hello all,
Now it is time to bring on the hull plating,round tubing are glued in place, then , I cut out 2 large pieces of sheet styrene, resembling the hull sides, and glue them into place
the bow is curved towards the front and towards the bottem, to achive this I cut gently every mm, in doing this the styrene starts to curve
that something went wrong is also Obvious in the above photo, but this will be corrected in no time. The port side with its anchor shell
Letting it all dry overnight , starting on the bulkheads. Each bulkhead has over 500 rivets, my punch and die has done some overtime
2019-05-10%2015.44.27.jpg?t=1565532631
enjoy,
Rammstein
Great stuff!  I really like how this is coming together.   Are you going to end up displaying any 1/35th tanks or vehicles on it when completed?
hello Out2gtcha,
I still don't know what I am going to do with it, first I wanted some LVT's in it but they weren't used for LVT, LVT came allmost allways out LST, same for DUKW's, maybe artillery 105's and GMC's, or something else every suggestion is welkom.
Rammstein
Sir, your skills with styrene are surpassed only by your ability to see how to use and form it into what ever you need.
This is going to be a fantastic model! :bow:
Barry
Edited by Barry
spelling
hello all,
Blackcollar, reference are plans by floating drydock, and photo's by navy source
LSP-kevin styrene sheet arefrom Vink NV in Belgium, bought via a friend/modelstore
Thanks Barry
Gewehr 43 every great things begin small.
some more photo's of the bullwark, the inside of the bullwark
Also the complete forward structure of the bow is made, bullwark dry fit in place
the hull bottom is put in place
work on the upper part of the bow ramp, holes drilled and anti skid strips placed
enjoy
Rammstein
Hello all,
Now that the underside aft is made, it is time to make propellers, and rudders
propeller supports in place
then it was time to instal the rudders, I only made one I casted the other
the Original one and the 2 resin rudders
both rudders in place
enjoy
Rammstein
hello all,
some more work on the bridge and on overlapping the spaces on vehicle deck
one more photo of ruddes and props
lower part of the bow made and bow ramp placed
bow ramp seen from vehicle deck
so far the easy part has been done , now it is fitting out time, some 20mm dry fitted
bulwarks in place
enjoy,
Rammstein
