Nick Manzara Posted September 11, 2019 Share Posted September 11, 2019 Sweeeeeet!!!!!!!! Phantom Durangokid 1 Link to comment Share on other sites More sharing options...
Brett M Posted September 11, 2019 Share Posted September 11, 2019 Very nice job on your paintwork and "metal". Definitely selling me on moving away from decals with how smoothly your masks worked! Link to comment Share on other sites More sharing options...
Marcel111 Posted September 12, 2019 Share Posted September 12, 2019 Bryan, I think the metal areas look very realistic, nicely done! Marcel A-10LOADER 1 Link to comment Share on other sites More sharing options...
JAWS Posted September 12, 2019 Share Posted September 12, 2019 This the best paintwork ever! I commend you on painting all the markings! Durangokid 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted September 13, 2019 Share Posted September 13, 2019 Great job on the exhaust area Bryan! If I might offer a subsequent tip, use some Tamiya pastels in "Oil Stain" and "Soot" to dirty up the titanium panels, to give them a real exhaust residue look. Cheers, Chuck Durangokid 1 Link to comment Share on other sites More sharing options...
Durangokid Posted September 20, 2019 Author Share Posted September 20, 2019 So after hearing Chuck and a lot of other modelers talking about Tamiya's X-22 gloss if figured I would give it a try and it's fantastic. I think it's the best I have tried for sure. I used Mr. Color leveling thinner to thin it and I think getting the 50/50 mix correct is important. I thinned it a bit much when painting the bottom which didn't turn out as glossy as the top. I ended up respraying the bottom with the correct mix and all was well. I also have the F-4 stencils from both AOA Decals and Cam. AOA's decals are by far the most detailed set I have seen on any aircraft. In fact, it's daunting with the amount of stencil required for F-4J. The F-4 had several different ejection seat triangles stencils and the Cam set had the ones that were on my aircraft. I used those and the 'danger' part of the intake decal. It took me a week working a few hours at a time to get this thing stenciled up. My only complaint, and it's a minor one, is that every single stencil marking is a separate decal. There are as much as 7 separate stencil decals on one square inch of the model which added to the time consuming process. Time consuming or not, these are just amazing and a must have if you are doing a F-4B or J. Thanks for making these AOA! I only have a few old photos of the aircraft I'm building and some of them show a fairly weathered bird. I think because this was on a ship really dirtied it up a bit more than what I saw with other Vietnam era F-4's. Because of that, I'm assuming a lot of the stencils were wore down although it seemed they were still visible on a lot of weathered aircraft. I decided I would use all the stencils provided but sanded them down to give it the worn look. It tool a lot of time to do since you have to go slow and use a soft grit sandpaper so as not to rip them down completely. I think it came out ok for the most part. I think this angle give you an idea of how smooth and glossy the X-22 is. Some wing stencils before sanding. P.S. You will notice that there is a crack where the intake meets the airframe . Apparently I didn't get enough superglue there so I had to fix that. Always gotta be something! After sanding, what do you guys think? The kit decals were terrible, it was like trying to decal with wax paper they were so thick and would't go down. Even after spraying them with decal sealer they still broke apart a bit. The canopy decals for the names were even worse. Luckily I was able to save it since this was all I had. Sorry for the crappy photos guys and I totally forgot to take pics of the bottom. My good camera is down and this thing is so big it's hard to photograph. I forgot to mention that I painted the intake leading edges aluminum. The instructions say red but it looked like metal to me in the limited photos I have, most of which are black and white. I could be totally wrong on this one. Some of you with a keen eye would notice I changed the tail number from 01 to 02. I was originally going to build 01 but I got confused when I drew the masks and it was a lot easier to change the tail number rather than repaint all the others. Brandon Wood actually caught that little detail! The original 01 aircraft was shot down by a sam missile after it shot down two enemy migs. The pilots had borrowed aircraft 01 so the kill markings were applied to their aircraft 02. Does anyone know if the kill markings were applied while they were deployed or when they returned stateside? Seems I remember reading they were applied while deployed but I can't find the source again. Thanks for stopping by fellas... Bryan Trak-Tor, easixpedro, scvrobeson and 16 others 19 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 20, 2019 Share Posted September 20, 2019 Looks fantastic, Bryan! X-22 sure is the bee’s knees. And I’m happy to say I put Chuck on to it! Kev Out2gtcha, Durangokid and chuck540z3 1 2 Link to comment Share on other sites More sharing options...
chuck540z3 Posted September 20, 2019 Share Posted September 20, 2019 Really nice decal work Bryan and like all decal sessions, issues always come up! Looks like you are winning though, so keep it up. 54 minutes ago, LSP_Kevin said: Looks fantastic, Bryan! X-22 sure is the bee’s knees. And I’m happy to say I put Chuck on to it! Kev And that you most certainly did Kevin and I thank you! No more Future/Pledge for this guy, even if it does work pretty well. Cheers, Chuck Out2gtcha, LSP_Kevin and Durangokid 2 1 Link to comment Share on other sites More sharing options...
Durangokid Posted September 20, 2019 Author Share Posted September 20, 2019 1 hour ago, LSP_Kevin said: Looks fantastic, Bryan! X-22 sure is the bee’s knees. And I’m happy to say I put Chuck on to it! Kev Good stuff Kev, I'm really glad you passed that one around. I had been using MRP clear gloss with pretty good results but it seemed to take a lot of coats to get really glossy. X-22 didn't take nearly as much and it is incredibly glossy. I did end up sealing the decals with MRP semigloss and there were no issues with the hotter paint on top of it. I would have used X-22 to seal them but I like to use semigloss for the oil weathering plus I'm running a bit low on the X-22. Funny thing is, I've had that X-22 sealed in the bottle for over 10 years and it was still like new. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
Lothar Posted September 20, 2019 Share Posted September 20, 2019 Stunning progress, she's gonna be THE show attraction once finished Lothar Link to comment Share on other sites More sharing options...
Fvdm Posted September 20, 2019 Share Posted September 20, 2019 That looks amazing! Durangokid 1 Link to comment Share on other sites More sharing options...
Gazzas Posted September 20, 2019 Share Posted September 20, 2019 Wonderful! Durangokid and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 20, 2019 Share Posted September 20, 2019 Wow, that looks terrific! What grit polishing cloth/pad did you use to fade up the stencils? Durangokid 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted September 21, 2019 Share Posted September 21, 2019 On 9/19/2019 at 7:38 PM, Durangokid said: Always gotta be something! Durangokid 1 Link to comment Share on other sites More sharing options...
Durangokid Posted September 21, 2019 Author Share Posted September 21, 2019 On 9/20/2019 at 7:11 AM, Out2gtcha said: Wow, that looks terrific! What grit polishing cloth/pad did you use to fade up the stencils? Hey Brian, I used 6000 grit but it was well used before I sanded the decals. I couldn't sand the yellow decals on the bottom because the ink would spread instead of fade. The good thing is the yellow part of the decals were very fine and not overly bright. USMC Herc and Out2gtcha 1 1 Link to comment Share on other sites More sharing options...
