Ryan
LSP_Members
  • Posts
    1,492
  • Joined
  • Last visited
  • Days Won
    7
Posts posted by Ryan
  1. 6 minutes ago, Zola25 said:
    Somebody just bought a 3D scanner.. ;)
    But I like the idea and I considered something similar myself but for the upcoming Jetmads Draken kit. I really want the Recce nose so I was thinking to scan the 1/48 Hasegawa nose and print it in 1/32. Its still a pretty big investment in equipment to get started with that so I am following your Super Hornet build closely to see if it is worth it
    Niels
    You would actually scan both to know what the profile of the JM kit will be at the cut point. You have seen the scans in my build, they wont be crystal clear but it will give you the data for the CAD work. You won't be able to scan the 48th nose scale and print it.
  2. 14 minutes ago, ScottsGT said:
    And ScottsGT slides the A-10 kits back into the stash…..
    Please, please, please…..DO IT!
    If I remember correctly Paul Fisher was working on this when the fire hit.
    I’m good for two if you do.  Maybe one with missle detectors, one without?
    The thing to do would be to scan the monogram kit and then enlarge and tweak to fit the Trumpeter unit. I think the blend could just be forward of the canopy or start with the fueling door rectangle and then just the area ahead of it. Hmmmm.
  3. GE 414 Compressor face.
    This is the front support; the fan blades will be in a separate part behind this to make painting easier. The assembly shown must be a complicated affair in real life, it looks like the metal behind the diverter vanes are blade shutters that open and close depending on airspeed, Mach number etc. I left the shutters half open to show the compressor face. (Not drawn yet.)
  4. Nice update today, I was able to print a small test section of the seamless intake and it came out pretty good. There is only a very slight encroachment into the intake which is just fine. The production prints will be in white and any small swipe with a sanding stick will be invisible, the resin sands quite easily so I will be able to true up the mouth to the tunnel.
    On to the pics, note that these are held in place with blue tack and trying to photograph it was a challenge while not upsetting the join.Y8w3B09.jpg
  5. Moving away from the perfect CAD world I did cut up some parts and assembled the wings in the unfolded configuration....spoiler alert the kit prefers the folded option!
    The fit is butt joint at best, so I crammed some scrap styrene styrene to improve the fit. I also cleaned up one of of the intake tunnels and capped off the ends. A closed part will help with scanning as the machine has trouble seeing into holes. The purple scan above was a open trunk and it was not the greatest scan.
    Ryan
  6. Another area of improvement is the seamed intake...yuk. If I can recreate the trunk and print in white resin then hooray, no seams and its already white. :)
    I ran a scan of the intake tube and modeled a simple replacement part. The rough elephants trunk is the scanned part and the shiny portion is the CAD model peaking through the mesh. Ideally you would want to have more of the CAD model closer to the mesh surface.
    It was late and I wanted a nicer scan but this illustrates the process. You can even see the tape I used to hold it together while I scanned. :)
