Shawn M Posted February 22, 2018 Share Posted February 22, 2018 looks great! dmthamade 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 22, 2018 Share Posted February 22, 2018 Very nice and smooth there Don. Great recovery as well. Carl dmthamade and Michael931080 2 Link to comment Share on other sites More sharing options...
gerry1 Posted February 23, 2018 Share Posted February 23, 2018 (edited) Don: I am new to this wip. I too built a P-38 and primered it like you did with gray color. But, I always use dupli-color gray primer from my local auto parts store. You can buy either the heavy fill which covers small defects or thin coat primer. It provides excellent adhesion and doesn't lift probably because of its auto application. Plus it provides an excellent surface for whatever your top coat color is. You might have to wetsand it with 1000 grit sandpaper again sourced from your local auto parts store. Your P-38 looks great and hopefully it won't take you a year like it did for me. Jerry Edited February 23, 2018 by gerry1 dmthamade and Vandy 1 VX 4 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted February 23, 2018 Share Posted February 23, 2018 Does look nice Don dmthamade 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 23, 2018 Share Posted February 23, 2018 dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted February 24, 2018 Author Share Posted February 24, 2018 Thanks for the support, guys!! The Aluminum is so easy to apply and looks great!! Don: I am new to this wip. I too built a P-38 and primered it like you did with gray color. But, I always use dupli-color gray primer from my local auto parts store. You can buy either the heavy fill which covers small defects or thin coat primer. It provides excellent adhesion and doesn't lift probably because of its auto application. Plus it provides an excellent surface for whatever your top coat color is. You might have to wetsand it with 1000 grit sandpaper again sourced from your local auto parts store. Your P-38 looks great and hopefully it won't take you a year like it did for me. Jerry Hello Jerry!! Every time i get car parts i pass by the spray can racks and see all the different primers and colors, always tempted to try them. They also have clear coats that tempt me, too. I've been spending time masking and painting various panels. I'm using Tamiya, Model Master Acryl, Vallejo Model Air and Metal Color. All of them work well, but i have to say i'm really happy with the Metal color stuff!! Looks good, easy and convenient to use, water clean up, super impressed. I was able to mask them off 10 minutes after applying using Tamiya tape, absolutely no stripping of paint!! So, for me, the primer is a non starter, but the Metal Color IMHO is great stuff. Almost time to start on the blue. I've been trying to find a shade of blue to match the decals. Decals give a suggestion of Dope Blue/Light Blue Shade.....great.... Hasegawa released a kit with these markings, all the builds i've seen show a much lighter blue that what the Bombshell decals are. Paint suggestions also found online also look off....nothing easy.....time to try mixing.... Don BradG, johncrow and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 24, 2018 Share Posted February 24, 2018 Good old AS-12 to the rescue! Looks great, Don. Kev dmthamade 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted February 24, 2018 Share Posted February 24, 2018 Yes AS12 is amazing isn't it ? Just like X-22 clear . Keep it coming Hubert dmthamade 1 Link to comment Share on other sites More sharing options...
RLWP Posted February 24, 2018 Share Posted February 24, 2018 Thanks for the support, guys!! The Aluminum is so easy to apply and looks great!! Hello Jerry!! Every time i get car parts i pass by the spray can racks and see all the different primers and colors, always tempted to try them. They also have clear coats that tempt me, too. Do it! I always use a rattle can if I can. You don't have to clean the airbrush afterwards Richard dmthamade 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 24, 2018 Share Posted February 24, 2018 Nice finish. Sincerely, Mark dmthamade 1 Link to comment Share on other sites More sharing options...
1to1scale Posted February 24, 2018 Share Posted February 24, 2018 Looks nice, are you going to spray an accent color or two? dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted February 24, 2018 Author Share Posted February 24, 2018 Thanks for the support, guys!! Happy with the way things are now. I've hit it with 4-5 different shades of aluminum paint, not huge differences between them and my photo skills don't show them that well. After washes and weathering the differences should show more contrast. Did find a blue, looks close to the decals but darker than online builds are. Time to think again.... Don Link to comment Share on other sites More sharing options...
dmthamade Posted February 25, 2018 Author Share Posted February 25, 2018 (edited) Well, been busy painting for the last few hours, did finally settle on a blue. This is MiG Ammo Dark Grey Blue MiG-229. This was a color recommended on another site, looks like a great match. I first sprayed Tamiya flat white XF-2 in the masked areas, then sprayed the blue. The wing tips and wing stripes have white borders that are supplied as decals. I sprayed white for the blue to cover better and be brighter, and to mask a 1.5 outer border then spray the white. Much happier doing it this way rather than rely on decals. Still have to do the prop spinners, oil cooler inlets and tail tips. I'll leave these for tomorrow, just want to take a break. Have to say, the blue and white really make the build come alive. I must have changed a camera setting or something, you can see more variety in the silver shades, now. Don Edited February 25, 2018 by dmthamade Alain Gadbois, johncrow, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
dmthamade Posted February 25, 2018 Author Share Posted February 25, 2018 I was going to take the night off, instead i finished off the blue. Don Vandy 1 VX 4, BloorwestSiR, Tnarg and 7 others 10 Link to comment Share on other sites More sharing options...
Gazzas Posted February 25, 2018 Share Posted February 25, 2018 Excellent masking and painting!! Gaz dmthamade 1 Link to comment Share on other sites More sharing options...
