Dave Williams Posted September 29, 2018 Share Posted September 29, 2018 It looks like they are using a short beam to lower the center two bombs to get enough clearance for four bombs in a row. Looking at the photos, it doesn’t seem that four would fit if they were all at the same height. alanash1963 1 Link to comment Share on other sites More sharing options...
Lancman Posted September 30, 2018 Share Posted September 30, 2018 It's the same as the Tamiya kit, as you say you won't get 4 x 500lb bombs in a row. You might be able to get 2 x 500's in the middle with 250lb either side as in the bottom pic 2nd row but again the 500's could be slightly lower. Graham alanash1963 1 Link to comment Share on other sites More sharing options...
PhilB Posted September 30, 2018 Share Posted September 30, 2018 All of the above, plus this is a test shot. I'm sure HK with all the research will have thought of this. Jan_G and alanash1963 2 Link to comment Share on other sites More sharing options...
LSP_Mike Posted September 30, 2018 Share Posted September 30, 2018 Good catch Graham. a wee bit of shim stock ought to make all right with the world. alanash1963 and scvrobeson 2 Link to comment Share on other sites More sharing options...
ScottsGT Posted September 30, 2018 Share Posted September 30, 2018 Any updates on release date? alanash1963 1 Link to comment Share on other sites More sharing options...
Chek Posted September 30, 2018 Share Posted September 30, 2018 (edited) On 9/29/2018 at 1:25 AM, Out2gtcha said: Extremely brittle most times. As I understand it, that's polystyrene in its natural form. Adding colour dyes also allows plasticisers to be added, giving the more-or-less flexible varieties of PS we see in the majority of kits. Odd that the HKM display model has both the early type fuselage windows and the starboard heater fairing aft of the wing. I had thought that a much later addition. Edited September 30, 2018 by Chek speeling mozart and GusM 2 Link to comment Share on other sites More sharing options...
Phartycr0c Posted September 30, 2018 Author Share Posted September 30, 2018 2 hours ago, ScottsGT said: Any updates on release date? This month, By all accounts is all ready to hit the shelves Link to comment Share on other sites More sharing options...
D.B. Andrus Posted September 30, 2018 Share Posted September 30, 2018 Each sub-assembly is like a kit in itself. Really amazing. Cheers, D.B. Link to comment Share on other sites More sharing options...
mozart Posted September 30, 2018 Share Posted September 30, 2018 (edited) 2 hours ago, Chek said: Odd that the HKM display model has both the early type fuselage windows and the starboard heater fairing aft of the wing. I had thought that a much later addition. You're right there Chek, the starboard heater was a later, perhaps even nearly post-war addition, so no place on a Mk I at least. There's another starboard "tube" exiting the fuselage on the most recent shots that I can't explain. Edited September 30, 2018 by mozart Link to comment Share on other sites More sharing options...
John1 Posted September 30, 2018 Share Posted September 30, 2018 22 minutes ago, mozart said: You're right there Chek, the starboard heater was a later, perhaps even nearly post-war addition, so no place on a Mk I at least. There's another starboard "tube" exiting the fuselage on the most recent shots that I can't explain. Tube for “window” packets? Phartycr0c and alanash1963 2 Link to comment Share on other sites More sharing options...
mozart Posted September 30, 2018 Share Posted September 30, 2018 (edited) No, a bit of research reveals it's the fairlead of one of the positions used for the trailing aerial, on other Lancs it's further forward on the port side, this is George in the AWM. I've just found a picture of a Mk I with it in this position. Kudos to HK! Edited September 30, 2018 by mozart Phartycr0c 1 Link to comment Share on other sites More sharing options...
Lancman Posted September 30, 2018 Share Posted September 30, 2018 I remembered this great wee film and talking of bombloads a few posts back check out around the 15 minute mark, the 2 bombs in the middle are on a shared rack and check out how they get the last bomb in!!!! I also think it's quite funny how the armourer carefully removes pins from the cookie fuses and it's like he's expecting something as he goes along. Graham Phartycr0c and Jan_G 2 Link to comment Share on other sites More sharing options...
scvrobeson Posted September 30, 2018 Share Posted September 30, 2018 I'd definitely buy a few nose sections if they release just that. Definitely don't have room for a full-size Lanc, but 2 or 3 nose sections with different nose art would look fantastic, and would give a chance to show off all of the interior detail Matt Uncarina, Southern Bandit and Phartycr0c 3 Link to comment Share on other sites More sharing options...
Cees Broere Posted October 1, 2018 Share Posted October 1, 2018 The reason the two middle bombs are lower is that the Lancaster has three bombstations next to each other. On the middle station they used a twin bomb carrier that could use the existing single pick up point but could be fitted with two bombs. Cees Jan_G and Phartycr0c 2 Link to comment Share on other sites More sharing options...
Finn Posted October 1, 2018 Share Posted October 1, 2018 10 hours ago, Cees Broere said: The reason the two middle bombs are lower is that the Lancaster has three bombstations next to each other. On the middle station they used a twin bomb carrier that could use the existing single pick up point but could be fitted with two bombs. Cees True but then there is this pic: the middle SBCs don't look to be that much lower than the outside ones. Jari Jan_G and alanash1963 2 Link to comment Share on other sites More sharing options...
