spyrosjzmichos Posted May 3, 2023 Posted May 3, 2023 (edited) Hello everyone! Back with another project and first for 2023. This time I will be tackling Hasegawa's 1/32 scale kit of the P-47D Thunderbolt, bubbletop version, and will depict Glenn T. Eagleston's aircraft. I will also be using the following aftermarket sets: Avionix resin cockpit Quickboost resin engine Eduard resin wheels I'm aware of the kit's misalignment issues around the cowling and Rick Kranias kindly pointed me to his detailed post on how to fix this. Quickboost provides a separate mounting for the engine which requires some surgery on the kit. Has anyone used this set and, if yes, did it it fix the issue? Hasegawa's kits are known for their good quality and accurately shaped moldings and are usually sold at a reasonable cost by keeping some details simple such as the surface details. So, that's how I decided to start the project. By riveting the whole airframe with the help of a Rosie the Riveter wheel. The riveting pattern is by no means an exact replica of the real thing but rather it follows the general plan with the aim to make the whole fuselage look more busy. Edited May 3, 2023 by spyrosjzmichos alain11, MikeMaben, BlackCanopy and 29 others 32
Jaro Posted May 4, 2023 Posted May 4, 2023 Great start! For sure a thread to follow! spyrosjzmichos 1
Uncarina Posted May 6, 2023 Posted May 6, 2023 Your builds are so fun to watch! Great start. Cheers, Tom spyrosjzmichos 1
themongoose Posted May 6, 2023 Posted May 6, 2023 That really changes the look of the aircraft. Well worth the effort and time! spyrosjzmichos 1
spyrosjzmichos Posted May 15, 2023 Author Posted May 15, 2023 Hi all! Apologies for not being very responsive this time. Unfortunately, life caught up with us, dealing with our son's protracted illness on one side and moving to a new place on the other. Scale modeling is the one thing that's keeping me sane at the moment so was able to make some progress with what limited free time I had. Using a number of reference pics I proceeded to detail the wheel wells with a combination of lead wire and flexible vinyl thread. The undercarriage legs were also detailed in a similar manner. I also took the opportunity to test fit Eduard's resin wheels which are beautifully detailed and only required a slight enlargement of the hole insert. Hope you guys like it! BiggTim, LSP_Kevin, MikeMaben and 18 others 21
LSP_Kevin Posted May 15, 2023 Posted May 15, 2023 Looking good, Spyros! I hope things work out with your son's illness. Kev spyrosjzmichos 1
MikeMaben Posted May 16, 2023 Posted May 16, 2023 No apologies necessary , take your sweet time , progress looks good. spyrosjzmichos 1
spyrosjzmichos Posted May 16, 2023 Author Posted May 16, 2023 8 hours ago, LSP_Kevin said: Looking good, Spyros! I hope things work out with your son's illness. Kev Thank you so much Kev! Little guy is finally getting better now. 29 minutes ago, MikeMaben said: No apologies necessary , take your sweet time , progress looks good. Many thanks Mike! Shoggz and LSP_Kevin 2
Sturmbock Posted May 16, 2023 Posted May 16, 2023 Like it a lot! It looks like a huge progress to me, really good work! Especially the wiring on the wheel wells. Everything looks fine! Cheers Lutz spyrosjzmichos 1
Reuben L. Hernandez Posted May 16, 2023 Posted May 16, 2023 Looking great so far. I'm currently getting ready to start working on mine. Question, where did you get the rivet pattern detail from? Thanks, Reuben spyrosjzmichos 1
spyrosjzmichos Posted May 16, 2023 Author Posted May 16, 2023 9 hours ago, Sturmbock said: Like it a lot! It looks like a huge progress to me, really good work! Especially the wiring on the wheel wells. Everything looks fine! Cheers Lutz Many thanks Lutz!
