red Dog Posted July 18, 2023 Author Share Posted July 18, 2023 Painting the inside of the canopy was a success thanks to @Isar 30/07 who pointed this topic for help: And following exactly Rick's advice it went without a hitch. So many thanks both of you. I decided to go for Tamiya X-24 with a few drop of X-19 to darken it a bit. One side painted one side left untouched Happy with the result - less is more so I stopped before it was too tinted. Dandiego, LSP_Kevin, scvrobeson and 10 others 13 Link to comment Share on other sites More sharing options...
scvrobeson Posted July 18, 2023 Share Posted July 18, 2023 Tinted canopy looks great. Definitely nerve-wracking to airbrush the canopy glass I'm sure Matt red Dog 1 Link to comment Share on other sites More sharing options...
Jim Barry Posted July 18, 2023 Share Posted July 18, 2023 Looking good! red Dog 1 Link to comment Share on other sites More sharing options...
red Dog Posted August 6, 2023 Author Share Posted August 6, 2023 After two weeks of holidays away from the bench, I'm back working on this hog of a kit. First a better picture to assess the tinting of the windscreen sides: The right part is the original untinted A-10 canopy I will use as test for the next step. I designed some head tracker reflector for the canopy. As always I made some sizing test before printing on decal paper: Just a bit too small, so I increased size by 10% and printed on laser decal paper. Then a quick and thin coat of X-22 and once dry I applied one of the three to the original A-10 canopy. I won't place it in the right spot because of that ugly seam line. it's just a test and I want to see clearly the whole area The idea here is to see how much of the carrier film remains visible on the transparency and also assess if the decal solution I use will not alter the transparent plastic (you can't be too careful with transparent parts) I also made such tests on the sprue of the vac canopy just to be sure Close-up and you see the carrier - that's after one drop of decal solution. I'm always a bit concerned with the edges of the carrier film, that's where it's the most visible and sometimes it has a tendency to lift and curl which is really awful. From a bit further away, it's barely visible. It's the best compromise I could come up with. I'll give it a night before repeating the process on the vac canopy. Don't hesitate to share your comments or let me know if you guys think of a better way to do this. Thanks Landrotten Highlander, Isar 30/07, Rainer Hoffmann and 6 others 9 Link to comment Share on other sites More sharing options...
A-10LOADER Posted August 6, 2023 Share Posted August 6, 2023 Would applying the dot decal with a drop of future make the carrier film less noticeable ?? Steve red Dog 1 Link to comment Share on other sites More sharing options...
red Dog Posted August 7, 2023 Author Share Posted August 7, 2023 great suggestion Steve, thanks I tried with the Future (Klear) that we have available here in Europe. that's the milky one, not the transparent one and here's the result: Same result IMHO Dany Boy, JayW, Derek B and 3 others 6 Link to comment Share on other sites More sharing options...
A-10LOADER Posted August 7, 2023 Share Posted August 7, 2023 This maybe as good as it gets unless you try what Pete suggested ? Steve Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
red Dog Posted August 7, 2023 Author Share Posted August 7, 2023 I can't believe I missed Pete's post. Sorry P Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
red Dog Posted August 8, 2023 Author Share Posted August 8, 2023 On 7/13/2023 at 10:43 PM, Pete Fleischmann said: I think if I were going to replicate the constellation of helmet trackers (dots)- I’d create a template of the dot pattern, temporarily tape it to the outside of the canopy, and from the inside, tap a tiny dot of JB WELD (applied with a fine strip of wire held in a pin vice) at the dot locations. I do rivets like this all the time. JB WELD dries to a very dark grey. It domes beautifully; and after you practice for a bit, you’ll make consistent sized dots. No decal film to deal with either P Sounds like a great way for me to screw that canopy Something I am good at But let's give it a try and abuse that trumpeter transparency first I am not familiar with JB WELD. is that the 2 component thingy: easixpedro, Pete Fleischmann, Derek B and 1 other 4 Link to comment Share on other sites More sharing options...
easixpedro Posted August 8, 2023 Share Posted August 8, 2023 3 hours ago, red Dog said: I am not familiar with JB WELD. is that the 2 component thingy: Bingo. red Dog, Derek B and Pete Fleischmann 2 1 Link to comment Share on other sites More sharing options...
red Dog Posted August 8, 2023 Author Share Posted August 8, 2023 ordered. Will try Pete's suggetsion over the weekend Thanks all A-10LOADER, Pete Fleischmann and Derek B 3 Link to comment Share on other sites More sharing options...
A-10LOADER Posted August 8, 2023 Share Posted August 8, 2023 I use this stuff all the time for gluing my resin parts to the models. Do some "testing" so you get a feel for how it works. Mix small batches at a time and try to keep your mixing ratios as close to 1:1 as possible otherwise it will harden too fast ( too much hardener ) or, it will take forever to harden ( not enough hardener ). Keep track of your time while mixing as well, when properly mixed it should start to set up in about 5 to 8 minutes, after that it's too hard to work with especially for what your trying to accomplish. Steve Youngtiger1 and Pete Fleischmann 2 Link to comment Share on other sites More sharing options...
red Dog Posted August 8, 2023 Author Share Posted August 8, 2023 thanks. Sounds like milliput Link to comment Share on other sites More sharing options...
red Dog Posted August 17, 2023 Author Share Posted August 17, 2023 While I practice the delicate JBWeld operation, I further converted the pilot and IP. The oxygen mask had to be cut from the original left hand and the insides were hollowed to allow the mask to fit the pilot face. The oxygen hose was also remade. Maps and datacards were glued on the two big kneeboards and the flight stick was glued in his right hand. The flight stick base is glued in the cockpit floor and these two will match as the pilot seat slides into the pit Also noticeable is the right eye lens necessary to convert the helmet to scorpion. On top of the helmet, the sensor for head tracker was added as well as the big cable running from inside the visor to the side panels. Here's a unforgiving closeup of the pilot's helmet converted to Scorpion. I usually print my own flight suit patches and HUD decals as unfortunately very few decal sheets provide these important details. I know most combat missions are done without them but call that artistic licence as I prefer my pilots to wear these. I usually design these by scaling down the aircrfat decals I design. Small detail that I actually never see on commercial decals are the mirrored US flaf to allow wearing it on the right arm. I heard the stars have always to point forward The super thick Trumpeter HUD glass was replaced with a thin sheet of acetate on which the HUD decal was applied The top plate HUD is missing and was added with a small plastic plate. I kinda hesitated to make the special glareshield pouch the A-10 pilots all have and place in front of them. All pieces together in the pit. I just need to add the scratched DTU box and repair the two seat rails that I broke previously. Michael931080, themongoose, geedubelyer and 14 others 15 2 Link to comment Share on other sites More sharing options...
geedubelyer Posted August 17, 2023 Share Posted August 17, 2023 Superb modifications. The addition of the right eye sight glass is very convincing. Great stuff A-10LOADER and red Dog 1 1 Link to comment Share on other sites More sharing options...
