rammstein Posted August 8, 2019 Posted August 8, 2019 hello all, In march I started on a Landing ship medium in scale 1/35. dimensions of a LSM lenght 203'6'' or 62,027 metres, the beam is 24'6'' or 10,515 metres. In scale 1/35 this will be 1m 772 x 30cm. These photo's are of the vehicle deck. vehicle deck and the lower part of the LSM next are some photo's of the bridge, with the different platforms and the windows drilled, I used a drainpipe for this I also placed a WT door I placed the walls of vehicle deck with water tight doors and ladder rungs next photo's are of how it all looks like , looks more and more of a LSM, work under vehicle deck is done enjoy, rammstein blackbetty, Shawn M, Giangio and 15 others 18
Shawn M Posted August 8, 2019 Posted August 8, 2019 happy to see another of your builds, this is looking great! Martinnfb 1
rammstein Posted August 9, 2019 Author Posted August 9, 2019 hello all, work started on the frames under vehicle deck, most of them are recktangle of shape, with curved frames towards stem and stern. all the frames glued in place work until now a close up of the ladder rungs one of the water tight door on vehicle deck while everything is drying I started on the stern with anchor support enjoy, Rammstein D.B. Andrus, GMK, John1 and 16 others 19
Out2gtcha Posted August 9, 2019 Posted August 9, 2019 Wow, some seriously nice work going onto a HUGE model here. Martinnfb 1
Sabre F-86 Posted August 9, 2019 Posted August 9, 2019 That is looking very cool. I have a set of plans for the German MarineFahrePram (MFP) which was the German version of a tank landing craft. One day (after I kiss this job goodbye) I want to scale them up to 1/35th and build one. It's basically a big box with a ramp on one end, it doesn't even have any curves to speak of. Martinnfb 1
rammstein Posted August 10, 2019 Author Posted August 10, 2019 hello all, Some more work done with fairlead placed next I started on the bow ramp enjoy, Rammstein Daniel460, Derek B, daveculp and 9 others 12
rammstein Posted August 10, 2019 Author Posted August 10, 2019 hello all, holes drilled in the lower part of the bow ramp support beams placed short support beams placed tubings on hull placed and bow made enjoy, Rammstein blackbetty, Derek B, Martinnfb and 6 others 9
Wegener Posted August 10, 2019 Posted August 10, 2019 Looks brilliant, although it must be tedious cutting all those parts. Very clean too - no evident filler applications! Hopefully not material but those imperial/metric conversions look a bit off to me - 24’6” is surely more like 7-8m than 10m, given that a metre is roughly 39” (3ft 3in)? Martinnfb 1
Fvdm Posted August 11, 2019 Posted August 11, 2019 That's looking great. You're gonna need a lot of plastic for this. I'm just gonna sit back and follow this interesting build. Martinnfb 1
rammstein Posted August 11, 2019 Author Posted August 11, 2019 hello all, Wegener you have a point there , beam is 34'6'', or 10,51 metres. the ramp dry fitted onto the model starting to make the bow construction vent, water tight door and ladders placed the anti skid strips placed on the bow of vehicle deck enjoy, Rammstein Uilleann, Iain, Derek B and 8 others 11
wunwinglow Posted August 11, 2019 Posted August 11, 2019 What a terrific project! Iain and Martinnfb 2
rammstein Posted August 11, 2019 Author Posted August 11, 2019 hello all at first I placed some ovals on vehicle deck, had no idea what they where, after seeing some photo reference, I made these manholes. at first I had to drill 10 oval holes all over vehicle deck, 3 in front, 4 at the middle and 3 at the end of vehicle deck I only made one manhole, casted all the others then it was time to do some more work on the bow, the under side of the structure the structure in place enjoy, Rammstein blackbetty, Derek B, D.B. Andrus and 7 others 10
Out2gtcha Posted August 11, 2019 Posted August 11, 2019 Great stuff, that really is going to be something special when done! Out of curiosity, where do you put finished projects of this size? Martinnfb 1
Martinnfb Posted August 11, 2019 Posted August 11, 2019 Absolutely incredible work. Thank you for sharing. Cheers Martin
