830 -
Days Won
2
Everything posted by Dragon
***Finished*** 1/32 Fisher Models - Hawker Sea Fury FB.11
Dragon replied to Tolga ULGUR's topic in Works in Progress
Pulling up a chair -
https://www.etsy.com/listing/1839347233/model-aircraft-stand-for-building-and?gpla=1&gao=1&
Another vote for leaving it as you’ve done. Looks great.
- 138 replies
Thanks for sharing the pics
I enjoyed my build of the kit; I don't recall anything being too difficult or challenging. I don't do resin cockpits just resin seats, and I used the AMS Resin (now B&B Resin) seats. My build:
Yes, it's a setting on how the threads are displayed. Next to the "Start new topic" bar, you'll see two colored (blue and white) toggle boxes: one with solid lines and one with what I'll call dashed lines. Toggle between them to get the different screen displays.
1:32 Icelandic Fine Arts FA.2 Sea Harrier (Pre-Production Prototype)
Dragon replied to Greg W's topic in Works in Progress
Looks to be a pretty good fit. -
Yeah, I no longer purchase kits made by Trumpeter.
Fantastic build! The JGSDF helo camo is my favorite. Who makes that model stand you’re using?
I have a SOD that has the Zactomodel‘s intake. I’m not going to finish the build. I can pop the intake off, and it’s yours if you want it. I have the cover and instructions as well. PM me if you’re interested in it.
I’ve had the same issues with the Alcad clears: tacky after months. Will no longer use them. Not a fan of rattle cans, but I’ll give the Mr Hobby clears a try. Anyone try the Vallejo or Ammo clears?
F-104G Starfighter, USAF markings, In-flight + parked
Dragon replied to F`s are my favs's topic in Ready for Inspection
An absolutely fantastic build! -
Stunning work!
Trumpeter 1/32nd scale F-105F Big Brass Ones
Dragon replied to Cbowling's topic in Ready for Inspection
Great looking build and well done! How special to meet one of the crew members! -
Yep, recently watched a YT video on the Alaska Ranger rescue, and now I want to build HH-60J Jayhawk.
This build is still alive but moving along slowly. I had a health issue that blind sided me, and my build motivation has been lacking since. When I do find some motivation, I’ve been working on filling and sanding seams, sink marks, and uneven joints. I decided to just paint the cockpit and seat black based on info I had found on the web and from the AMS (B&B Resin Design) Sabre upgrade set. Once I get things cleaned up I'll add the resin nose correction. Hopefully, the drive to build returns, and I can get this build done. Thanks for looking in Mike
Biggest quantity of one particular kit in the stash?
Dragon replied to Shoggz's topic in General Discussion
(4)-Tamiya F-4 (3)-Tamiya F-16 (4)-Trumpeter Intruders Have no idea where I’ll display these once built. -
Props: DHC-2 with floats P-47 A-1 Jets: F-105 F-5 F-16
Before I started working on the wings and drop tanks, I figured I better get a sense of what challenges I was going to have installing the resin cockpit. After cutting off the pour blocks and doing a bit of sanding and shaving of parts, I dry fitted the cockpit into the fuselage, and the fit of the cockpit is very good. I'm going to work on the resin gunsight coaming next. A little plastic surgery is need to remove the kit coaming, and hopefully, the resin replacement will drop right in. Thanks for looking in on my build. Mike
Thanks everyone! I had read that the parts of this kit are thick, and they definitely are! One plus of the excessive thickness is greater surface area for gluing the parts. First issue of the kit to deal are the gun port panels. I have the AMS Resin replacement panels, but after comparing the dimensions of the resin replacement panels against the kits panels, I felt the replacement panels would be more work (and frustration) than they would enhance the look. So, I decided to try and improve the kit's gun panels. To fill the gapping holes in the kit's gun panel (on the right), I glued pieces of styrene strips to the backside of the gun panel (on the left). I think this simple fix helps tremendously. I did the same for the right side once I saw how it improved the appearance. This next step for improving the gun panel was taking a drill bit and routing the gun ports out a bit to improve their shape. After completing the gun panels, it was closing up the machine gun panels. Not a fan of open panels. The panel fit wasn't bad. The only issue was a slight warpage to them, but nothing that was too difficult to deal with. Next up will be the wing assembly and the wing tanks. Thanks for looking in. Mike
I'm joining this GB with the Kinetic F-86F-30 and AM. Not pictured is a AMS cockpit set for this kit. Somehow I've mis-placed the instructions for the set, but I've reached out to BiggTim for an assist. I also have several AM decal options to chose from, but I haven't made a decision on what plane I want to do. Thanks for looking in. Mike
25th Anniversary Group Build Announcement!
Dragon replied to LSP_Kevin's topic in General Discussion
I’ll be in with either a MiG-21, a F-86, or a X-1. Decisions, decisions, decisions…… -
Love it when YouTube brings videos to my attention. This one popped up today that I had not seen. Great combat footage of the A-1E and stories.
