mozart Posted November 15, 2022 Share Posted November 15, 2022 Is it really likely/feasible that this new company, “fledged” from Wingnut Wings with all the superlatives that we know apply to that company, are going to produce a kit which is anything less than as perfect as it’s possible to be for their first offering? Paul in Napier, Pete Roberts, coogrfan and 1 other 4 Link to comment Share on other sites More sharing options...
thierry laurent Posted November 15, 2022 Share Posted November 15, 2022 It took me months and a huge amount of documentation to find the correct features for my Spit Mk.I and the Kotare kit ones I saw are identical. They incorporated features never seen on other early Spit kits. So, with regard to accuracy I can testify they did the job more than correctly. I'm also convinced the assembly will be perfect and the finish of the parts without a single default. Keep in mind these guys did the WnW test shot quality control for ten years! So, they know this job. I'm convinced this kit will be a terrific one. The only thing that is worrying me a little bit is the price of a model produced on the other side of the globe but I guess high prices are a sign of the times and we will probably have to live with that. mozart, cbk57, coogrfan and 7 others 8 2 Link to comment Share on other sites More sharing options...
cbk57 Posted November 15, 2022 Share Posted November 15, 2022 22 minutes ago, thierry laurent said: It took me months and a huge amount of documentation to find the correct features for my Spit Mk.I and the Kotare kit features I saw are identical. They incorporated features never seen on other early Spit kits. So, with regard to accuracy I can testify they did the job more than correctly. I'm also convinced the assembly will be perfect and the finish of the parts without a single default. Keep in mind these guys did the WnW test shot quality control for ten years! So, they know this job. I'm convinced this kit will be a terrific one. The only thing that is worrying me a little bit is the price of a model produced on the other side of the globe but I guess high prices are a sign of the times and we will probably have to live with that. I can:t believe people are even debating this and trying to put down the likely quality of Kotare before the 1st kit hits the market. Maybe none of it will fit together and the whole thing when you put it together will be upside down and filled with filler but I strongly doubt that. It is a little early to judge and normally I would say that it is too early either way but we know the track record of the crew on this project and my expectations are that this will set the bar for the Early Spitfire. I will still give Tamiya the win for the Mk IX even if Kotare does one assuming Kotare does not do an engine but Kotare is going to be superior in most regards to Tamiya when this kit drops. mozart, Pete Roberts and Paul in Napier 3 Link to comment Share on other sites More sharing options...
Pete Roberts Posted November 15, 2022 Share Posted November 15, 2022 58 minutes ago, cbk57 said: I can:t believe people are even debating this and trying to put down the likely quality of Kotare before the 1st kit hits the market. Maybe none of it will fit together and the whole thing when you put it together will be upside down and filled with filler but I strongly doubt that. It is a little early to judge and normally I would say that it is too early either way but we know the track record of the crew on this project and my expectations are that this will set the bar for the Early Spitfire. I will still give Tamiya the win for the Mk IX even if Kotare does one assuming Kotare does not do an engine but Kotare is going to be superior in most regards to Tamiya when this kit drops. I agree Paul in Napier 1 Link to comment Share on other sites More sharing options...
npb748r Posted November 15, 2022 Share Posted November 15, 2022 1 hour ago, cbk57 said: I can:t believe people are even debating this and trying to put down the likely quality of Kotare before the 1st kit hits the market. Maybe none of it will fit together and the whole thing when you put it together will be upside down and filled with filler but I strongly doubt that. It is a little early to judge and normally I would say that it is too early either way but we know the track record of the crew on this project and my expectations are that this will set the bar for the Early Spitfire. I will still give Tamiya the win for the Mk IX even if Kotare does one assuming Kotare does not do an engine but Kotare is going to be superior in most regards to Tamiya when this kit drops. I think there are only 2 of us who have raise a question on the kit seen in in the pictures and in the flesh at the weekend which has now been explained is a mock up and not the real kit. The comments relate to this mock up and are a reality, the fit is awful on the rear fuselage, even the designer said it's not right. It was just an observation of what was posted. Paul in Napier, John1 and nmayhew 3 Link to comment Share on other sites More sharing options...
rjones726 Posted November 17, 2022 Share Posted November 17, 2022 (edited) Here's a link to a preliminary copy of the Kotare Spitfire instructions. They're exactly what I was hoping for considering the makeup of the development team. https://www.1999.co.jp/eng/image/10934948 Edited November 17, 2022 by rjones726 Kagemusha, D.B. Andrus, LSP_K2 and 11 others 4 10 Link to comment Share on other sites More sharing options...
geedubelyer Posted November 17, 2022 Share Posted November 17, 2022 Thanks for the link @rjones726 The detail in the cockpit area is immense. If anyone has seen a WNW instruction pamphlet it's easy to spot the heritage of this model kitset from the similar style of the instructions. Very comprehensive. Uncarina, MikeC, mozart and 2 others 5 Link to comment Share on other sites More sharing options...
MikeC Posted November 17, 2022 Share Posted November 17, 2022 46 minutes ago, geedubelyer said: Thanks for the link @rjones726 The detail in the cockpit area is immense. If anyone has seen a WNW instruction pamphlet it's easy to spot the heritage of this model kitset from the similar style of the instructions. Very comprehensive. Absolutely. Can't wait for my Hannants pre-order to arrive, this looks like a "clear-the-bench" kit. mozart, Paul in Napier, Uncarina and 1 other 4 Link to comment Share on other sites More sharing options...
Dennis7423 Posted November 17, 2022 Share Posted November 17, 2022 The comments in the instructions about the Port wingtip lights are interesting. Look at the decal diagrams to see what I'm talking about. - Dennis S. Mount Juliet, TN USA Uncarina and Paul in Napier 2 Link to comment Share on other sites More sharing options...
John Stambaugh Posted November 17, 2022 Author Share Posted November 17, 2022 Yippie, another outstanding kit release! Recently I had come to think that the LSP revival was coming to a close. So nice to be wrong. So let's see; we have so far this year all new molds: ICM Yak 9 Zoukei mura 109 G14. Revell's G2. Soon to rereleased: Revell Hurricane mk 2B Italeri Macchi 202 Kotare Spitfire mk 1 Who am I forgetting? Oh yes, the biggest of them all: The Airfix Spitfire mk IXc. Politics aside, 2022 has been a great year. May we all buy at least one of each. geedubelyer, Uncarina, Alain Gadbois and 5 others 8 Link to comment Share on other sites More sharing options...
npb748r Posted November 17, 2022 Share Posted November 17, 2022 2 hours ago, rjones726 said: Here's a link to a preliminary copy of the Kotare Spitfire instructions. They're exactly what I was hoping for considering the makeup of the development team. https://www.1999.co.jp/eng/image/10934948 thanks for posting. I really like the fact that the instructions include details of what the items are, that makes it much more interesting for me. Uncarina and John Stambaugh 1 1 Link to comment Share on other sites More sharing options...
Uncarina Posted November 18, 2022 Share Posted November 18, 2022 I’m all over this one! I’ve read that instruction manual at least three times. Cheers, Tom Dennis7423 and geedubelyer 2 Link to comment Share on other sites More sharing options...
Gazzas Posted November 18, 2022 Share Posted November 18, 2022 2 minutes ago, Uncarina said: I’m all over this one! I’ve read that instruction manual at least three times. Cheers, Tom I’d better look at it carefully then. The last spitfire instruction manual I read was written by Monogram. John Stambaugh, Pete Roberts, Uncarina and 2 others 2 3 Link to comment Share on other sites More sharing options...
Uncarina Posted November 18, 2022 Share Posted November 18, 2022 9 hours ago, Dennis7423 said: The comments in the instructions about the Port wingtip lights are interesting. Look at the decal diagrams to see what I'm talking about. - Dennis S. Mount Juliet, TN USA Be sure to drink some port first! Cheers, Tom Dennis7423 and europapete 1 1 Link to comment Share on other sites More sharing options...
Pete Roberts Posted November 18, 2022 Share Posted November 18, 2022 11 hours ago, Dennis7423 said: The comments in the instructions about the Port wingtip lights are interesting. Look at the decal diagrams to see what I'm talking about. - Dennis S. Mount Juliet, TN USA Nice way to remember which is which. Dennis7423 1 Link to comment Share on other sites More sharing options...
