LSP_Kevin Posted June 27, 2022 Share Posted June 27, 2022 Looks fantastic, John! Kev Pastor John 1 Link to comment Share on other sites More sharing options...
Pastor John Posted June 28, 2022 Author Share Posted June 28, 2022 (edited) AIMS 1/32 Spitfire PR 1G conversion (using Revell Mk II kit) with Barracuda details update. Hi everyone and thanks for following this build. Today I was able to finish the interior work and despite the pain in my hands really enjoyed it.First the dash/firewall was added and this was followed by the rudder pedal assembly. Adding the latter would have been 100% easier if I had not pre-located the framework on the kits floor as I had to twist the pedal assembly this way and that to get it in. With that headache over I was finally able to complete the plumbing of the excellent Barracuda Mk II onwards U/C control - opting to leave the brass wires unpainted. After the rudder pedal control cables were added I could then install the Barracuda control yoke and then the control arm and bracing. Moving backwards so as to leave the pilots seat to last - my AIMS PR conversion 29 gallon tank was popped into place and work started on what remained. The Barracuda seat with kit/scratch built framework had the beautiful Eduard Sutton harness added but I left off the left side lap belt as I planned to drape it over the door. After this my attention turned to the overly thick balsa wood camera box I had made earlier and the camera's were added simply by drilling through the box and into the camera sides and thus allowing me to micro adjust them into the correct place thanks to the flexible but strong brass wire. The camera box and the pilot seat were then added to the model leaving only the oblique mounted F 24/Mk 25 pivot cradle to be re-joined with the pivot arms at the correct angle. Please note that many 14" lens bodies have an angled end but in this case I have not done that. Hope you like and found helpful, John Edited June 28, 2022 by Pastor John thierry laurent, themongoose, chrish and 15 others 18 Link to comment Share on other sites More sharing options...
Rockie Yarwood Posted June 28, 2022 Share Posted June 28, 2022 Lovely! Pastor John 1 Link to comment Share on other sites More sharing options...
Fanes Posted June 28, 2022 Share Posted June 28, 2022 Just wow. Pastor John 1 Link to comment Share on other sites More sharing options...
Steve Eagle Posted June 28, 2022 Share Posted June 28, 2022 Doing wonderful work. Pastor John 1 Link to comment Share on other sites More sharing options...
dennismcc Posted June 28, 2022 Share Posted June 28, 2022 Modelling magic, and it looks great Cheers Dennis Pastor John 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted June 28, 2022 Share Posted June 28, 2022 Brilliant work John. I'm so glad that you're still able to work on a model Matt Pastor John 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 28, 2022 Share Posted June 28, 2022 Terrific work, John! Your modelling even with a handicap is better than mine under any conditions! Kev Pastor John 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted June 28, 2022 Share Posted June 28, 2022 Incredible, your work reminds me about Wolf's Spitfire build, precise and ultra-detailed. Bravo! Martin Pastor John 1 Link to comment Share on other sites More sharing options...
chrish Posted June 29, 2022 Share Posted June 29, 2022 Wowzers! Pastor John 1 Link to comment Share on other sites More sharing options...
Derek B Posted June 29, 2022 Share Posted June 29, 2022 That looks great John. Derek Pastor John 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 29, 2022 Share Posted June 29, 2022 Link to comment Share on other sites More sharing options...
Pastor John Posted June 29, 2022 Author Share Posted June 29, 2022 AIMS 1/32 Spitfire PR 1G conversion (using Revell Mk II kit) with Barracuda details update. Apart from the PR 1G's camera selector control which I had forgotten to add before taking the last photos I was keen to move onto the wings with the Eduard and Barracuda parts. I found that putting a tailor's pin tac into a pin vice was a much better solution than rolling a small ball underneath one of your fingers as per the instructions to make the half-etch appear concave - I know the instructions are only representative haha! Anyway what I did worked a treat and the PE is a very nice solution to the gear bays clearance blister. Although the instructions do not call for any plastic to be removed to fit the box sections in the leg compartments I found I had to remove quite a bit from the side wall as well as the kits ceiling to get a nice fit. With the PE work finished I completely forgot to start drilling and cutting for the Barracuda parts and so went ahead and joined up the wings - no problems though and I was able to do this well enough latter. I have a bit of filling to do now so as to blend in the water cooler base as well as blend the back of the oil cooler as the kit part is designed much too long. Also I drilled out the outboard air ducts a little. Thanks for looking John denders, LSP_Kevin, KiwiZac and 13 others 16 Link to comment Share on other sites More sharing options...
Fanes Posted June 29, 2022 Share Posted June 29, 2022 John, just a heads up: if you intend to mount the landing flaps in the closed position, you will need to remove all the ribs from the upper side. Pastor John 1 Link to comment Share on other sites More sharing options...
Pastor John Posted June 29, 2022 Author Share Posted June 29, 2022 (edited) Yes I saw that with a dry fit yesterday thanks. I got excited about finishing the PE and closed everything up too soon! Lots of work needed still Edited June 29, 2022 by Pastor John monthebiff and Fanes 2 Link to comment Share on other sites More sharing options...
