Subodai Posted February 8, 2020 Posted February 8, 2020 Hello all, lurked for a little while and joined recently for inspiration and a push to keep my recently refound love for this hobby. It's been quite a few years since I've put paint to plastic so I'm hoping this isn't just another Hobby phase. We shall see... I attended the big model show in Telford and got 'the itch' bought a bunch of different paints to test and play with, as well as some btis and pieces that postage costs had made prohibitive to try... I've always pined over a whole bunch of 1/32nd Jets, in particular F-14s .. most Jets with twin tails seem to just do it for me.. But I've never had the cash or time to really get into it. Queue a nice bonus at work and decided to sploosh a bit on some kits, found a cheap seller in China on eBay and managed to get a nice little haul... However I don't trust myself and wanted to ease into it.. so picked up this thing quite cheap and have been quietly mulling away at it since Christmas. It's a pretty much OOB build, this is all just me getting used to the tools and paints and all the shiny new things that are available that were definitely NOT as easy to get hold of before. I don't think this will be anything like top notch show worthy and I'm not a rivet counter so accuracy on this kit isn't really that much of a thing for me, I just want to be happy with the end result. it's literally just dipping my toes in the water, seeing if I get the bite.. And giving me something to do that doesn't always involved using a computer or screen all the time (even if I am currently limited to my office desk). Anywho enough wafflin' have some photos! Getting down to business with the internals, attemping some basic stuff with weathering (never done that before, especially not with oils) Turned out okay Pit part-painted and test fitting, I used the kit provided decal for the dials, it wasn't super accurate in some places (mostly the dials on the right) but it gave me a chance to try microset and microsol for the first time.. WOW that stuff is magic. Pit now assembled, gloss coated, oil washed, and flat coated Micro Krystal clear added to some dials for depth, I'm aware it's too much now.. but hey ho.. Also realised I had bought the worlds most expensive PVA glue... lesson learned... Marrying up the wings after painting the wheel well and inner surfaces with the green called out in the instructions More parts setting up, also a view of the not-so-great paint on the inner fuselage, post oil-wash and such. FIrst time really having a proper go at deleting a seam and getting a nice finish, was pretty happy with the result. Definitely justifies how much I blew on sanders!! Fuselage setting up, yep, no pit.. I actually found it easier to get a nice bond without the pit fitted, got the plastic properly welded then slotted the pit in from underneath to give the fuselage the proper width to marry up with the wing roots, worked perfectly! A dry-fit of the main fuselage bottom engine cover and wings (glued and seams removed on all) Never done glazing masking before, so this was just after they were Krystal cleared in after cutting the masks and before filling the gaps First layer of paint on the glass frames to match the interior colour, after filling and smoothing out the gap in front of the main screen (seems to be the done thing, might not be the accurate colour though :S ) put FAR too much paint in the airbrush so used it as a way to check my seams.. all seems fine. Tried to rescribe a few lines with my dandy new Tamiya scribing tool... didn't go well... wibbly wobbly lol Realised I'd filled most of the rivet holes in the nose so had a bosh at trying to sand that back a bit and re-drill them (far too big and deep it would seem after later priming) Fuselage and wings now setting up Test fit of the bottom nose cowel.. thing after having sprayed the interior of it black (before realising it has a blanking piece inside that I missed DOH!). Also did a small amount of pre-painting to the inside of the radiators before fitting them. Radiators assembled and fitted required a little persuation on one of them for it to lay 'flat' but looks fine. Front cowel thing is now also attached And you'll have to forgive me, I missed a few steps between, but, this is now after being primed with Mr Surfacer 1500.. which is _amazing_ stuff. I've never used anything that gives such a silky smooth finish (after a super light pass with 600 grit). It did however, probably give me a little cancer as I grossly underestimated how much I would need, how long it would take and how much it would gas me out... Immediately ordered a Respirator and had a good root through for the power supply for my extractor (not been in use since we moved house a few years ago). And this is where I am still, I have since refilled, sanded and reprimed the way-overdone holes and used a Trumpeter rivet tool to re-do the rivets in the top covers but don't have a photo of that yet. I was waiting on the right colour paints, which after seeing someone elses Mosquito build, I picked up some of MRPs colours, but finding the right time to spray lacquer (the Mr Surfacer probably took a few years off my life) I just haven't had the time yet. Thanks if you got this far! (and sorry for the monolithic post) This is my first 'OP' here so if I've screwed up, missed something, or done a massive Faux Pa let me know. Cheers Mark Dutch Man, MikeC, TAG and 15 others 18
LSP_K2 Posted February 8, 2020 Posted February 8, 2020 Looks like a really nice kit, and that's the craziest keyboard I've ever seen. Subodai and Dutch Man 1 1
rigor Posted February 8, 2020 Posted February 8, 2020 Looks good to me and welcome to the nut house like Kev said that key board is pretty crazy Subodai 1
Alain Gadbois Posted February 8, 2020 Posted February 8, 2020 Beautiful OOB cockpit! Looks like a fun build! Impressive way back in the hobby! Alain Subodai 1
LSP_Kevin Posted February 9, 2020 Posted February 9, 2020 Fantastic re-entry into the hobby, Mark! You're doing terrific work, and the results speak for themselves. I can say that my own return to the hobby was nowhere near this impressive. And yes, your Fisher-Price keyboard is certainly an eye-catcher! Kev MikeC, LSP_K2, Dutch Man and 2 others 1 1 3
MikeMaben Posted February 9, 2020 Posted February 9, 2020 (edited) 9 hours ago, Subodai said: I attended the big model show in Telford and got 'the itch' bought a bunch of different paints to test and play with, as well as some btis and pieces Uh Oh 'now' you're in trouble. You've done this before ?, it's like riding a bicycle Edited February 9, 2020 by MikeMaben Subodai 1
Subodai Posted February 9, 2020 Author Posted February 9, 2020 Thanks for the warm welcome and encouraging words guys Yeah Telford was a mistake, at least my wallet thinks so.. but you only live once right? Heh, yeah the keyboard is a bit of a mashup, it's a bit of a zombie one using all the keycaps I had left over from customizing some other ones I've never really looked at it as an outsider... you're right it does look a little fisher price now that I see it lol. If anyone's into that, it's a Keycool 87 key "rainbow' backlit Mechanical keyboard from Massdrop, with Clone Cherry MX Blue Kailh switches, with a subset of White PBT caps and most of a set of Ducky Yellow ghost PBT caps (no printed letters). I was hoping to spray today but flippin' heck it's windy here in the UK! not sure I want to open a window... MikeC 1
Wackyracer Posted February 9, 2020 Posted February 9, 2020 Welcome to the forum. Great start to your venture into 32nd Subodai 1
Greif8 Posted February 9, 2020 Posted February 9, 2020 Very nice start, the pit looks great! Subodai 1
dennismcc Posted February 9, 2020 Posted February 9, 2020 That's looking great, but then again it is a Spitfire, doesn't look like you have been away from modelling at all, keep up the good work Cheers Dennis nmayhew and Subodai 1 1
Subodai Posted February 17, 2020 Author Posted February 17, 2020 Managed to find a small amount of time to get some of the solid base colours down. I applied some 'light aircraft grey' to the underside, and then realised I wanted to try pre-shading a bit, never done that before.. so.. did some of that and then applied the main upper grey and green. First ever attempt at pre-shading (wow this step makes you feel bad) Then after application of the main grey And then after the green. Not a lot else to report, yet. I've got the 'sky' colour to apply on the fuselage band (I think there's a decal, but I want to spray it) and then I'll probably do some pre-shading on the bottom and re-apply that grey as it's a bit monotone currently... After that, I believe it's Gloss coat, decals, glosscoat, weathering right? Apologies the photos are a bit dark, I was masked up so they were just quick snaps before evacuating! Cheers Landrotten Highlander, MikeC, USMC Herc and 9 others 12
Subodai Posted March 2, 2020 Author Posted March 2, 2020 Decided to have a go at post-shading/fading the panels a bit tonight, managed to make some time over the weekend as well... damn this fine airbrushing is tiring!! Got the Sky colour through so I'll mask that up tomorrow and get the band painted, then tidy the bottom up and get a clear coat on her before decals Then on to weathering and knocking back these highlights a bit! Not super loads of progress, but good to practice skills when I have the time Enjoying the MRP paints, really nice to work with Thanks for checking in Sub JefH, D.B. Andrus, LSP_Kevin and 10 others 13
Out2gtcha Posted March 2, 2020 Posted March 2, 2020 Say hey, that looks terrific! Doing some great work here. Like Kev, my re-introdution to the hobby was nowhere near this impressive. Subodai 1
Subodai Posted March 3, 2020 Author Posted March 3, 2020 9 hours ago, Out2gtcha said: Say hey, that looks terrific! Doing some great work here. Like Kev, my re-introdution to the hobby was nowhere near this impressive. Thank you, kind of you to say.
MikeC Posted March 13, 2020 Posted March 13, 2020 Looking good, can't believe I've missed this up to now. Oh, and welcome aboard. May I ask where you are in Cambs? I'm in St Neots.
