hello all,
dodgem37: lenght will be +- 1m77
thierry laurent: thanks for the info BTR-50 and T-55 Tirans wow, but I will keep it in WW2 time frame.
Started on the 25 men balsa life rafts.
styreen is evergreen n° 199 ; 6,3 x 6,3 mm
the build is straight forward, not difficult to do, just styreen and etch, cutting and sanding
the making of the wooden floor, I make it once, cast then 2 times. Tape 11 strips of 2mm width
remove second, forth, sixth  etc strip and tape it
glue a strip over these strips, make sure everything is square
repeat this 14 times
just cut out and sand
just to fill in some voids, and sand it
it will look like this, a lot of detailing to do, all the etch which is visible through the squares must be removed
enjoy,
Rammstein
hello all,
just made another 20mm ammo box, wasn't satisfied with the first one.I show you step by step. 1: sides and front/back
2: top and bottom twice
3: the section between the box and hood, 3 different thickness of sheet plastic
this the result
4: making of the hood
end result
2019-09-21%2009.13.55.jpg?t=1568968926
now I can make a mould and cast some more, lot of detailling to do too.
enjoy,
Rammstein
hello all,
the 20mm ammo lockers have been cast, now it is time to extra detail the locker., making of the locking screws.2019-09-24%2013.08.32.jpg
twist some wire around a drill, bent some wire in u_ shape, drill holes and glue2019-09-24%2013.09.04.jpg
cut to lenght, glue a disk onto the wire, and glue a ring on top of this, repeat it 10 times and one ammo locker is finished, still 3 lockers to go
also some work done on the forward 40mm bofors tub, and MK 51 director tub.
enjoy,
Rammstein
42 minutes ago, Shawn M said:
pics arent loading, look like attachments instead of links
Weird, they aren't loading for me either......and normally I can see them when away from my work picture hosting blocking
3 hours ago, rammstein said:
hello all,
Does anyone have an idea why can not post photo's?
rammstein
might reduce the size a bit of the pictures.  and then reload? I think your on god level here this is shaping up in to an epic buid...keep m coming I damn fine work so far
Cheers
Frederick Jacobs
4 hours ago, rammstein said:
hello all,
rammstein
I'm seeing all your photos just fine. But I think Frederick might have a point: they are very large (around 4MB each), so perhaps reducing them in size to about 1024px wide or so before uploading them might help (keep the original full-size images however).
Kev
For whatever reason, I see the photos with Mozilla Firefox (though loading very slowly), but not at all with Google Chrome :hmmm:
Stunning project, by the way!
Alex
