chuck540z3 Posted December 20, 2018 Share Posted December 20, 2018 (edited) December 20/18 After exactly 1 year, I have finally finished my 1/32 Tamiya Mk.IXc Spitfire. Since I started this build here, I'd like to also display the finished model here, along with my other prior builds. For those who might be interested in the build threads, I started this project at LSP here: 1/32 Tamiya Spitfire MkIXc, "Kicked Up A Notch" Part 1 and finished it at ARC here: 1/32 Tamiya Spitfire MkIXc, "Kicked Up A Notch" Part 2 I added a ton of detail from after market parts and my own plumbing and wiring, which can be found within the threads above, so I won’t go into that gory detail here, but I would like to make the following comments. 1) As indicated in the first thread, this Spitfire is dedicated to my father who passed away many years ago. He was an “Airframe Mechanic” in RCAF 401 Squadron, which was stationed in England and later Belgium and France towards the end of the war. 2) This particular Spitfire is also dedicated to F/L W.R. (Bill) McRae, who flew in many squadrons including 401. In the 2nd Edition of Robert Bracken’s excellent book, “Spitfire II the Canadians” on the front cover and on page 59, is the artwork of Ron Lowry. Bill is the rear wingman in this pic, as shown below: 3) While I tried to be accurate as much as possible, I didn’t worry too much about some details of early vs. late Mk. IX’s. For instance, I used the later and much larger lower intake instead of the small one in the pic above, mostly because it looks cool. 4) While I did get the cowlings to fit OK, the fit isn’t great and you really have to man handle the model to get them on and off, which risks damage (and I had a bunch of it!) so I won’t be putting them on again- ever. The main reason for the so-so fit is my addition of the Eduard PE cowling rub strips to the engine frame, which get in the way of clearance. I knew this was a likelihood when I added them, which is also why I didn’t add some plumbing to the port side that covered the engine cradle, but the strips look so nice, I don’t care. Good thing I plan on displaying this Spit with the cowlings off all the time anyway, including model contests. If you’d like to see how they fit, there’s some pics in my public ImageShack site here: Spitfire Build and Reference Pics 5) I wanted a well-worn Spitfire based upon many photos in the Bracken book and also an unrestored Mk.Ia in the Imperial War Museum in London, that I took many reference pics of for such a project. As you will see, I really wore the paint off both sides of the wing roots to replicate this and other photographs that I could find of the real deal in WWII. 6) None of my weathering included pre-shading panel lines or a dark wash within panel lines, which is usually done to this model. Based upon the above references, I did the exact opposite, and added a metallic light wash to replicate unpainted panel line edges and raised rivets. Weathering is like art where some people will like it while others will not, so no offence taken from me if you don’t like some of the things I did. 7) Most of my detail is within the cockpit and engine areas. The uncovered engine photographs great, but to get good pics inside the cockpit, I need to use a flashlight or other light source, which makes everything look unnatural. Thankfully, you can see almost everything within the cockpit area with the naked eye. 8)- You won’t find any silvered decals, because I didn’t use any conventional ones. All the insignias and lettering were painted using Maketar paint masks and the stencils were HGW water transfer decals, which leave no carrier film after drying. I am now a huge fan of both products. Now the pics, starting from the entire model to many close-ups. Sorry for so many engine pics, but you can’t see everything unless you look at every angle. Thank you in advance for your interest in this project. First, a pic of the unrestored Spitfire: And now my interpretation of a war time Mk.IX. Note that some colors have shifted due to my lighting. Edited December 21, 2018 by chuck540z3 Alain Gadbois, TAG, Fanes and 12 others 15 Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 20, 2018 Author Share Posted December 20, 2018 A-10LOADER, Whitey, Squizzy 78 and 11 others 14 Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 20, 2018 Author Share Posted December 20, 2018 (edited) Thanks to everyone here for your support during "Part 1". I really appreciated it. Cheers, Chuck Edited December 20, 2018 by chuck540z3 Shawn M, KiwiZac, Old Dog and 26 others 29 Link to comment Share on other sites More sharing options...
dennismcc Posted December 20, 2018 Share Posted December 20, 2018 A real masterpiece, love it. Cheers Dennis chuck540z3 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted December 21, 2018 Share Posted December 21, 2018 chuck540z3 1 Link to comment Share on other sites More sharing options...
DonH Posted December 21, 2018 Share Posted December 21, 2018 Very nicely done. chuck540z3 1 Link to comment Share on other sites More sharing options...
Jan_G Posted December 21, 2018 Share Posted December 21, 2018 Amazing build and details Chuck! jan chuck540z3 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted December 21, 2018 Share Posted December 21, 2018 You got that right, Brother. Thank you for finishing this off here. Sincerely, Mark chuck540z3 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 21, 2018 Share Posted December 21, 2018 magnificent chuck540z3 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted December 21, 2018 Share Posted December 21, 2018 Absolutely 'spot on' Chuck! Just the right amount of weathering and wear. So pleased you posted her here finished....she's gorgeous. Hope my Tamiya Mk Vc conversion finishes up to this standard! Cheers mate Anthony chuck540z3 1 Link to comment Share on other sites More sharing options...
F`s are my favs Posted December 21, 2018 Share Posted December 21, 2018 Beautiful Spitfire ! That striptease form is phenomenal! chuck540z3 1 Link to comment Share on other sites More sharing options...
TorbenD Posted December 22, 2018 Share Posted December 22, 2018 Top of the toppest drawer Chuck - mighty fine work. Beautifully finished. Torben chuck540z3 1 Link to comment Share on other sites More sharing options...
Bill Cross Posted December 22, 2018 Share Posted December 22, 2018 Damn that's fine! Wish I had purchased the kit when I was in Tokyo last October: $60 at the Tamiya Playmodel Shop. Really masterful modeling down to the printing on the seat harness. chuck540z3 1 Link to comment Share on other sites More sharing options...
JeffH Posted December 22, 2018 Share Posted December 22, 2018 Outstanding as usual Chuck. Great job! Love the weathering. chuck540z3 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted December 22, 2018 Author Share Posted December 22, 2018 (edited) Thank you everyone, I appreciate your kind comments. As mentioned above the cowling fit is only so-so, so here's what they look like test fitted. Since the fit is a small distraction rather than an enhancement of the model, I likely won't put them on again, because they are a bear to get everything placed together properly and you risk damage in doing so. From now on, they will sit below the engine area. Cheers, Chuck Edited December 31, 2018 by chuck540z3 Anthony in NZ, Eenyweeny, Fanes and 6 others 9 Link to comment Share on other sites More sharing options...
