Warbird Posted February 6, 2018 Share Posted February 6, 2018 Hi Guys, I started to build the Trumpeter ME-262 a few months ago but I have lacked time to open a WIP thread sooner. I'll then begin at the painting phase. Overall, the Trumpeter kit is rather nice although it suffers from a few inaccuracies, nothing that can be quite easily corrected though. The most challenging (annoying) drawback being that the engine nacelles, gun cowlings and forward fuselage need some serious work to have them perfectly aligned, and that it meant hours spent in rescribing and re-riveting. Otherwise, the slats deserve some corrections if positioned extended, which is always the case when on the ground. I intend to represent a well known KG.51 machine, 9k+FH. Marking will be made using my Silhouette cutter. Any insight on the colors used ont this airplane is welcomed. I'm hesitating between a 81/82 base with 02 or 76 (gray green) spots. Or a 81 only base. Spots might be a light green too. Here is where I stand. You can see signs of struggle on the area mentionned above. Cheers KiwiZac, Victor K2, Gazzas and 4 others 7 Link to comment Share on other sites More sharing options...
TimHepplestone Posted February 6, 2018 Share Posted February 6, 2018 Nice one!. Have the kit in my stash so will be watching with interest. Didn't know KG 51 flew th ME 262. Did a JU-88 a few years ago in1/48 with the Eidelwiess nose art. Was this a fighter bomber version? Link to comment Share on other sites More sharing options...
Victor K2 Posted February 6, 2018 Share Posted February 6, 2018 Hi Warbird, I wish you had started this build from the beginning, so that we mere mortals could have seen you address and correct the problems that have mentioned. I have one of these kits on my "to do" pile (which is getting bigger all the time). I look forward to seeing more of this build and will be following this thread to help to promote my model to the front of the pile. Bob. Link to comment Share on other sites More sharing options...
Thunnus Posted February 6, 2018 Share Posted February 6, 2018 I'm also building this kit but a few steps behind you. I'm just starting to get a handle on the fit issues that you mention. I'm buttoning down all of the panels on my build too and I hope that I can do as good a job as you've done. Link to comment Share on other sites More sharing options...
VintageEagle Posted February 10, 2018 Share Posted February 10, 2018 Great subject! Note that this aircraft had a wooden rudder that had a slightly different shape vs. the standard one (lower edge). Cheers, Roger Link to comment Share on other sites More sharing options...
Gazzas Posted February 11, 2018 Share Posted February 11, 2018 Some very nice looking work on the nacelles and nose. Nice looking rivet lines, esp! Gaz Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 11, 2018 Share Posted February 11, 2018 Looks great! Every thread on this model I see, Im more and more glad I have the Shatton full resin nose for the 1a/U4 conversion to take care of the afor mentioned problem areas. Looking forward to more progress! Link to comment Share on other sites More sharing options...
Piprm Posted February 11, 2018 Share Posted February 11, 2018 (edited) Amended : RLM 81 Brown fuselage /82 Dark green ) - with 83 light green spots ... (look at the GI's Khaki pants for comparison) also red/brown nose cone with light grey putty lines (vertical pair) ... there also seems to be 76 light blue/grey overspray rear of aircraft towards and under stabilisers... almost starting from rear of cockpit ( scribble pattern and some spots too) - dark brown rudder with light green overspray - heavier green overspray more prominent starboard side of rudder. white tips etc. Pip Edited February 18, 2018 by Piprm Link to comment Share on other sites More sharing options...
alaninaustria Posted February 11, 2018 Share Posted February 11, 2018 Looks great so far! Nice to see another ‘262 entering the fray... Cheers Alan Link to comment Share on other sites More sharing options...
Warbird Posted February 24, 2018 Author Share Posted February 24, 2018 Thanks for your comments! I found some time to apply a coat of grey primer (mostly straight from the can), I then had to make corrections here and there, and then a solid coat of AS-12.The slats have been modified and will be glued later on to avoid breaking them. Regarding the camo colors, I'm leaning toward an overall RLM81 upper surface with RLM 76 (probably blue green variation) spots. The pictures below show that the spots color is closed to the underside color and that the base color looks pretty uniform in terms of shade. RLM 76 underside except for wings,left bare metal (this is a guess as I couldn't find a picture of this area). MikeMaben, Whitey, Gazzas and 2 others 5 Link to comment Share on other sites More sharing options...
Warbird Posted February 28, 2018 Author Share Posted February 28, 2018 After the overall coat of AS-12, the forward section was painted in Alclad steel, simply because this section was indeed made of steel. Also, some underside panels have been painted with Alclad dark aluminium. I have now started to roughly apply dark grey over panel lines and rivets, following the pattern seen on the Me-262 111711. A lighter grey will be used over the steel section. fab, Dany Boy, KiwiZac and 11 others 14 Link to comment Share on other sites More sharing options...
Shawn M Posted February 28, 2018 Share Posted February 28, 2018 man that looks great Link to comment Share on other sites More sharing options...
VintageEagle Posted February 28, 2018 Share Posted February 28, 2018 Looks fantastic! What tool did you use for the rivets? Link to comment Share on other sites More sharing options...
monthebiff Posted February 28, 2018 Share Posted February 28, 2018 Very nice work, super smooth paint wotk! Regards. Andy Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 1, 2018 Share Posted March 1, 2018 Love that! Kev Link to comment Share on other sites More sharing options...
