airscale Posted May 23, 2018 Author Posted May 23, 2018 (edited) Hi folks The postman has just dropped the PE off, so time to take a lookat what we have... ..rear fuselage floor - this is where the fuselage fuel tank sits... ..and it's rigid layer.. the top layer of the IP, and the IP surround layers.. ..the middle layer of the IP - this carries just the bezels.. ..one of the fuselage frames and inside it a number of cockpit switch panels - you can see the layers - a solid back layer onto which a detailed relief layer is added. From these designs the decals for all the labeling is scaled so I know they will fit.. ..same again with another frame.. ..a bunch of fuselage station formers - these need a strip adding to them so they look like a pressing... ..you can see part of the sub-floor here for the main fuselage - the real aircraft has multiple floor panels - this panel is to mount all those sub-panels to, and inside it some more formers - I think this is the spare lamp bulb hatch.. ..some of the individual floor panels - these will be laminated with micro plywood as the real ones were wood construction, but with a metal backing like this I can be sure I get the shape right and all the fixings & screws... ..the throttle quadrant and levers.. ..and the rudder pedals with their embossed logo & text.. Good show, Peter. Did you trace or free-hand? Thank you. Sincerely, Mark Hi Mark - pretty much all of the PE was traced in Coreldraw from manufaturers drawings so they should be bang on for dimensions / proportions. Each of those drawings is dimensioned in inches so I just convert the inches to mm and scale to 1/18 So, with all the first tranche of parts done, I can start to make things now and start to get the internal fuselage structure built out.. TTFN Peter Edited May 23, 2018 by airscale sandokan, KiwiZac, Starfighter and 16 others 19
Guest Peterpools Posted May 23, 2018 Posted May 23, 2018 Peter Hikes - looks incredible Keep ‘em comin Peter
Hacker Posted May 23, 2018 Posted May 23, 2018 Peter not being nosey but what does it cost you for those PE parts? l am thinking rather expensive Hacker
dodgem37 Posted May 23, 2018 Posted May 23, 2018 Nice results. The fuel selector has engraved copy. How is that going to relate with the decals? Not to sound like a hound dog, but the opening is off-center. I don't know if that matters or not. 69 all the time. Heh, heh. That symbol and copy is nice. No anti-skid tracks? Good show, Peter. Sincerely, Mark Hubert Boillot, sandokan, Out2gtcha and 2 others 5
airscale Posted May 23, 2018 Author Posted May 23, 2018 Nice results. The fuel selector has engraved copy. How is that going to relate with the decals? That symbol and copy is nice. No anti-skid tracks? Good show, Peter. Sincerely, Mark thanks for stopping by Mark - there is a blank fuel selector seen below it, so I will either use that and the decal, or the etched one will be sprayed black and hopefully I can scrape off the etched relief to leave the bare metal below (like the real one) and not use the decal - so a couple of options in play ..not sure what you mean by anti skid tracks - the pics I have of the rudder pedals just seem to show them in painted metal so I will have to look a little deeper... I couldn't resist making a quick start on a PE part, so started with a floor panel - this was stuck to some 0.4mm ply I have had since I was a kid, I have no idea where I got it, but it's perfect for this application.. ..I drilled out the holes from the back onto a hard sheet of perspex after covering it in tape to stop the surface splintering and put little lengths of lead wire through the holes... ..note also I haven't cut the final shape until all this was finished so I have a larger, more stable part to work with rather than lots of little edges and cut-outs..... ..the underneath is a mess of CA holding them all.. ..then all the stubs are sanded flush.. ..and on the bottom too... ..and then it's cut to shape from the back, using the PE part as a guide.. ..I will likely varnish it or something so I can wear off the black paint later for scuff marks.. ...will repeat for the other wooden panels.. TTFN Peter sandokan, MikeMaben, NukerDan and 11 others 14
Out2gtcha Posted May 23, 2018 Posted May 23, 2018 This is looking more and more stunning each day! Peter, I think Mark meant the ribbing/rough areas around the NAA logo and heal areas seen on some Mustang pedals Uilleann, sandokan and airscale 3
MikeMaben Posted May 24, 2018 Posted May 24, 2018 (edited) Peter, I think Mark meant the ribbing/rough areas around the NAA logo and heal areas seen on some Mustang pedals Not on Bs ... Edited May 24, 2018 by mmaben sandokan and airscale 2
airscale Posted May 24, 2018 Author Posted May 24, 2018 Help needed folks... does anyone have any detail on the external labelling on a P51? I can see there are many dotted around the airframe, and have asked Aircorps if they have anything showing what they are, but in the meantime is there a P51 resource somewhere that shows them for a 'C'? TIA Peter Uilleann and sandokan 2
Trak-Tor Posted May 24, 2018 Posted May 24, 2018 Great job, Peter! I think I'm jealous, or something like that... Peter, how small is the smallest hole in the PE? Or, how small hole one can get? I guess it's in the instructions you had put the link for before... Don't stop, please! Thanks. Juraj airscale 1
Hacker Posted May 24, 2018 Posted May 24, 2018 (edited) but in the meantime is there a P51 resource somewhere that shows them for a 'C'? http://www.warbirdsresourcegroup.org/URG/p51.htm Here maybe? Hacker Edited May 24, 2018 by Hacker airscale 1
Fencer-1 Posted May 24, 2018 Posted May 24, 2018 Help needed folks... does anyone have any detail on the external labelling on a P51? I can see there are many dotted around the airframe, and have asked Aircorps if they have anything showing what they are, but in the meantime is there a P51 resource somewhere that shows them for a 'C'? TIA Peter Peter, you need document 102-00010 on Aircops library for full P-51B/C markings and labels. Just type the number in the "Search" frame. airscale 1
KUROK Posted May 24, 2018 Posted May 24, 2018 Help needed folks... does anyone have any detail on the external labelling on a P51? I can see there are many dotted around the airframe, and have asked Aircorps if they have anything showing what they are, but in the meantime is there a P51 resource somewhere that shows them for a 'C'? TIA Peter Peter... I think you have a ways to go before you are ready for external stencils, eh? LOL airscale 1
airscale Posted May 24, 2018 Author Posted May 24, 2018 Peter, you need document 102-00010 on Aircops library for full P-51B/C markings and labels. Just type the number in the "Search" frame. Unbelievable! thank you so much, that is EXACTLY what I was after Peter... I think you have a ways to go before you are ready for external stencils, eh? LOL ah yes, but I am doing the decal artwork so I need to get all of it gathered together now so i can get them printed with an airscale stock order that is getting overdue Peter Uilleann and KiwiZac 2
