MikeC 3,258 Posted June 8, 2020 Share Posted June 8, 2020 I'm just coming to the end of a Tamiya P-51D build (sorry I didn't do a WIP, but I'll try to do an RFI in due course), and I wondered how other people get on with the "working" features on the 1/32 Tamiya kits in general. I found on the Spitfire Mk IX that I had great trouble fitting the ailerons using the prescribed method, so I simply cemented them and the other control surfaces, as I did with the P-51D. The flaps on the latter I left working, as it made for easier handling during building and painting. I left the cowls removable, although the fit of the bottom one was not great, and it's very difficult to get off anyway, so that's staying in place. As I'll never change from undercarriage down to up, I've fixed all the relevant bits, as I have the radiator flaps. My next Mustang will have the cowlings fixed as well, as to leave them off may prove challenging for painting and decalling the nose - I'm planning a 356th FG bird for that one. That will also save time as I can do a minimal build of the engine and its bay, just enough to ensure structural integrity. So as you may have gathered, I'm really not that interested in having "working" features which in my grumpier moments I have been known to describe as "toy-like". But am I alone in this, in the majority, or what? What do those of you who have built one, or are contemplating it, think? In fact, what's your take on working features on LSPs in general? Annnd ..... Go. scvrobeson, coogrfan, Lothar and 3 others 6 Link to post Share on other sites
Lee White 3,114 Posted June 8, 2020 Share Posted June 8, 2020 Sliding canopies and movable propellers is about as far as I'll go with moving features. discus, Rick Griewski, MikeC and 4 others 7 Link to post Share on other sites
Stokey Pete 1,155 Posted June 8, 2020 Share Posted June 8, 2020 Unless I can use them to accentuate a particular pose, they get fixed in their neutral position. Rick Griewski, phasephantomphixer and MikeC 3 Link to post Share on other sites
wunwinglow 5,647 Posted June 8, 2020 Share Posted June 8, 2020 Fixed. Except the prop, because however many notices you put up at displays not to touch the model, someone invariably gives a prop a flick.... Ha. Like I ever finish my models anyway!! Lothar, Rick Griewski, MikeC and 1 other 4 Link to post Share on other sites
DonH 1,720 Posted June 8, 2020 Share Posted June 8, 2020 Everything fixed. Even the prop. I only build for me, so no one is ever going to flick my prop or wiggle my ailerons. Phartycr0c, Lothar, MikeC and 2 others 4 1 Link to post Share on other sites
BaldEagle 55 Posted June 8, 2020 Share Posted June 8, 2020 Only when it enables a number of different poses for the model. I like people to see the hard work detailing the engine. However, I can't stand loose control surfaces flapping about though, so they're glued on. The problem with plastic working parts is that they end up coming off! phasephantomphixer, MikeC and Rick Griewski 3 Link to post Share on other sites
Tony T 5,450 Posted June 8, 2020 Share Posted June 8, 2020 Fixed mostly, except propellers which must turn, otherwise they remind me of badly built kits from my youth, and wheels if possible but not a deal-breaker. Would love to replace the plastic flattened tyres on my Tamiya Mossie for turning vinyl rubber which squish au naturel. For that reason I bought a Tamiya Type 21 Zero to convert to a Suisen II floatplane ("look mum, no wheels") and a Hasegawa Type 52 to build with legs. Jets; well, there isn't one that doesn't have turning vinyl rubber tyred wheels, the F-15 inlets can bow IIRC, and the F-4's all-moving stabilator does its thing. All features I like very much. On jets I'd really like more build options, especially retracted or dropped flaps the way manufacturers habitually do with airbrakes. Tony phasephantomphixer, scvrobeson and MikeC 3 Link to post Share on other sites
Sepp 465 Posted June 8, 2020 Share Posted June 8, 2020 I'll use the provided hinges as attachments, but everything gets fixed in a set pose - yes, even the prop. Lothar and MikeC 2 Link to post Share on other sites
Tony T 5,450 Posted June 8, 2020 Share Posted June 8, 2020 11 minutes ago, Sepp said: I'll use the provided hinges as attachments, but everything gets fixed in a set pose - yes, even the prop. Is that to "de-toy" it so youngsters find it boring? I like to alter a display — move the props a few degrees left or right — but it does make the more attractive to little fingers. Tony MikeC 1 Link to post Share on other sites
Daywalker 778 Posted June 8, 2020 Share Posted June 8, 2020 I also fixed MOST of the working features on my Tamiya builds save the movable propellers. Ailerons, flaps, cowl panels - all of them fixed on the A6M, Spitfire, and Mustang. DOn't remember any working features on the F4U. MikeC 1 Link to post Share on other sites
cbk57 1,553 Posted June 8, 2020 Share Posted June 8, 2020 My least favorite working feature on a tamiya lsp was the working landing gear on the Zero. I do not love that but worked with it. As to the others I have managed. I really like the removable cowlings. I have not had a problem with those. On the mustang the lower piece, I use a dab of lithium grease on the grommet so it can be smoothly removed. As fat as painting the cowlings and gun bay covers. The gun bay covers i use a couple drops of micro crystal clear just to tack them down so I can paint. Cowling is more complicated but as it uses magnets and the spinner to lock them in place, I use those bits and tape down the spinner to hold it all together. Then I can do my bare metal paint work. Finally I can tape it up for anything like the blue nose and mask it all as one paint piece. As for control surfaces. I have managed fine assembling them but I agree with those that think they are a waste of time haveing them moveable. The Corsair had a better solution in my opinion. Also I found getting the Spitifres landing gear mounted in the down position a real beast and would never want to take them out once installed personally. MikeC and phasephantomphixer 2 Link to post Share on other sites
Sepp 465 Posted June 8, 2020 Share Posted June 8, 2020 (edited) 2 hours ago, Tony T said: Is that to "de-toy" it so youngsters find it boring? I like to alter a display — move the props a few degrees left or right — but it does make the more attractive to little fingers. Tony Nope, no little fingers in my house any more. MY "little one" is now a hulking great 6ft+ copper, lol. I should, pehaps, temper my first post by saying that I like the surfaces to be moveable so there's a choice of pose but once the pose is struck, it stays put. I simply don't see the point in replacable landing gear, but chacun à son goût! Edited June 8, 2020 by Sepp MikeC 1 Link to post Share on other sites
John1 3,932 Posted June 8, 2020 Share Posted June 8, 2020 The Mustang was my least favorite of all the newer Tamiya kits. Working landing gear.... really guys??? I eliminated all the hinges and glued everything in place, minus a single cowling part that I wanted to leave off to display the motor. Thankfully, their later kits have moved away from these "features". MikeC and phasephantomphixer 2 Link to post Share on other sites
LSP_K2 25,003 Posted June 8, 2020 Share Posted June 8, 2020 I've yet to tackle even a single 1:32 Tamiya kit, but when I do, I'll fix everything in place. I'm never going to "play" with it, so no need for gimmicky working parts. MikeC, MikeMaben, Rick Griewski and 1 other 4 Link to post Share on other sites
Jennings Heilig 15,126 Posted June 8, 2020 Share Posted June 8, 2020 6 hours ago, DonH said: I only build for me, so no one is ever going to flick my prop or wiggle my ailerons. I’ve been trying for years to find someone to wiggle my ailerons... AlbertD, MikeC, Ben Brown and 1 other 1 3 Link to post Share on other sites
