The mr Hobby airbrush looks nice. I needed a bigger airbrush when painting a uss nimitz 1:350 and i decided to buy a 0.6mm needle for my H&S. But a special airbrush for large surfaces is real handy.
  • 1 month later...
16 hours ago, MGySgt0372 said:
I want to see more, Durangokid! You do some awesome work & i'm about to start my Tamiya F-4J. Thanks!
Semper Fi,
Masterguns
Thanks brother!  I was waiting for the new decals from AOA and they should be here any time.  Then I'll be starting back up...
Semper Fi!
  • 5 months later...
So I'm finally back to work on my Phantom.  The kit decals were trashed as were the Yellow Hammer decals I had.  The kit decals completely yellowed but I was able to bleach them out for the most part by setting them in direct sunlight for a few days.  I tested a decal only to have it break apart in water so I sprayed some testers decal bonder which helped but wasn't perfect.  They Yellow Hammer decals were even worse and they weren't all that accurate to boot.  My only other option was to use my trusty Silhouette to cut some masks.  Thankfully AOA has a new set of stencils so I'm all set.  I drew all the markings, including the walkways, with Inkscape.  It took some time but was worth it in the end.
First I painted the white areas:
pmhb7NFFj
Then masks for the green strips and clovers:  Note: I must have broke that damn probe five time now!
pmN7d2Xyj
Painted custom green color:
plipgcZtj
Masked the stripes:
plhuOKRsj
Painted the main color:  I used Mr. Color but for this but it seems too light.
pnemYzrrj
Removed masks...OOPS!
pndy8hUoj
pnoYUshqj
Added tail markings
plktvRM2j
pmNtqpK0j
The walkways were next.  The black outline was a PIA!
poi5iIApj
I painted and masked the grey areas:
poaLSGvfj
I also drew the stars and bars from scratch.  These took some work but I figured it would be easier to do these before painting the main color.  I first painted the blue areas.
pmqRrWF6j
Then applied the masks for the white and red areas:
pmSCs81Xj
poz66yHTj
Here she is after painting and removing masks:
pmK2qT9Tj
Still a few more to go.
plSdT3Xmj
You can see just how detailed the Silhouette can cut once you have all the settings dialed in:
popVFIehj
Here she is with all the markings, not on decal used...
pmYWjQTyj
plXWlCSzj
plizEFGqj
Time for some blending and a bit more weathering... Thanks for looking!
Bryan
