our' comments and queries with such grace, as most modellers do on this forum. A lot of heart and soul is exposed in sharing builds and its no small thing to invite feedback! EDIT: I found some time to follow up and found this side view of the Allison V-1710-C, which I think is the correct engine for the earlier P-40s. It does show a slightly bigger gap between third and fourth exhaust stacks. This is the V-1710-F, which powered most P-40s (according to Wikipedia). It appears to use the same cylinder blocks/heads and also displays a larger gap. Anyway, I hope I haven't caused too much stress, Peter. It was a detail which I couldn't explain without some evidence and even then I wonder why the engine was designed like that. I haven't found any clear images of whether the exhaust stacks in any way compensate for that gap but suspect they don't. In other words, as you were! Edited August 30, 2022 by SwissFighters GMK, BiggTim, airscale and 2 others 5 Link to comment Share on other sites More sharing options...
