Hawkwrench Posted March 25, 2020 Share Posted March 25, 2020 Wow, I gotta get me some of that wire. That looks dead on!!! Tim Pete Fleischmann and chrish 1 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 26, 2020 Author Share Posted March 26, 2020 more comm cord stuff- cheers Pete dodgem37, Starfighter, Landrotten Highlander and 7 others 10 Link to comment Share on other sites More sharing options...
shark64 Posted March 26, 2020 Share Posted March 26, 2020 your interior is just perfect. i dig this build. Nice one bro. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 27, 2020 Author Share Posted March 27, 2020 16 minutes ago, shark64 said: your interior is just perfect. i dig this build. Nice one bro. Thanks my friend.. I’ve said it before, but I’ll say it again- you are one of my most favorite modelers!! cheers Pete Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 27, 2020 Author Share Posted March 27, 2020 Hey all- had some fun with this today- got to mess with the fire extinguishers- these were first shot with a black undercoat, then I mixed a yellow green from Tamiya yellow and Tamiya bright green then I dry brushed a lighter version of the base color, using the Same colors plus a little white. I test it on a paper towel until a barely perceptible dusting comes off the brush Then gently hit the high spots and edges- The trigger assemblies were painted MM jet exhaust and dry brushed with aluminum A couple decals..a few chips..a wash, and done! cheers Pete geedubelyer, Out2gtcha, Fanes and 10 others 13 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 27, 2020 Author Share Posted March 27, 2020 Here’s how I made the inspection tags on the fire extinguishers- first; grab some thin, rigid cellophane- the kind from a pack of cigarettes is perfect, but I don’t smoke..but I found some on a package of paint brushes. Cut a chunk off- next, paint the backside with Tamiya buff. Paint only one side- Once the paint dries, flip it over. Apply decals from the spares box. The brass grommets are dry transfers from Archer- they rock! And I use them for all kinds of stuff. When the decals are dry, flat coat them- use a a new blade a a straight edge to cut them into a tag shape. I used a section of stretched sprue to simulate the zip tie- super easy.. cheers Pete Jeff T, geedubelyer, Starfighter and 17 others 18 1 1 Link to comment Share on other sites More sharing options...
Hawkwrench Posted March 27, 2020 Share Posted March 27, 2020 Totally cool Pete. Those look so real!!! Tim A-10LOADER and Pete Fleischmann 1 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted March 27, 2020 Share Posted March 27, 2020 (edited) Check you out. It's fun to catch your updates. A lot of knowledge transfer. Your skillset is just tops. Appreciate the tutorial. Sincerely, Mark Edited March 28, 2020 by dodgem37 Pete Fleischmann and Brett M 1 1 Link to comment Share on other sites More sharing options...
CZPetrP Posted March 28, 2020 Share Posted March 28, 2020 Amazing solution with those flags. Good job. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
crobinsonh Posted March 28, 2020 Share Posted March 28, 2020 Brilliant work Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 28, 2020 Share Posted March 28, 2020 This goes from strength to strength Pete. I am very impressed by the wear to the cabin floor, in particular the metal tread on the outer edge. The chipped paint is hugely realistic and shows that restraint often yields a better result. Beautiful work buddy. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted March 28, 2020 Share Posted March 28, 2020 This build is just incredible. The detail looks crisp and so authentic. Wow! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 29, 2020 Author Share Posted March 29, 2020 (edited) Thanks you guys! Appreciate all of the support! This was a head-scratcher..most of my references show the USAF Pavehawks with the cabin configured for CSAR; with tons of medical triage gear scattered all over. There are always I.V. Fluid bags hanging from the ceiling..but how do I make them? heres how: first; cut a blank out of clear plastic sheet. Drill a hole for the hanger- while you’ve got the blank on the wire, bend the wire into a hook- then mix mix up some clear 2 part 5 minute epoxy. Goober it on the clear plastic blank. Gravity is your friend- once these set up, I’ll maybe frost them with a flat coat..maybe a label? Not my area of expertise, but problem solved! cheers Pete Edited March 29, 2020 by Pete Fleischmann LSP_Kevin, johncrow, Fanes and 11 others 14 Link to comment Share on other sites More sharing options...
Timmy! Posted March 29, 2020 Share Posted March 29, 2020 Dude nice solution....again.... What an awesome project, so many unusual things to model. Most excellent challenge! Keep it up broseph! Timmy! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 29, 2020 Author Share Posted March 29, 2020 2 minutes ago, Timmy! said: Dude nice solution....again.... What an awesome project, so many unusual things to model. Most excellent challenge! Keep it up broseph! Timmy! Thanks brother- I just woke up on the floor after looking at the latest on your Jaguar. Guess I passed out from over-stimulation! cheers Pig Landrotten Highlander and Madmax 2 Link to comment Share on other sites More sharing options...
