AlexM Posted July 1, 2017 Share Posted July 1, 2017 Dear modellers, since the Hampden is sloooowly seeing the still distant finish line, I thought it's time to show what I've been working on in the mean-time: The (in my eyes) finest looking WW2 floatplane, the Fiat RS.14. I began working on the 3d-model about two years ago, and now started printing some major parts after I bought my own 3d-printer. I'm still playing around with various materials and printing-settings. Some parts shown here were printed in a very rough resolution for test-purpose, and will probably be replaced later with finer parts. The engines and propellers in the 3d-pictures are not from me but came from a free model of the Fiat Cr.42. So here we go: Cheers Alex Alburymodeler, 109, kkarlsen and 11 others 14 Link to comment Share on other sites More sharing options...
AlexM Posted July 1, 2017 Author Share Posted July 1, 2017 My first first clumsy attempts in vacu forming: TorbenD, Iain, Zero77 and 9 others 12 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 1, 2017 Share Posted July 1, 2017 Wow! Alex, this is pure awesomeness! Have you considered turning this into a kit? It certainly looks good enough! Kev sandokan, spacewolf, dutik and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted July 1, 2017 Share Posted July 1, 2017 I agree !!.....Harv Link to comment Share on other sites More sharing options...
ssculptor Posted July 1, 2017 Share Posted July 1, 2017 AGREED!!!I] I'd buy one. Stephen AlexM 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted July 1, 2017 Share Posted July 1, 2017 Phenomenal! Link to comment Share on other sites More sharing options...
Troy Molitor Posted July 1, 2017 Share Posted July 1, 2017 Super cool efforts here Alex. I love this one. Troy AlexM 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted July 1, 2017 Share Posted July 1, 2017 Beauty! Being a former seaplane Captn. I love it!! Cheers Alan AlexM 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted July 1, 2017 Share Posted July 1, 2017 Fantastic, Alex ! Hubert AlexM 1 Link to comment Share on other sites More sharing options...
TorbenD Posted July 1, 2017 Share Posted July 1, 2017 Hats off to you sir! Torben AlexM 1 Link to comment Share on other sites More sharing options...
RBrown Posted July 1, 2017 Share Posted July 1, 2017 Absolutely marvelous! AlexM 1 Link to comment Share on other sites More sharing options...
Gazzas Posted July 1, 2017 Share Posted July 1, 2017 Wow! Gonna love watching this! AlexM 1 Link to comment Share on other sites More sharing options...
AlexM Posted July 2, 2017 Author Share Posted July 2, 2017 (edited) Thanks guys! I'm curious myself how this will turn out at the end Wow! Alex, this is pure awesomeness! Have you considered turning this into a kit? It certainly looks good enough! Kev Haha Kevin, that would be a challenge. But never say never Unfortunately the technology (at least of my printer) isn't ready yet that one pushes the print button and gets a perfect clean part. I'm playing around with different materials, and it seems they all have their pros and cons. Here are some examples of the floats. The one in the background was one of my very first prints, printed with a material called PLA in silver-grey color and very rough resolution (0,2 mm), where even after some sanding the layers are still very visible. The next one was printed with grey PLA in a higher resolution (I think 0,1 mm). After some sanding, it looks OK but I guess that after some painting, the layers would be still visible, requiering more sanding. PLA seems to be one of the most common materials for that kind of printers. It prints reliable, sticks good on the printing plate, and tends just little to warp when cooling down. If you have luck there is no warping visible at all. But PLA has also a rather low melting point, which makes sandig tricky. And once cold, it is very hard and difficuld for scribing on the surface. The halve float on the foreground was printed with a material called ABS. The edges turned out pretty sharp, an it "feels" similar to our well-known polystyrene. It can be easily sanded, and should be good for scribing. With the right glue, it can be "welded" like normal kit parts. But it has a higher tendency to shrink when cooling down, what can tourn out into warped parts, expecially at the lower area. It ist difficult to peruade ABS to stick on the printing plate. And finally, there appeared lots of stress cracking all way up during the print, probably due to shrinking. I filled those cracks with putty, but this float is not usable for a model. I also tried a material from another manufacturer called smartABS, which has a lesser tendency to shrink/warp. It's definitly better, but cracks can still occur. Finally, the full float on the foreground was printed with a white material called HIPS, what stands for High Impact Polystyrene, indicating that it is the same/similar material like normal kits. The edges turned out less sharp compared to ABS. It is even harder to persuade to stick on the printing plate, and there can also be some warping on the lower area. But on the float, no stress cracking appeared. It is rather soft, and good to sand. Scribing should be no problem. After some sanding, the surface felt pretty smooth. But after a coat of grey Mr. Surfacer, it turend out that there was more cleaning up necessary. At the edge between the lower and upper part of the float, I glued some Evergreen stripes to achive a sharp edge. So for the moment, whenever possible, I would use HIPS or smartABS for modelling. Cheers Alex Edited July 2, 2017 by AlexM Hubert Boillot, AceofClubs, Zero77 and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 2, 2017 Share Posted July 2, 2017 I think for the purposes of developing a kit, I would use the printed parts as the basis for masters for resin casting. That way, you can just use whatever material either shrinks the least or cleans up the best, and take care of scribing and other details once the parts are in resin. Just an idea! Kev sandokan and AlexM 2 Link to comment Share on other sites More sharing options...
DeanKB Posted July 2, 2017 Share Posted July 2, 2017 Wow. Link to comment Share on other sites More sharing options...
