Gazzas Posted December 15, 2019 Share Posted December 15, 2019 Thunnus 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 15, 2019 Share Posted December 15, 2019 That is looking really good! Exceptional paint work! Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted December 15, 2019 Author Share Posted December 15, 2019 Thanks guys! Got a lot done this weekend! Two coats of MIG Scratches Effect wasn't enough to get good chipping results. The Mr Hobby Aqueous over the metal was extremely stubborn and I had to use a toothpick to get most of the chips, which lead to a less than natural effect. Oh well... I can work with it and augment it later with sponge chipping and colored pencils. I gave the model a gloss coat (Alclad Aqua Gloss). Removing the masks to check out the landing gear wells. I thinned the Alclad Aqua Gloss with Mr Leveling Thinner and it had a funky effect on chipping area at the port wing root. Gonna have to fix that when the gloss dries. daHeld, LSP_Kevin, TenSeven and 10 others 10 1 2 Link to comment Share on other sites More sharing options...
Troy Molitor Posted December 15, 2019 Share Posted December 15, 2019 Damn. Looking every bit a late production K, John. Thanks for sharing this. Love the all bare interior gear housing. The contrast in RLM 76 and the green 76 looks awesome. Thanks for keeping us all updated. Troy Thunnus 1 Link to comment Share on other sites More sharing options...
Wackyracer Posted December 15, 2019 Share Posted December 15, 2019 That was an enjoyable 20 mins catch up over breakfast of your amazing build John. Inspirational work throughout. Thunnus 1 Link to comment Share on other sites More sharing options...
Greif8 Posted December 15, 2019 Share Posted December 15, 2019 An absolutely master class build! Your airbrushing is exquisite. Ernest Thunnus 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 15, 2019 Share Posted December 15, 2019 Nice! Too bad about the strange clear coat effect, but overall it's coming along swimmingly. Thunnus 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 15, 2019 Share Posted December 15, 2019 Hmmm...Is the Aqua gloss water or lacquer based? Strange what it did. Looking good, though; I don't think that will be a hard fix. Thunnus 1 Link to comment Share on other sites More sharing options...
anj4de Posted December 15, 2019 Share Posted December 15, 2019 On 5/18/2019 at 1:08 AM, Thunnus said: Thanks for checking in guys! I appreciate the input! The joint between the forward and rear fuselage parts has been cleaned up on both halves. I've re-scribed the panel line too. I'm going to leave it there for now until I resolve the canopy situation. Here's the canopy frame folded but not yet glued. It's reasonably close but I don't think this is going to cut it. Gluing down the top of the canopy to the side frames improves things but it's just not square enough to sit flush. And being a delicate metal frame, it's hard to make adjustments without throwing other areas off. I think this is beyond my pay grade. Here is the kit canopy as a comparison. I'm thinking that I can round off the top corners of the rear canopy and the fuselage from the canopy to about one panel line back. And then polish up the canopy afterwards. For back-up, I have a copy of the Revell G-10 canopy that I might be able to use. It is narrower at the base but I think I can use some hot water and coax it a little wider just in case something goes wrong with the Hasegawa canopy. I'll set aside the metal canopy frame for now. I've added an actuator to the rear of the oil cooler housing. Hello from Bavaria I am following this threat with great intrest...found it while searching for material for my Revell/AMUR Reaver G-6AS build. I also do have a Hasegawa/Revell k-4 in my stash and I already did the modification of the rear fuselage. I glued the halfs togther like you did and I will be using the 2nd Erla canopy of the Revell G-10 kit for it. Fits very good and even better when positioned opened. With the Revell kits being cheap it might also be an option to use the larger wheel buldges... cheers Uwe TorbenD, rafju and Thunnus 2 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted December 16, 2019 Share Posted December 16, 2019 Cool John , a smörgåsbord of color Thunnus 1 Link to comment Share on other sites More sharing options...
Antonio Argudo Posted December 16, 2019 Share Posted December 16, 2019 terrific job John , keep the good, here is a great reference picture of wing root chipping effect, cheers Kais, nmayhew, Thunnus and 9 others 7 5 Link to comment Share on other sites More sharing options...
Thunnus Posted December 16, 2019 Author Share Posted December 16, 2019 Thank you for that fascinating photograph, Antonio! I don't think I'll be able to replicate that type of chipping at the wing roots with this build but it certainly gives one inspiration for the future. Hairspray chipping has its positives but I'm not able to achieve consistency with this method. When it works, it looks good but once the paint gives way to bigger and bigger chips, the effect is easily lost. Plus there is some physical degradation in the paint finish that can occur and those are hard frustratingly hard to correct. Paint removal using Micromesh is one way to replicate the effects shown in the photo and I may have to look at this further... maybe on my Corsair build? zaxos345 and Antonio Argudo 2 Link to comment Share on other sites More sharing options...
Thunnus Posted December 16, 2019 Author Share Posted December 16, 2019 21 hours ago, LSP_Ray said: Hmmm...Is the Aqua gloss water or lacquer based? Strange what it did. Looking good, though; I don't think that will be a hard fix. I believe it is a water-based acrylic. I've used Aqua Gloss thinned with iso alcohol, Tamiya Lacquer Thinner and Mr Leveling Thinner. Although I get a nice smooth finish with MLT, I've noticed a few strange things when using it. I think it is a "hotter" thinner than the others and seems to cut into the acrylic paint a bit. I've had some pre-shading leak through the top camo coat when sealing it with MLT-thinned Aqua Gloss, especially if it is an especially thin coat. Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 16, 2019 Share Posted December 16, 2019 The MLT might be the problem. I had a similar thing happen when I used MIG washes on a KV-1 painted with Tamiya acrylics. Turns out the enamel thinner used in the washes is pretty hot. Of course, it didn't happen on the test scrap I tried it on first with the same paints! Thunnus 1 Link to comment Share on other sites More sharing options...
Guest Vincent Posted December 17, 2019 Share Posted December 17, 2019 Hi Wing root fairings on the K4 were made of plywood, not metal Only the front part of the fairing was metal V Link to comment Share on other sites More sharing options...
