Finn
LSP_Members
  • Posts
    1,534
  • Joined
  • Last visited
Everything posted by Finn
  1. Maybe the answer can be found here: https://www.docdroid.com/d3D4wyb/convair-b-36-peacemaker-flight-operating-instructions-pdf Jari
  2. This view shows where the LAU-7 launcher was installed on the inboard pylon, the top of the pylon sway braces adding spacing for the TER and bombs: Jari
  3. Looks like the Russians are using tires to protect their a/c from Ukrainian attacks: https://www.thedrive.com/the-war-zone/russian-su-34-strike-fighter-seen-covered-in-tires Jari
  4. Here are the instructions on Scalemate: https://www.scalemates.com/products/img/0/9/1/1480091-12-instructions.pdf the unit markings have been crossed out. Jari
  5. The Trumpeter site has the shorter version of the decal sheet: http://www.trumpeter-china.com/index.php?g=home&m=product&a=show&id=3924&l=en while Hobby Search has the longer one: https://www.1999.co.jp/eng/image/10995499 maybe one was the early release, i guess we'll find out when we get one and open the box. Jari
  6. Nice look at both kits, however i have seen this decal sheet: shown on some model sites. Jari
  7. Hi Peter, here are some nice photos of them being built at the CCF factory in Fort William Ont (now Thunder Bay, my home town): https://canavbooks.wordpress.com/2019/11/12/canadian-car-foundry-and-the-curtiss-sbw-helldiver/ click on any of the images for larger versions. Jari
  8. Here is Ruhr Express and you can clearly see it has it: Jari
  9. Here is one with Ostketten: which you can 3D print: https://www.thingiverse.com/thing:2788343 Jari
  10. A view from the rear: https://www.iwm.org.uk/collections/item/object/205126703 Jari
  11. Looking good, in case you want to add a bit of colour to the engines: https://www.iwm.org.uk/collections/item/object/205188205 https://www.iwm.org.uk/collections/item/object/205188203 Jari
  12. Some Korean War Navy ones: the brackets on the side were for toe bars: Jari
  13. A 1/32 Y-Wing and TIE Bomber would be nice as well. Jari
  14. With more 3D printed interest of late, here is a video that maybe be of use: Jari
  15. Thanks Dana, i kind of figured it had something to do with covering things up. Reminds me when i was stationed in West Germany, they said we should not have any white on our ball caps lest a MiG flying at 500kts at 200ft would see it and attack the base, not seeing all the green buildings, the long concrete runway, taxiways and dispersals. Jari
  16. Why would they have tarps on the wings: https://artsandculture.google.com/asset/aircraft-carrier-hornet/TAHTP750hbdMAw no doubt they would be removed before flight. edit: here is another photo that have rudder covers on them to make them less colourful on the deck: https://artsandculture.google.com/asset/aircraft-carrier-hornet/9QHRucFM-lleig Jari
  17. Kev, hope the next print comes out within acceptable limits. If not perhaps try to print the outer wing sections as separate parts, that way it may make it easier for the machine to print the main centre wing section. Jari
  18. Here is an image that may be helpful: https://www.iwm.org.uk/collections/item/object/205123899 Jari
  19. A series of 8 videos showing a damaged Lancaster being recovered and being put back into service: https://www.iwm.org.uk/collections/item/object/1060042869 Jari
  20. Craig here is a video of a Lancaster squadron at RAF Scampton in 1942 which might be of help: https://www.iwm.org.uk/collections/item/object/1060021063 Jari
  21. Watch the rocket pod on the one lifting off: the nose of the pod angles up just after lift off. Why, i don't know. Jari
  22. How about 2 of them in flight: https://www.militaryfactory.com/aircraft/imgs/lrg/sikorsky-ch54-skycrane_9.jpg Jari
  23. Check here: https://www.416th.com/missions/combat_missions.html select one of the missions and you'll get crew names, 4 for the glass nose and 3 for the G. Jari
