JeffH Posted January 1, 2019 Share Posted January 1, 2019 I'm in with a Trumpeter P-38 in Tom McGuire Markings (Pudgy V), Using the Big ED set (parts that I don't break or lose totally) I've already made a small start, beginning with the interior PE set. When there's a lot of PE I tend to approach it from 2 directions. I go through the PE instructions looking for kit part numbers. Then I just mark PE on that part on the instruction sheet as a reminder. Then I go through the PE sets hacking up the kit pieces as need be. When all the PE is done I proceed with the kit. So these first few posts will just show kit parts with PE Let the fun begin Daniel460, spacewolf, LSP_Kevin and 8 others 11 Link to comment Share on other sites More sharing options...
Dragon Posted January 1, 2019 Share Posted January 1, 2019 (edited) Great approach for PE! I’ll keep that in mind for future builds. Edited January 1, 2019 by Dragon Link to comment Share on other sites More sharing options...
Erwin Posted January 1, 2019 Share Posted January 1, 2019 Nice to see this kit. It's on my "maybe-list" for this GB. Link to comment Share on other sites More sharing options...
Thomas Lund Posted January 1, 2019 Share Posted January 1, 2019 Lovely !! not often we see these P-38s built. I've got one as well with a conversion to an early version I considered for this GB... so I'll be keeping an eye on you progress :-) Link to comment Share on other sites More sharing options...
Iain Posted January 1, 2019 Share Posted January 1, 2019 Oooh - cracking! As Thomas said - we see too few of these kits getting built - which is a great pity... Iain Link to comment Share on other sites More sharing options...
JeffH Posted January 1, 2019 Author Share Posted January 1, 2019 Thanks for looking in guys. I assume this plane doesn't get built a lot because the NMF scares people off. There are no O/D options for an L without back-dating. And back-dating would involve hacking the nacelle intakes (at least). So it's left to fearless (mindless?) sorts like myself and the gods like Chuck to have at it. Here are some shots of progress so far My LHS no longer stocks Alclad and I did not have anything chrome-like on my shelf. The LHS now carries Vallejo so I slapped the drop tanks together, blasted a coat of Tamiya TS-14 (thanks Chuck!) then Vallejo Chrome and this is what I ended up with. Close enough for government work I figure; and it's all I have without resorting to (gulp) foil. Here's the modified gun bay bulkhead Cockpit rear deck (radio) area. Trimmed according to Eduard instructions. That brass bulkhead at the rear is larger than the plastic area it is covering. I'm expecting it to cause a fit issue later on but it's on my radar. Eduard Instrument panel. Toggle switches...are you freaking kidding me? I lost about 3 banks of them to the ether. There's one on there. I don't know why I bother with this stuff. In theory it's neat but the instructions are vague and it takes a bit of technique, a couple of critical tools and a whole lot of patience. The patience is sadly lacking on my part. But it doesn't look bad from 3 feet and it will be well hidden (I hope) Magazine for the 20mm cannon. This thing is a pain in the ass too. Eduard gives you flat(!?) 20mm shells to feed in there somehow. This guy is going out empty Radio gear for the rear deck and replacements for the kit rudder pedals. The .50 cal and 20mm And the ammo cans. That is most of the Eduard interior set. Thanks for following along. Happy New Year everybody! Shawn M, Trak-Tor, BiggTim and 5 others 8 Link to comment Share on other sites More sharing options...
themongoose Posted January 1, 2019 Share Posted January 1, 2019 Nicely done! Don’t you love to hate PE? Because they included those toggles it’s really hard to NOT put them on right! BiggTim and JeffH 2 Link to comment Share on other sites More sharing options...
JeffH Posted January 1, 2019 Author Share Posted January 1, 2019 The trick is not to lose it when the tweezers go 'ping' and switches fly off. Then I'm thinking screw it, I still have the nice little colored front plate...ping argh!!!! We need some sort of 'cone of silence' when working with this stuff. Maybe I'm not that far out...some sort of mosquito netting or some such draped over you like a tent. Anything that flies will stay in tent.....hmmmm BiggTim 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted January 4, 2019 Share Posted January 4, 2019 IP looks good to me! PE is definitely a love-hate thing. I still have one of Aber's first offerings: a 1/35th T-37 WWII Russian tracked tractor that is 95% PE. Still working up the courage for that one. BiggTim 1 Link to comment Share on other sites More sharing options...
richardchapman5 Posted January 4, 2019 Share Posted January 4, 2019 Coming along very nicely BiggTim 1 Link to comment Share on other sites More sharing options...
JeffH Posted January 27, 2019 Author Share Posted January 27, 2019 Thanks guys. Slowly picking away at the PE there's the canopy latches and masks applied. This piece has actually been painted but I don't have a picture yet You have to get inventive on this kit for where you place weight to get the nose down. The engines end up being hidden but since they help line the props up I decided ti build them as an exercise _and_ to add weight. I added some lead fishing weights in the engine block gap and I noticed this dead space at the back of each engine (bell crank housing in a car engine). I took some fine lead solder and scrunched it up to fill the space T These guys are starting to feel like they have a bit of weight in your hand. I'm looking for more spots forward of the CoG Plodding forward. Having trouble with my airbrush but it's self-inflicted. I let it get gunked up and it hasn't been the same since D.B. Andrus, LSP_Kevin, BradG and 2 others 5 Link to comment Share on other sites More sharing options...
chrish Posted January 27, 2019 Share Posted January 27, 2019 Very nice work! You have my respect for not folding the photo-etch sheet up into a 1"X 1" square and throwing it in the bin. (My go to response with photo-etch) Any weight filling spaces above, beside, the nose gear well? Must be tough finding room with such a small fuselage "egg" BiggTim 1 Link to comment Share on other sites More sharing options...
Azgaron Posted January 27, 2019 Share Posted January 27, 2019 Cool with a P-38 and nice work so far! Håkan BiggTim 1 Link to comment Share on other sites More sharing options...
JeffH Posted January 27, 2019 Author Share Posted January 27, 2019 1 hour ago, chrish said: Very nice work! You have my respect for not folding the photo-etch sheet up into a 1"X 1" square and throwing it in the bin. (My go to response with photo-etch) Any weight filling spaces above, beside, the nose gear well? Must be tough finding room with such a small fuselage "egg" Thanks guys There's not a lot of space in the nose gear area because of the gun detail. But I just noticed the ammo cans have a bit of space to hide some more lead solder and that will be right in the nose BiggTim 1 Link to comment Share on other sites More sharing options...
BiggTim Posted January 28, 2019 Share Posted January 28, 2019 I filled the nose cone of my L model with solid lead, and made the ammo cans out of lead covered with sheet styrene, as well as some under the floor of the gun bay. It's really tough when you're gonna leave the gun bay open especially. Maybe this year I'll actually finish the darn thing! Out2gtcha 1 Link to comment Share on other sites More sharing options...
