alain11 Posted November 26, 2020 Posted November 26, 2020 hi gents yes , indeed , keep your used ( or new ) toothpicks . Here is a simple , and efficient way to paint jet exhaust nozzle ..........a good idea I picked up on the French Forum "master 194" a good idea must be shared Alain thank you Mr Gruson Kagemusha, Shawn M, Landrotten Highlander and 21 others 19 5
jenshb Posted November 26, 2020 Posted November 26, 2020 How do you stick the toothpicks to the petals? Rockie Yarwood, A-10LOADER and Out2gtcha 3
Out2gtcha Posted November 26, 2020 Posted November 26, 2020 2 hours ago, jenshb said: How do you stick the toothpicks to the petals? Was going to ask the same.......and what to use to remove whatever is used to stick them on? Rockie Yarwood 1
alain11 Posted November 26, 2020 Author Posted November 26, 2020 the guy uses " white glue" I don't know if that means something to you , but it's easy to remove the glue residues , a little bit like the maskol Rockie Yarwood, Greg W and Out2gtcha 3
Out2gtcha Posted November 27, 2020 Posted November 27, 2020 2 hours ago, alain11 said: the guy uses " white glue" I don't know if that means something to you , but it's easy to remove the glue residues , a little bit like the maskol I was thinking a bit of Mr Maskol might do the trick Greg W 1
alain11 Posted November 27, 2020 Author Posted November 27, 2020 12 hours ago, Out2gtcha said: I was thinking a bit of Mr Maskol might do the trick I think so !! , charge to you , to us to improve the tip Out2gtcha and Rockie Yarwood 2
thierry laurent Posted November 27, 2020 Posted November 27, 2020 White glue in France is actually wood/vynil glue. Out2gtcha, Rockie Yarwood and alain11 2 1
LSP_Matt Posted November 29, 2020 Posted November 29, 2020 On 11/28/2020 at 12:25 AM, thierry laurent said: White glue in France is actually wood/vynil glue. PVA Polyvinyl Acetate D Bellis 1
James Rademaker Posted November 29, 2020 Posted November 29, 2020 Brilliant idea. Jim Rockie Yarwood 1
alain11 Posted November 29, 2020 Author Posted November 29, 2020 thank you Maru but this is not my own idea , I only share it , all the better if that can help , or inspire people Alain Greg W, Uncarina, Rockie Yarwood and 1 other 4
Greg W Posted December 10, 2020 Posted December 10, 2020 Thank you Alain for posting this technique. I wanted to try it right away when I read about it but I thought that there must be a better way to attach the toothpicks than by white glue. After scratching my head for a bit, I ended up using stiff wire to make clips that grip over the lip of the AB. They just clamp on and stay put if the tension is correct. The resin can is from the Eduard Brassin 1:48 F-4E exhaust set, which I am using on a Hasegawa eggplane. Late tomorrow I will post pics of the painted exhausts on my thread in the Non LSP Works part of the forum. Greg alain11, Uncarina, LSP_Kevin and 1 other 3 1
