A-10LOADER Posted February 8, 2020 Share Posted February 8, 2020 Great work so far Marcel, she looks really good !! Steve "TOMCATS FOREVER, BABY...!" Marcel111 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 8, 2020 Share Posted February 8, 2020 Exceptional work, Marcel! Kev Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted February 18, 2020 Author Share Posted February 18, 2020 (edited) I have used the Mig Ammo walkway paste for the first time. Must say I am really impressed, it's very easy to use and the results are more realistic than what I could achieve with the textured paint method I was previously using. One minor watch-out is not to layer it on too thickly around the masking tape, else you'll get an uneven tear when removing the tape. Cheers, Marcel Edited February 18, 2020 by Marcel111 Out2gtcha, chuck540z3, A-10LOADER and 9 others 12 Link to comment Share on other sites More sharing options...
chuck540z3 Posted February 18, 2020 Share Posted February 18, 2020 Looking great Marcel! Those walkways are nice and crisp. As for your wing glove problems, I have felt this pain before, hence a new rule: If it takes clamps with any kind of meaningful pressure to get the parts to fuse together, don’t do it! The join always seems to separate later, especially after painting. Cheers, Chuck Marcel111 and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 18, 2020 Share Posted February 18, 2020 WOW, excellent work! Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted February 19, 2020 Author Share Posted February 19, 2020 20 hours ago, chuck540z3 said: Looking great Marcel! Those walkways are nice and crisp. As for your wing glove problems, I have felt this pain before, hence a new rule: If it takes clamps with any kind of meaningful pressure to get the parts to fuse together, don’t do it! The join always seems to separate later, especially after painting. Cheers, Chuck Yes, and you would think I would have learned my lesson from when the whole assembly came apart on me after I clamped everything together. In this case I felt like I had no other choice though. Oh well, the underside of this model will never be the greatest, I am focusing on getting the parts right that will be visible as the model stands. Link to comment Share on other sites More sharing options...
Marcel111 Posted February 19, 2020 Author Share Posted February 19, 2020 (edited) Took some quick IPhone pics of the model before I headed into the mountains. The skunk stripe is on, which is actually very dark blue with a slightly lighter blue border... on the pics it looks about black, as does the real thing. This is how those vents turned out. I used the Scale Navy Stuff parts, which fit perfectly. However, those tore off of the nose section at some point and from there on in it was a huge amount of filling and sanding to get everything together again. I chose to use Archer rivets as fasteners because I did not want to risk pressing rivets into the brittle superglue/filler composite. Not entire accurate since those fasteners are actually flush but I will live with it. Also note GPS receiver. Snapshot of the front section, you can see the skunk stripe blues a little better here. Notice the formation light stips, which I have airbrushed on. I had not noticed that the front one is solid while the rear one is cut into two halves, looks like I will need to correct this... which I am really not keen on doing since with this build it seems every step forward results in half a step back. Cheers, Marcel Edited February 19, 2020 by Marcel111 LSP_Kevin, USMC Herc, A-10LOADER and 5 others 8 Link to comment Share on other sites More sharing options...
Brett M Posted February 19, 2020 Share Posted February 19, 2020 1 hour ago, Marcel111 said: Took some quick IPhone pics of the model before I headed into the mountains. The skunk stripe is on, which is actually very dark blue with a slightly lighter blue border... on the pics it looks about black, as does the real thing. This is how those vents turned out. I used the Scale Navy Stuff parts, which fit perfectly. However, those tore off of the nose section at some point and from there on in it was a huge amount of filling and sanding to get everything together again. I chose to use Archer rivets as fasteners because I did not want to risk pressing rivets into the brittle superglue/filler composite. Not entire accurate since those fasteners are actually flush but I will live with it. Also note GPS receiver. Snapshot of the front section, you can see the skunk stripe blues a little better here. Notice the formation light stips, which I have airbrushed on. I had not noticed that the front one is solid while the rear one is cut into two halves, looks like I will need to correct this... which I am really not keen on doing since with this build it seems every step forward results in half a step back. Cheers, Marcel Beautiful work Marcel! Quick Google search on the slime lights, it doesn't appear that all D's had a solid front light? Or, is that image you posted your exact jet you're building? If so, disregard.... Marcel111 1 Link to comment Share on other sites More sharing options...
CZPetrP Posted February 19, 2020 Share Posted February 19, 2020 Good Job, Marcel. How the air intakes from Zactomodels came close to you? Thank You. Petr Marcel111 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted February 19, 2020 Author Share Posted February 19, 2020 Brett, thanks for your comment... The initial pics I came up with all had the solid front slime light, but I have now found even pics of D's with the front light also split. So I will keep as is. I have no pics of 200 where I can as retain this for sure. Thx Petr... not sure I understand your question... Cheers, Marcel Brett M 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted February 20, 2020 Share Posted February 20, 2020 19 hours ago, Marcel111 said: Notice the formation light stips, which I have airbrushed on. I had not noticed that the front one is solid while the rear one is cut into two halves, looks like I will need to correct this... which I am really not keen on doing since with this build it seems every step forward results in half a step back. Cheers, Marcel I bet if you you hunt around, you can find a pic of the front light being split. Formation lights are notorious for being all over the map for both color and configuration. I’d leave that nice looking light alone. Also, in the small chance you weren’t doing this already, make sure you paint that tiny notch at the bottom front of the titanium gun shield gray. 90% of the Tomcat builds I’ve seen miss this small, but characteristic detail. Cheers, Chuck A-10LOADER and Marcel111 2 Link to comment Share on other sites More sharing options...
easixpedro Posted February 20, 2020 Share Posted February 20, 2020 I won’t go so far as to call the slime lights consumables, but they’re parts that can go bad, and are removed and replaced quite frequently. Depending on what’s in the supply stock and what lot from what manufacturer, and you get what you get. I’d go with it, and not worry about it. -Peter Marcel111 and USMC Herc 2 Link to comment Share on other sites More sharing options...
Marcel111 Posted March 28, 2020 Author Share Posted March 28, 2020 (edited) Here are some some overall shots of where I am now. Still have many little flaws to fix and details to add, so the close-ups will come later. I used Vallejo acrylic metal paints for the first time, on the leading edge. Love the result, I won't be using the toxic smelling alternatives much anymore. I really need to coat the leading edge with flat, but it's so nice to see something shiny on this Cat that I am having a hard time dulling down that metal finish. Love the Fightertown decals. For the carbon fiber shrouds, I used a mix of gunmetal and gloss black (one of the rare instances where I still use enamels, in this case Modelmaster). After the first coat I added more gloss black to the mix and sprayed through a screen placed on the surface of the model to give a very subtle hashed look. So subtle you hardly see it here, but then again it's pretty subtle on the real thing. The AAQ-25 is sourced from the Academy F-16 kit. The Trumpeter pod looks really wrong since the leading edge of the intake is curved in side-on perspective, it should be completely straight. Here is my pod, complete with paint stripping off the front, as often seen on the real thing: Cheers, Marcel Edited March 28, 2020 by Marcel111 allthumbs, LSP_Kevin, F`s are my favs and 9 others 12 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 28, 2020 Share Posted March 28, 2020 (edited) You're making great progress on your big cat Marcel and she looks superb. If I were to send you a large box of bits, would you finish mine off for me please? This is a treat to see, keep it up Edited March 28, 2020 by geedubelyer Correcting autocorrect! stusbke, Kagemusha, Marcel111 and 1 other 1 3 Link to comment Share on other sites More sharing options...
scott_t Posted March 28, 2020 Share Posted March 28, 2020 Really looks terrific Marcel !!!!! Thanks for pointing out where you sourced the vents from. Just went and ordered two sets for a couple of big cat builds I am collecting stuff for. Scott Marcel111 1 Link to comment Share on other sites More sharing options...
