Out2gtcha Posted August 14, 2019 Share Posted August 14, 2019 Wow, this is so, SO good! Im not even a ship guy, but I can recognize excellent work when I see it. Really looking forward to the next installment! rammstein and Uilleann 1 1 Link to comment Share on other sites More sharing options...
rammstein Posted August 15, 2019 Author Share Posted August 15, 2019 hello all, as said above fitting out time,I made one 10'' bollard, and casted them 10'' 10'' bollards finished in place some hatches, same procedure make 1 cast the others in place some more work done on the bridge, the door has fallen of enjoy, Rammstein Derek B, Lothar, F-4Phanwell and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 15, 2019 Share Posted August 15, 2019 Really great work..............so interesting to see it all come together. rammstein 1 Link to comment Share on other sites More sharing options...
Shawn M Posted August 15, 2019 Share Posted August 15, 2019 agreed Brian, this is a great project Out2gtcha and rammstein 1 1 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted August 15, 2019 Share Posted August 15, 2019 This a great build. your 20 mm master come from the Elco pt boat sets? At one time I wanted to build the LST that they used for Viet Nam for the Sea Wolves helo pads. Link to comment Share on other sites More sharing options...
rammstein Posted August 16, 2019 Author Share Posted August 16, 2019 hello all, Vandy : the 20mm is from PT conversion kit by Italeri. next up date is regarding vents, there are 3 different types, this the largest one the other is a little lower I made one then casted the rest this is the smallest one placed on the bow structure enjoy, Rammstein Derek B, Uilleann, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
Juggernut Posted August 16, 2019 Share Posted August 16, 2019 (edited) Very nice! I wish I had those plastic forming skills. I just butcher the plastic to some shape that "resembles" what I need and go with that.... Now if I were able to do what you do, I'd be much better off. Care to share how you design, cut and manufacture such things like the hatches, vents, and the loading/unloading ramp? I'm quite sure there are a lot of us who'd benefit from such a tutorial (for lack of a better word). Edited August 16, 2019 by Juggernut rammstein and D.B. Andrus 1 1 Link to comment Share on other sites More sharing options...
rammstein Posted August 17, 2019 Author Share Posted August 17, 2019 hello all, Juggernut I will post how I made it, hopefully you will benefit from it. I do not have any photo reference how I made the vegitable locker, but I do have photo's regarding build main mast. into place on vehicle deck main mast dry fitted with radar on top, radar is by Italeri from the PT conversion set I made the yardarm , main mast in the back, with a working platform in between the eyes in the yardarm are made with a drill, insert a thin wire and than drill thickness of the drill is 0.9mm, this will be also the diametre of the eye, cut to lenght and glue. The making of the platform is straight forward, draw 2 circles on a piece of sheet, cut out and sand, drill a hole for the mast, a piece of strip is glued in the center resembling a support and a piece of sheet is glued on the side. the platform is glued in place, then the yardarm, this is how it looks regards, Rammstein Derek B, Vandy 1 VX 4, Shawn M and 5 others 8 Link to comment Share on other sites More sharing options...
rammstein Posted August 18, 2019 Author Share Posted August 18, 2019 hello all, made an other platform this time for the warninglights, just under the radardome the disks to make the warninglights, thickness 0,5 mm radius 2x5mm, 6x4mm, 1x3mm, 1x1mm, 2 of the 4mm are glued onto each other this is the end result making of the watertight doors, cut 2 sheets of plastic 0,5mm in thickness, 40mm x 20mm and 38mm x 18mm, draw some round cornersin the corners roughly cut of the corners and sand , one side sanded first glue the smaller one, on top of that glue the larger door, it will gave the impression the door is off the wall, a piece of strip is rounded , this will be the hinges the base for the hinges will be glued upright, 4 spreus are cut, these will come against the base 4 small dots are made by punch and die set , these will represent the hinge shaft the small dots glued onto the hinge door handle and gutter is cut from L-sprue door grip is made, a piece of fine sprue which is bent to shape the result with flagbag above it, the flagbag is made a few days ago last photo is this piece on the LSM enjoy, Rammstein LSP_Kevin, D.B. Andrus, F-4Phanwell and 7 others 10 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 18, 2019 Share Posted August 18, 2019 Amazing work! Kev Vandy 1 VX 4, rammstein and Out2gtcha 2 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 18, 2019 Share Posted August 18, 2019 For sure, this is so cool to watch come together rammstein 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted August 18, 2019 Share Posted August 18, 2019 Much better than going to the movies! Outstanding work!! Cheers, D.B. rammstein 1 Link to comment Share on other sites More sharing options...
Shawn M Posted August 19, 2019 Share Posted August 19, 2019 love all the little details rammstein 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted August 19, 2019 Share Posted August 19, 2019 Fantastic work! I like those specialized ships, very purpose looking! Alain Link to comment Share on other sites More sharing options...
stusbke Posted August 20, 2019 Share Posted August 20, 2019 Wow just found this thread I like it a lot....quite the daring project but you seem to be on the right track here...looking forward to your next updates is there any chance we'll be seeing this at the KMK show or any show for that matter this yer in Belgium? Cheers Frederick Jacobs Link to comment Share on other sites More sharing options...
