Starfighter Posted July 13, 2020 Share Posted July 13, 2020 I have said "it doesn't get any better than this" many times in your build threads, and I was wrong each and every time. Another step towards perfection... it's just so impressive what you are doing, Peter. The level of craftsmanship is just beyond belief and I think I've said this before as well - it's hugely inspiring, motivating and depressing at the same time. Please keep doing what you are doing! airscale 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted July 13, 2020 Share Posted July 13, 2020 Bloody hell! That's so impressive! airscale 1 Link to comment Share on other sites More sharing options...
allthumbs Posted July 13, 2020 Share Posted July 13, 2020 Spectacular! airscale 1 Link to comment Share on other sites More sharing options...
airscale Posted July 18, 2020 Author Share Posted July 18, 2020 afternoon my friends Something arrived in the post this week which has meant I could crack on with my favourite part of any build.. ..this stack are the custom decals for the 190 that I had in the corner of a layout sheet for an airscale restock. The good thing is they are super high quality decals, the bad thing is I have 75 copies as that was the sheet order size for one of the layouts… I only need one of any decal on the sheet as I have so many copies and it keeps the sheet size down, plus there are a few bits on there for friends ..anyways, I don’t have any WIP shots, but I have been busy – this is the V15 cockpit I am basing the V18 on.. ..and my version.. ..upper panel.. panel in front of the control stick.. lower panel.. ..and sort of how they go together.. ..and that’s that – favourite bit done, it’s all downhill from here On 7/12/2020 at 11:31 PM, sky said: Well well well, it would seem as if I need to get me some unobtanium eh lithium, dammit, litho plate to play with. As I have said before the results are amazing (as usual...), the way they are done is not exactly rocket science with a bit of planning ahead (and mostly household tools). Just look at the boss for the punch and die action: haphazardly glued bits of styrene on a flat surface, that kind of looks like my desk while building. It's just that I don't use that to create shapes in litho over it (yet! - see above, lack of litho...) :P. However, for me it just happens, whereas Peter does plan ahead - as is apparent by the printed out templates, that either have already been turned into PE sheets or will likely be some time soon. So again thank you, Peter, for showing us how it's done. Looking over the build process I need to keep reminding myself that for a lot of parts it is not some super duper magic stuff happening, but simply adding relatively simple shapes and things on top of others to make complex shapes (which btw is very similar in 3D modelling). See that radiator - 3D printed body with added PE. Ok, I was honestly disappointed that the internal radiator structure was not made from individual PE sheets but is just a structured blind stuck on the front. The next one must be! (Ok, so who am I kidding here? ;)). Or the layered sidewalls - "simple" really if you know how to use software to draw things, but the effect is amazing. Back to the sidelines, watching, hopefully learning Thanks Sky - appreciate that. You are so right, if you break this all down, it is simple tasks. I still say that if you approach each and every component as a model in itself then the quality of the output goes up TTFN Peter BlackCanopy, zaxos345, Rocat and 17 others 20 Link to comment Share on other sites More sharing options...
TorbenD Posted July 18, 2020 Share Posted July 18, 2020 IPs look.... well... real! Just WOW! Super impressive stuff Peter Torben airscale 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted July 18, 2020 Share Posted July 18, 2020 Trip me out. Well done! Sincerely, Mark airscale 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted July 19, 2020 Share Posted July 19, 2020 Awesome efforts again. The panels are certainly not 2 demential and yours are certainly not. Well done Peter. airscale 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 19, 2020 Share Posted July 19, 2020 If you told me they were real instrument panel parts, I'd believe you. Kev TAG, Brett M and airscale 3 Link to comment Share on other sites More sharing options...
LSP_Ray Posted July 19, 2020 Share Posted July 19, 2020 28 minutes ago, LSP_Kevin said: If you told me they were real instrument panel parts, I'd believe you. Kev +1!!! airscale 1 Link to comment Share on other sites More sharing options...
RadBaron Posted July 19, 2020 Share Posted July 19, 2020 Absolutely astonishing, Peter airscale 1 Link to comment Share on other sites More sharing options...
Chek Posted July 19, 2020 Share Posted July 19, 2020 Congrats Peter, you've saved a kit from the shelf of doom after more than 20 years! I'd laboriously fabricated the dimple panels and webs in the U/C bay on my MPM kit then started reading about how the D series had left the panels off for improved engine bay cooling. So I figured, in the absence of actual data, the same is very likely true for the similarly inline engined C model. I considered swapping the wings on to a regular A model, but the moulded exhaust tube fairing channels on the upper wing parts didn't make that an easy option. So into storage it went until I summoned up the courage to rip out the dimples. Bit of a pain as the photo etch radiator grilles and cockpit parts looked great. Only to find out now after all this time that they're fine as they are. I'll get back to it and hopefully make the decision whether to finish it as a prototype, or go for a faux operational hi-altitude finish. Link to comment Share on other sites More sharing options...
airscale Posted July 19, 2020 Author Share Posted July 19, 2020 2 hours ago, Chek said: Congrats Peter, you've saved a kit from the shelf of doom after more than 20 years! I'd laboriously fabricated the dimple panels and webs in the U/C bay on my MPM kit then started reading about how the D series had left the panels off for improved engine bay cooling. So I figured, in the absence of actual data, the same is very likely true for the similarly inline engined C model. I considered swapping the wings on to a regular A model, but the moulded exhaust tube fairing channels on the upper wing parts didn't make that an easy option. So into storage it went until I summoned up the courage to rip out the dimples. Bit of a pain as the photo etch radiator grilles and cockpit parts looked great. Only to find out now after all this time that they're fine as they are. I'll get back to it and hopefully make the decision whether to finish it as a prototype, or go for a faux operational hi-altitude finish. Well, I don't know they were fitted and in fact since I made them, a pretty convincing argument has developed to say they were not. As you say the inline D series didn't have them and while I know the fuselage of V18 was an early A model, the wings as a bolt-on unit could be A or D based I think the compelling reason they were likely not there is that there is a chuffing great big pipe that comes out of the bay at the rear spar and feeds into the big scoop under the fuselage and when I mocked this up in the bay the pipe clashes with the dimpled roof parts.. ..that said, I have made them now, I like them as a feature and to date there is zero proof they were not there so I am just going to do a bit of 'whiffery' and modify them to accomodate the pipe - I can live with that and I hope you can too and rescue yours from the SOD Peter chukw, RadBaron, Chek and 5 others 8 Link to comment Share on other sites More sharing options...
airscale Posted July 19, 2020 Author Share Posted July 19, 2020 …side consoles.. TTFN Peter Starfighter, BlackCanopy, Rocat and 12 others 15 Link to comment Share on other sites More sharing options...
Hans Posted July 19, 2020 Share Posted July 19, 2020 Impressive.. airscale 1 Link to comment Share on other sites More sharing options...
allthumbs Posted July 19, 2020 Share Posted July 19, 2020 Oh my, it just keeps getting better. Impressive work indeed! Rich airscale 1 Link to comment Share on other sites More sharing options...
