Durangokid Posted January 21, 2019 Author Posted January 21, 2019 I'm slowly plugging along. I've been working on the wing fold which has been a bit more work than I thought it would. I've got everything else fixed so this is one of the last few things I have to complete before I head to the paint barn. I've got one wing done and not being a big scratch builder, it took some time to get it looking half way decent. I can already tell the wing join is going to be a bit fragile. I made a wing fold brace based on some photos I've seen which will have the added advantage of strengthening it a bit...hopefully. All this turned out to be more work than just redoing the extended wings. Broken wing parts: Hopefully this will look better under a coat of paint! Working on the locking mechanism: I'm going to wait until the end of the build before I attach these, it will be easier to paint not to mention I will surely break them off if I don't Here is the exhaust joint I had to fix. It looks terrible but it should only need a few touch ups after I hit it with primer I've been adding a few more small details like the framing on the inside of the flap areas. Most of this won't be very visible but I like the way it brings out the details. I probably won't have too many more to add until I primer everything and make the inevitable touch ups. Thanks for looking in! Bryan Marcel111, mark31, Starfighter and 9 others 12
Anthony in NZ Posted January 21, 2019 Posted January 21, 2019 Awesome save and probably a nicer end result will happen.....beautiful! Durangokid 1
Durangokid Posted January 25, 2019 Author Posted January 25, 2019 It's a bit cold here in Colorado and it's hard for me to run my exterior fan for my paint booth but I managed to get some primer down in a few areas. I use Alclad's primers mixed with a bit of leveling thinner. I love this stuff as it dries solid and sands perfectly. You get that nice feathered edge and the leveling thinner makes it go down smooth as butter. I was able to get the front canopy on with only a minimal gap that I was able to fill with a small amount of surfacer. I used a small, pointed Q-tip dipped in leveling thinner to clean the excess off. I tried to be very careful so the thinner didn't mess up the clear part since it's possible to seep under the tape. I'm fairly happy with the way the exhaust area came out but there are still a few adjustments to make. It's not perfect but the gap around the exhaust cans isn't nearly as big as before. I've heard the Sierra Hotel exhaust is the right size so I highly recommend those to anyone considering building this kit. My way works but it's a serious pain in the butt. If I had to do it all over again, I would have spent the extra money. Even though I already bought the Aires exhaust years ago, it would have been worth it to buy the SH exhaust. Plus I recently discovered that one of the burner cans is a bit warped. I'm really happy with they way the little exhaust vents came out. I wasn't going to attempt to fix them but it kept bothering me especially considering I'm fixing less obvious issues with the kit. I just wasn't sure how to do it but I looked up Chuck's phantom build and could see how he fixed his. I couldn't get the soda can aluminum to work for me so I uses thin styrene sheet. It was actually a lot easier than I thought it would be. The only thing I would do different is removing the louvers in the vent and replacing them. I would have done that but I already glued the fuselage together making it difficult. There is a lot of panel line reworking going on here so I'm glad it came out okay. The front AC intake blended in well too. I'm happy with the way the reworked wing joint came out considering the earlier disaster. I'm so close to paint I can taste it or should I say smell it . Sure glad I have the big Pace Peach Keeper booth! This thing is huge! If there are any Phantom experts looking in, please let me know if there is anything that needs correcting. I think I've got the obvious stuff fixed but I can only figure out so much looking at photos. I have Gorman's great phantom book but I wish I had Jake's book too. Thanks for looking in fellas and your comments good or bad are always welcome... Bryan MikeMaben, Greg W, HerculesPA_2 and 15 others 18
Dragon Posted January 25, 2019 Posted January 25, 2019 Great work! Looking forward to seeing some paint on your build. I hindsight I wish I would have gotten the Peace Keeper instead of the Super-Mini booth. Definitely more room for LSPs. Mike Anthony in NZ and Durangokid 1 1
Out2gtcha Posted January 25, 2019 Posted January 25, 2019 Excellent work! Looking forward to seeing it in paint Anthony in NZ and Durangokid 1 1
Marcel111 Posted January 25, 2019 Posted January 25, 2019 Awesome modelling... and at high speed too! Marcel Durangokid and Anthony in NZ 1 1
chuck540z3 Posted January 26, 2019 Posted January 26, 2019 Great job and I like how you sweat the tiny details that others would just skip over. Cheers, Chuck Durangokid, Anthony in NZ, Panzerwomble and 1 other 3 1
MikeMaben Posted January 26, 2019 Posted January 26, 2019 21 hours ago, Durangokid said: I'm so close to paint I can taste it or should I say smell it . Sure glad I have the big Pace Peach Keeper booth! Smells like peaches ??? Coming together nicely Bryan Durangokid 1
Durangokid Posted January 26, 2019 Author Posted January 26, 2019 1 hour ago, chuck540z3 said: Great job and I like how you sweat the tiny details that others would just skip over. Cheers, Chuck Yea, I have been stealing some of your ideas from your phantom build.
Durangokid Posted January 31, 2019 Author Posted January 31, 2019 I've got the black primer down and I'm ready for some black basing action. You can see the Alclad primer mixed with leveling thinner goes down nice and smooth. I use a very thin coat so I don't fill the small details and just enough for the black basing. I rarely have lifting issues using Mr. Color and MRP paints and using the Alclad brings it down to zero. I've got a start on some of the weapons. I have Two Bob's decals for the Aim-9's and the Aim-7's which look really nice. However, I was glutting for punishment so I decided to paint the stripes on. I painted the stripe colors and masked them with various widths of tape before painting them white. It turned out fairly well but I'm not sure I like the way the front section of the Aim-9's turned out. I still have to paint the seeker heads and the rear fin metal parts before I apply the decals. The Aim-9's are from Zacto and are fantastic. The small parts can be a bit fiddly but that goes with the fine details. I think they are a must as I haven't found any that are correct or are as detailed. The sparrows are from the kit and are pretty good. I bought Two Bob's decals since the kit markings are lacking. Here is what I have so far. I also worked on the wheels. I have they Brassin wheels that are very nice but they are smaller than the kit wheels and I have no idea which are correct. I also have the wheels that came with the Rhino intakes and they appear to be a copy of the kit wheels. I'm going to paint both for comparison but looking at photos, the Rhino/kit wheels look closer to the real thing. However, the tire part of the wheel is significantly more detailed with the Brassin. The Brassin wheels had a defect but it was fairly easy to correct. Here are the Brassin wheels painted up, just need some weathering. I really appreciate all the nice comments fellas, it keeps a guy motivated. Lenny320, Starfighter, Trak-Tor and 13 others 16
Squizzy 78 Posted January 31, 2019 Posted January 31, 2019 Amazing work on your phantom, I'm really looking forward to seeing it come together! Durangokid 1
Anthony in NZ Posted January 31, 2019 Posted January 31, 2019 That black base looks awesome. Unbelievably smooth as are your missiles Nice work, loving it! Durangokid 1
Lenny320 Posted February 1, 2019 Posted February 1, 2019 Beautiful work Bryan. This is giving me motivation to restart my D model. Durangokid 1
mark31 Posted February 1, 2019 Posted February 1, 2019 very nice work you show here keep it going Mark Durangokid 1
Durangokid Posted February 1, 2019 Author Posted February 1, 2019 Thanks fellas, I really appreciate all the nice comments. I wanted to mention what airbrush I use to primer or gloss coat a big model. I use the GSI Mr. Hobby PS-290 and I absolutely love it. I use a Harder & Steenbeck Infinity for most of my detail work which I really like but it's not good for laying down a lot of paint. It was difficult to lay down a good gloss coat without getting edge dryness because it's such a small line to work with. Not to mention it took forever to paint the large subjects we all enjoy. I wanted to get the Iwata HP-TH but didn't want to spend the $300 US dollars to buy it. I ran across some reviews raving about the PS-290 and that it was virtually the same as the HP-TH without the MAC valve. They sure look the same anyway. I was able to buy mine a few years ago for $130 US dollars. I couldn't be happier with my purchase! I don't have the largest modeling budget anymore so finding something that works well on a reasonable price is important to me. It comes with two tips, one a standard round and the other a fan tip. I use the fan tip and as you can see from the phantom photo, it lays down the paint like butter. No more streaks or dry edges and I can paint an entire 32nd scale phantom in minutes. The only issue one might have is that it takes significantly more air pressure to spray then a detail brush. I have a Super Silent 20A which isn't recommended but I've had zero problems getting enough air for modeling purposes. However, I'm not sure a tankless compressor would keep up so keep that in mind if you consider this airbrush. I hope this is helpful to others that are looking for a solution to better coverage when it comes to this type of airbrushing. P.S. It really came in handy when semi-glossing this beast! Fvdm, F`s are my favs, blackbetty and 8 others 11
