HK models with Fisher Meteor F-8 conversion set.
The rockets are also from Fisher models and some additions from Eduard sets.
The assembly of the fuselage with the new nose requires a lot of care and also we must add a lot of ballast to obtain a correct ground position.
Painted with the MR paint IDF range.
Thank you friends for your comments.
Also, i have the T7 two-seater version which will have to be all aluminum but the lack of references of the cockpit makes that it is on standby.
And then, I have a lot of projects running, which is why I did not publish in "In the work" because I was not sure of finishing it.
Having already three current topic in this category, Stearman, Ra am & Peten.
Babs.
