Thomas Lund Posted August 22, 2017 Share Posted August 22, 2017 Hey If you scribe panel lines and feel the need to correct some because they are not straight enough... what do you fill the incorrect line with ? It seems to me that some fillers will chip if you try to scribe a new line in the immediate vicinity... Link to comment Share on other sites More sharing options...
ericg Posted August 22, 2017 Share Posted August 22, 2017 Superglue works well Thomas. Cheers, Eric. Zero77, 109 and Ryan 3 Link to comment Share on other sites More sharing options...
Guest Maxim Posted August 22, 2017 Share Posted August 22, 2017 I use superglue. I use the super thin and sand within minutes and rescribe while still soft. Link to comment Share on other sites More sharing options...
Starfighter Posted August 22, 2017 Share Posted August 22, 2017 I use superglue as well. 109 1 Link to comment Share on other sites More sharing options...
dennismcc Posted August 22, 2017 Share Posted August 22, 2017 CA for me too, applied with a toothpick, however I do not let it set rock hard as I would then be sanding the softer plastic and not the CA, so I let it set for 30 mins or so and then sand it. Cheers Dennis 109 1 Link to comment Share on other sites More sharing options...
Thomas Lund Posted August 22, 2017 Author Share Posted August 22, 2017 Thanks guys - will try that Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 22, 2017 Share Posted August 22, 2017 Dan's actually just written my eBook on rescribing for me. Kev MikeC, Rick Griewski, Uncarina and 5 others 8 Link to comment Share on other sites More sharing options...
ROM Posted August 22, 2017 Share Posted August 22, 2017 hi, I would recommend to mix a drop of cyano with talc. Il will speed up the cure time. genreally, the mix is dried within minutes. But maybe it is to hard then to rescribe in it. Woody V 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted August 22, 2017 Share Posted August 22, 2017 I don't scribe incorrect lines so I don't know. Just kidding. Enough said, super glue. Sincerely, Mark Shawn M 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 22, 2017 Share Posted August 22, 2017 Rather than talc, I am using micro glass balls with CA glue when the line to fill is quite large/deep. Link to comment Share on other sites More sharing options...
Durangokid Posted August 22, 2017 Share Posted August 22, 2017 I really like using black super glue. It dries quickly and it can handle being rescribed. I like the black variety because I had problems seeing if my lines were filled. I always use accelerator since it keeps the SG from shrinking and it actually doesn't dry as hard. Hope this helps... Bryan Shaka HI, Uilleann, Uncarina and 3 others 6 Link to comment Share on other sites More sharing options...
Shawn M Posted August 22, 2017 Share Posted August 22, 2017 I've never seen black super glue! Who makes it? Big Texan and Shaka HI 2 Link to comment Share on other sites More sharing options...
Shaka HI Posted August 23, 2017 Share Posted August 23, 2017 Ya..that's new to me too...black super glue? Link to comment Share on other sites More sharing options...
justjim1 Posted August 23, 2017 Share Posted August 23, 2017 wow black super glue really shows up well .who makes and supplies ? Link to comment Share on other sites More sharing options...
Guest Maxim Posted August 27, 2017 Share Posted August 27, 2017 I add black ink to me super glue to turn it black. A cheaper option. Link to comment Share on other sites More sharing options...
