Fvdm Posted March 30, 2019 Posted March 30, 2019 I think that wheatering is always difficult. How far should one go before it gets overdone. When I look at this I get a pretty good idea because i really like what I'm seeing. Great job. Out2gtcha 1
LSP_Kevin Posted March 30, 2019 Posted March 30, 2019 As much as I'm not into what-if concepts generally, I have to confess that this looks really fabulous, Brian! Kev Kahunaminor and Out2gtcha 2
LSP_Ray Posted March 31, 2019 Posted March 31, 2019 That looks really good, Brian! Well done! Out2gtcha 1
Out2gtcha Posted April 1, 2019 Author Posted April 1, 2019 Thanks gents! More weathering tonight, this time its on the underside only with AKIs "dust effects" which are technically for landing gear (which I will use on them too) but this time I used my airbrush to effect some dust on the underside, where kicked up by the prop, across the inner section of the underside, wing roots, and behind the flaps and gear wells. I also got some of the same sections on top, to give it an overall dusty effect, but concentrated more on the sections that would have been blasted by prop wash. No pics of that yet, as I was letting it all dry, then covering with and overall semi-gloss clear, then a flat clear over just the dusty parts to give the worn feel. While all that was curing off, I got the main bodies of the Ruhrstahls done. This is all MRP, from nose to tail, insignia white, aluminum, steel and jet exhaust for the rocket tip. This was washed with Tamiyas enamel brown panel line accent: Ive just unmasked the Ruhrstahl winglettes, and have applied the first side of Uschi wood decals. More pics later this week after I get the other side of the wood decals on, and can get to a stage of showing the missiles completed. I just have to paint and install the sway braces. The missiles are coming along great IMHO, and will add a lot to the finished model. Cheers and stay tuned to this channel for more pics this week! LSP_Kevin, Trak-Tor, Mebo and 5 others 8
Kahunaminor Posted April 4, 2019 Posted April 4, 2019 Fan-bloody-tastic Brian, Am I allowed to say that? Too late! Read from start to now and just thrilled with the show. Well done and so many thanks for the lessons involved. Regards,
monthebiff Posted April 4, 2019 Posted April 4, 2019 Just catching up with your build Brian and love what you are doing with the big 335! That desert scheme really suits it. Regards. Andy Out2gtcha 1
Out2gtcha Posted April 4, 2019 Author Posted April 4, 2019 Thanks all! I actually have been slowly adding weathering to the big dessert beast. I have the flat coat on top, some very subtle chipping started and some dust effects added. Just havnt had time to sit at the bench long enough to take pictures. Next up, is finishing off the X-4 missiles, and then cranking out one of the last things to do which is the landing gear. Ive been working on a review for the new AOA F-4 decals, and trying to box up some clear parts for the old vac Beaufighter to get replicated so my time with the big 335 has been limited the last week or so. Pics soon!
Out2gtcha Posted April 5, 2019 Author Posted April 5, 2019 Ok, as promised here is where I am at with the weathering.....................not remotely done, but the wash (brown Tamiya panel line accent) and dust (AKI dust effects) have been added as well as some very minor chipping (Prisma color pencil) to only certain parts, as I figured this paint job while not professionally applied would not have been super old (but daily combat would take a toll quickly) therefor likely would have been dirty but not too scratched up yet. Props and rudders are only stuck on for appearance sake at this point as I just wanted to see what I had so far. I will leave all this off again once I pick up on further weathering. Overall coated with a semi-gloss clear, then the tops/horizontal parts that were exposed to direct sunlight were hit with some MRP flat/matt for that dusty, faded flat look. I also got the dust filters and rear/belly intake scoops unmasked as well: All for now, as I need to put the finishing touches on a F-4 Phantom decal review for AOA and should be back on the big bird tonight or tomorrow. Cheers! LSP_Kevin, Fvdm, MikeMaben and 12 others 15
BloorwestSiR Posted April 5, 2019 Posted April 5, 2019 Looks great Brian. The missiles are impressive especially with the touch of weathering you've given them. Carl
Erwin Posted April 5, 2019 Posted April 5, 2019 (edited) Looks great.Don't overdo the weathering. Just my opinion. But I would have used black crosses with white outline on top and fuselage.Looks better on a light color like the sand. Only white works better on dark colors. Your model ofcourse.No bad comment intended. Edited April 5, 2019 by Erwin Out2gtcha 1
Out2gtcha Posted April 5, 2019 Author Posted April 5, 2019 Thanks boys! Irwin, I actually stayed with what the normal Do-335s would have worn during the time frame as these are merely the later style of balkenkreuz that likely would have been worn by all combat active Do-335s. I also went with the white only balkenkreuz on the top wings and fuse as it fit in better with the desert motif IMHO in that it blended a bit better so as to not disrupt the camo quite as much as a full white and black balkenkreuz may have. Thanks for looking in on me! Lothar, Erwin and williamj 3
PhilB Posted April 5, 2019 Posted April 5, 2019 Yep, I was waiting for this stage and I think it's just right. Takes it from the "just painted" stage and knocks it back to be more realistic and given your scenario on it's age it looks right. I can't wait to see those missiles on it. They remind me of kind of a "Buck Rogers" type thing and that's the 1939 films!!! Out2gtcha 1
Out2gtcha Posted April 5, 2019 Author Posted April 5, 2019 Thanks bub! I'm actually looking at my pics, and didn't do a very good job of capturing the weathering, especially the dusty/slightly chipped parts, but they are harder to see. You actually cant see most any of the dust effects or how the flat looks IRL. Will have to think on that for future pics.......... More later, as I do plan on finishing up the weathering on the airframe this weekend, and will be moving to finish the landing gear, gear doors and X-4 missiles. BiggTim 1
themongoose Posted April 5, 2019 Posted April 5, 2019 I finally got to see this full size and not squinting over my phone and WOW does it look great. Crazy paint scheme for sure. You really pulled this one off in spades! I’m with the rest of the gang, can’t wait to see those missiles on it. Out2gtcha 1
LSP_Kevin Posted April 5, 2019 Posted April 5, 2019 That looks superb, Brian! Spot on with the weathering. Kev Out2gtcha 1
