MDuv Posted August 7, 2021 Share Posted August 7, 2021 (edited) Hi! My Focke build is a bit stalled atm and I am not in the mood for small finishing steps. Having worked on this big beast On and Off for some time, I think it's time for a WIP topic to get the things really started. The present conversion work is very inspired by Peter's (EasixPedro) own master piece. I am just happy to follow his footsteps, and sometimes adapt the techniques used to my taste. I'll be starting from the C boxing, but have a J at hand if necessary. I would like to depict a strapped to catapult bird, ready for the big acceleration, but I still need to figure out the strap configuration. The subject : Early F-4B from VF-84 during the 1965 cruise on the Independance. The parts I already gathered : AMS Mk5 seats & thin wheels. J cockpit, to be adapted to earlier standard And Aires short Exhausts, gotta check the diameter thing. As a motivational work, the tail was done and almost finished earlier : The markings And voila : Edited August 7, 2021 by MDuv Fanes, themongoose, Starfighter and 25 others 28 Link to comment Share on other sites More sharing options...
MDuv Posted August 7, 2021 Author Share Posted August 7, 2021 (edited) Following closely with the thinning of the wing : As a starter, the yellow tape was used to delimit the surface to work on. It was removed, scanned and imported in the silhouette software to draw a first mask (the upper one) it was then cut on oramask (the middle one) and applied on the surface to check its fit Then panel lines were drawn with a cd pencil on the mask while on the wing. The drawn mask was then put alongside the others on the paper and scanned. Panel lines were added accordingly using the scan on the cut file. Once everything was fine, thin plastic card was then cut: To be in line with the wing plastic thickness (1mm) another sheet of 0.5 was cut as well, this time without the surface detail. Then the cirurgy on the wing may begin, I just removed material under the mask, if everything was done right, the new part should slot in with minimal adjustment. Point of no return reached.. The new parts are then attached after adding plastic strips to support from under: The Panel lines seems to line up, wich makes me very happy :-) Still a lot of work, but a bit closer now. Ah yes, and I have to other wing to do.. Cheers. Mathieu Edited August 7, 2021 by MDuv vvwse4, Derek B, blackbetty and 24 others 27 Link to comment Share on other sites More sharing options...
chrish Posted August 7, 2021 Share Posted August 7, 2021 Wow…just…wow Anthony in NZ, Starfighter Jock and MDuv 2 1 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted August 7, 2021 Share Posted August 7, 2021 Whoa! Why didn’t I think of that?? MDuv, Anthony in NZ and Scotsman 2 1 Link to comment Share on other sites More sharing options...
easixpedro Posted August 7, 2021 Share Posted August 7, 2021 Whoa, that's amazing! Wonderful work and makes mine look rather hamfisted. Great use of technology to make the process smooth and foolproof too-I love it! Looking forward to more! Peter Derek B, Anthony in NZ and MDuv 2 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted August 7, 2021 Share Posted August 7, 2021 Impressive start, very nice work on the tail. Anthony in NZ and MDuv 1 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 7, 2021 Share Posted August 7, 2021 Oh wow, another cool Phantom build! Wonderful start and super clean work. This will be amazing! Looking forward to following this as well Cheers Anthony MDuv and Derek B 1 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted August 8, 2021 Share Posted August 8, 2021 Derek B and MDuv 1 1 Link to comment Share on other sites More sharing options...
aircommando130 Posted August 8, 2021 Share Posted August 8, 2021 More Phantom awesomeness! Cheers...Ron MDuv 1 Link to comment Share on other sites More sharing options...
James Rademaker Posted August 8, 2021 Share Posted August 8, 2021 Very impressive, can’t wait to see more of your work. Jim MDuv 1 Link to comment Share on other sites More sharing options...
J.J. Posted August 8, 2021 Share Posted August 8, 2021 Great job! Did you draw the tail fin markings yourself, or did you trace it in the Silhouette programme? I am about to make my own masks for a VF-84, but in 1/48th scale. Jens MDuv 1 Link to comment Share on other sites More sharing options...
MDuv Posted August 26, 2021 Author Share Posted August 26, 2021 Hi Guys ! Thank to all of you for your positive vibes. @easixpedro, haha, i'm the hamfisted one when it comes to cut and form plastic by hand. i better relay on technology for sure :-D @Anthony in NZ, thank you, i may not be commenting on your post, wich would be only amazed repeating of already said things. But i'm following it closely and very fan of what you are doing. Keep it up. @J.J. I did trace it with a silouhette. Just got my hands on the tamiya 1/48. wich i'll build in flight in the same scheme. Shoot a pm, i can send you the File. Cheers Mathieu easixpedro, Derek B, J.J. and 1 other 4 Link to comment Share on other sites More sharing options...
MDuv Posted August 26, 2021 Author Share Posted August 26, 2021 Some limited news from the front: I've been busy mating the two flat surface togheter: Surfacer, sanding, check, surfacer, sanding, .... -Repeat. Nothing really entertaining, but necessary. Here is an intermediate state of things. wich finally led here; I also correted the panel line layout. wich was inccorect in my first attempt. On the cockpit side, I started studiying the parts I have at hand: Tamiya C cockpit, Aires J cockpit, C Eduard PE, Aires Mk7 Seats, AMS Mk5 Seats. RIO Front and left panels will need modding, right panel is kinda ok. Pilot office looks almost identical to the C version. AMS seats are great but less defined than the aires MK7, so i'll try to backdate the aires seat to mk5 standard with the AMS as reference. Phamily pic : take a seat please. First cut on the resin, I removed the centered throttle in the RIO Office, just behind the scope, will relocate it in front of the harmrest Laslty a pic of the subject in all her glory : Cheers. Mathieu alain11, Starfighter, Sepp and 19 others 22 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted August 26, 2021 Share Posted August 26, 2021 Mathieu that is beautiful and clean work, I love what you are doing here! Your attention to detail is very precise, clean and detailed, please keep it up, you are inspiring me! I am glad you are looking at my Phantom build, I hope you find it interesting, but your standards are high and you set the bar higher for me! Cheers Anthony Derek B, MDuv and easixpedro 2 1 Link to comment Share on other sites More sharing options...
easixpedro Posted August 26, 2021 Share Posted August 26, 2021 1 hour ago, Anthony in NZ said: Mathieu that is beautiful and clean work, I love what you are doing here! Your attention to detail is very precise, clean and detailed, please keep it up, you are inspiring me! I am glad you are looking at my Phantom build, I hope you find it interesting, but your standards are high and you set the bar higher for me! Cheers Anthony You're not kidding! My build is looking downright childish compared to that lovely work. I've been staring at his panel lines for a few minutes now and want to go back and fix mine (too bad they're covered in decals now). MDuv 1 Link to comment Share on other sites More sharing options...
