Marcel111 Posted July 23, 2020 Author Share Posted July 23, 2020 (edited) Hi guys, here are a few I Phone pics to prove that this build is alive and well. I have run into a few challenges but am really enjoying the kit. This part of the CWS cockpit fit is ok... needs quite a bit of filling and sanding but that's no problem on this section. The LERX extension as it is right now. I must say I thought this would be a lot easier than it is turning out to be, getting the right contour seems to be almost impossible. I am using the Zacto exhausts which are incredible. My approach to replicating the various shades of silver, gold, violet and blue on the exhausts was to spray a color and then mask off some sections and spots with liquid mask... note that the color transitions are hard so I am not keen on a soft-edges, airbrushed transition. Incidentally, this product worked really well: Before starting to remove the liquid mask, things looked quite promising: However, I then struggled to remove the liquid mask and when I did it left a slight ridge. So back to the drawing board, fortunately Christ (Zacto) sent me some replacement outer exhaust sections so that I can easily start over without losing too much time and exhaust detail. Cheers, Marcel Edited July 23, 2020 by Marcel111 Squizzy 78, LSP_Kevin, Rockie Yarwood and 15 others 18 Link to comment Share on other sites More sharing options...
seiran01 Posted July 24, 2020 Share Posted July 24, 2020 This is looking great so far! I bought the masks from Jim for this plane and several others two weeks back. Didn't realize he'd done this scheme at your request, so thanks for that Marcel111 1 Link to comment Share on other sites More sharing options...
dsahling1 Posted July 24, 2020 Share Posted July 24, 2020 First, really cool subject, its about time someone did a 1/32 MiG-29 here. In regard to the problem of the LERX, I have an idea. I encountered a somewhat similar issue with 'Projekt Flanker' (A large Kilp Yavr Russian Air base diorama, with (3) 1/32 Su-27 Flankers (loaded with all the aftermarket), (1) 1/35 Mi-8 Hip, and various ground vehicles, equipment, tarmac, a little terrain that I will try to add my first WIP entry here this weekend, its been well underway for a while now and I have 2 of the Su-27s almost ready to prime, I have to go back and add rivet and panel line detail to one I started painting so its like the other two, to make them look uniform and realistic) anyhow, sorry I digressed there for a moment. Please see below for my idea. You see, the kit leading edge slats of the Su-27s lack the little 'bulged' 'extensions' near the wing root so I mixed some superfine white milliput (finer grain white allows better sanding) and made a little larger VERY rough shape of the extension (it aligns with a panel line so its a little easier getting the position and shape right) and then I drew in pencil where I wanted the leading edge of the new bulge to be, to aid in sanding it uniformly on both sides. I then VERY slowly began sanding it down to shape until it seamlessly blended with the slat. You could try taking some milliput and apply it larger than you'd need as a long 'snake' and put it there for where the LERX extension shims are and then sand it to the shape you want, the stuff dries ROCK hard (think like CA glue does). Or you could cut little 'bulkheads' that would outline the cross-section of the shape you need and attach those to the kit and then add the milliput. The bulkheads would act as a guide for how to sand it. In case you weren't aware Zactoman has some really great 1/32 MiG-29 stuff for the NEW trumpeter mig-29s you might want to check out. Marcel111 and Smokey 2 Link to comment Share on other sites More sharing options...
Marcel111 Posted August 28, 2020 Author Share Posted August 28, 2020 (edited) On 7/24/2020 at 6:19 AM, dsahling1 said: First, really cool subject, its about time someone did a 1/32 MiG-29 here. In regard to the problem of the LERX, I have an idea. I encountered a somewhat similar issue with 'Projekt Flanker' (A large Kilp Yavr Russian Air base diorama, with (3) 1/32 Su-27 Flankers (loaded with all the aftermarket), (1) 1/35 Mi-8 Hip, and various ground vehicles, equipment, tarmac, a little terrain that I will try to add my first WIP entry here this weekend, its been well underway for a while now and I have 2 of the Su-27s almost ready to prime, I have to go back and add rivet and panel line detail to one I started painting so its like the other two, to make them look uniform and realistic) anyhow, sorry I digressed there for a moment. Please see below for my idea. You see, the kit leading edge slats of the Su-27s lack the little 'bulged' 'extensions' near the wing root so I mixed some superfine white milliput (finer grain white allows better sanding) and made a little larger VERY rough shape of the extension (it aligns with a panel line so its a little easier getting the position and shape right) and then I drew in pencil where I wanted the leading edge of the new bulge to be, to aid in sanding it uniformly on both sides. I then VERY slowly began sanding it down to shape until it seamlessly blended with the slat. You could try taking some milliput and apply it larger than you'd need as a long 'snake' and put it there for where the LERX extension shims are and then sand it to the shape you want, the stuff dries ROCK hard (think like CA glue does). Or you could cut little 'bulkheads' that would outline the cross-section of the shape you need and attach those to the kit and then add the milliput. The bulkheads would act as a guide for how to sand it. In case you weren't aware Zactoman has some really great 1/32 MiG-29 stuff for the NEW trumpeter mig-29s you might want to check out. Dan, thx for the tips and apologies for the belated response. With this Mig I actually used plastic card as a base from which to sand down... the challenge isn't the material but more just getting the shape right, which I'm struggling with. Regarding the Zacto parts, Chris has equipped me well! I just tonight glued the intakes onto the bottom fuselage, I snapped these pics before doing so. Note the corrected, off-center "wedge" between intake and fuselage. The wedge is symmetrical on the Trumpeter kit, which is plainly inaccurate. Also on the above pic, note that the intake leading edges are natural metal. I sprayed on a coat of Vallejo steel and masked off the sections that will be hard to paint after assembly. I had to rebuild the lower leading edge since it became ever so slightly indented after sanding the intake trunking. The front of the RD-33's is nicely done by Trumpeter. I sprayed the compressor with Vallejo Jet Exhaust, the pics I have indicate these to have a pretty dark appearance. Cheers, Marcel Edited August 29, 2020 by Marcel111 Starfighter, Basta, Lothar and 8 others 11 Link to comment Share on other sites More sharing options...
Crew Dog Posted August 29, 2020 Share Posted August 29, 2020 (edited) Nice work on the burner cans, and good to know about the LERX's and intake plates! Those intake fans definitely look the part as well. Edited August 29, 2020 by Crew Dog Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted September 8, 2020 Author Share Posted September 8, 2020 (edited) Here is where I am with the outer exhausts, basis of which are the beautifully done and correctly sized Zacto renditions. Chris sent me a spare set after I screwed up my first attempt... I tried to use liquid mask to create a splattered effect but just couldn't get the mask off, plus the paint would form a noticeable ridge at the demarkation in those instances where I was able to get the mask off. For the below, I started the painting with an overall spray of half flat aluminum / jet exhaust mixture (all metallic colors are Vallejo acrylic). This to get a duller overall finish, applying glossy metallic over such a surface will still result in a flatter finish because the metallic paints go on so thin. Next, I started applying various other metallic shades, at times using the Uschi splatter masks. Finally, I applied some old Alclad hot metal blue and violet shades. I found the blue to work really well while the violet would quickly clog my fine airbrush (went to the rough H&S instead) while the violet doesn't come through all that strongly. I'm pretty pleased with the result. Compared to the real thing, that is the Duke Hawkins book (a must-have for this build): Cheers, Marcel Edited September 8, 2020 by Marcel111 Martinnfb, Dart_Schatten, Cicciuzzo and 22 others 25 Link to comment Share on other sites More sharing options...
Dragon Posted September 8, 2020 Share Posted September 8, 2020 Great job with the exhausts! Marcel111 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 8, 2020 Share Posted September 8, 2020 Those exhaust nozzles are a work of genius! Kev Marcel111 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted September 9, 2020 Share Posted September 9, 2020 Hey Marcel, two words: NAILED IT! Cheers, Chuck Marcel111 and Martinnfb 2 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted September 9, 2020 Share Posted September 9, 2020 Those exhausts look perfect Marcel! Marcel111 1 Link to comment Share on other sites More sharing options...
Youngtiger1 Posted September 10, 2020 Share Posted September 10, 2020 Nice choice of scheme and subject. Also, those exhaust nozzles looks awesome. Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted September 12, 2020 Author Share Posted September 12, 2020 Thanks guys! I have completed the inside convergent/divergent section also. Incredible how the Zacto parts just fit into place perfectly, glue is almost optional. These Vallejo acrylic metallic paints are a revelation. First of all they look great. They are also acrylic which suits me perfectly since I really hate using enamels and lacquers. But on top they can be mixed with Tamiya acrylic paints, which means color and dull variations are easily created. Cheers, Marcel Landrotten Highlander, LSP_Kevin, Greg W and 9 others 12 Link to comment Share on other sites More sharing options...
Alex Posted September 12, 2020 Share Posted September 12, 2020 That exhaust effect is brilliant. Honestly that (the complex burnt metal shading) is the one thing that terrifies me about trying to build a fighter jet (all my models so far are piston engine and prop). I'll come back to this thread once I get my courage up... Marcel111 1 Link to comment Share on other sites More sharing options...
Neo Posted September 12, 2020 Share Posted September 12, 2020 Wow great job. Thanks for the tip about the Uschi - Trinity Splatter i shall begin hunting for them Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted September 14, 2020 Author Share Posted September 14, 2020 Thanks guys... here's some more work on the RD-33's: Airbrushed with Vallejo flat aluminum mixed with some Tamiya tans, browns and blacks. Cheers, Marcel The Madhatter, Starfighter, johncrow and 7 others 10 Link to comment Share on other sites More sharing options...
