Pastor John Posted June 4, 2022 Share Posted June 4, 2022 AIMS 1/32 Spitfire PR 1G Although in pain I want to try and do a little modelling each day if I can. Inspired by Andrew Eaton's PR IV and with fond memories of my 1/72 PR 1G from 25 years ago (see photo attached of model only as a reference point) I have set out to make my AIMS 1/32 conversion. I have a host of goodies from Barracuda Studios and other items are on their way to me from Hannants. I have also ordered some 0.2mm solder balls to see if I can locate them along the datum line longeron and a few other noticeable places. I have burred off and filled the absolutely terrible engine cowl clearance blisters and will make my own, and I have started reshaping the wheel blister as well as filling in all the sink holes. So here we go - something British for our Queen's Jubilee! Long live the Queen! LSP_Kevin, Model_Monkey, Hoss FL and 27 others 27 3 Link to comment Share on other sites More sharing options...
monthebiff Posted June 4, 2022 Share Posted June 4, 2022 Good to see you back at the bench John and looking forward to see you work your magic on this one. Regards. Andy Pastor John, BiggTim and mozart 3 Link to comment Share on other sites More sharing options...
mozart Posted June 4, 2022 Share Posted June 4, 2022 (edited) Good on you John…..little and often is the way forward! I’m sure we’re in for a masterpiece. Edited June 4, 2022 by mozart MikeC, Pastor John and BiggTim 3 Link to comment Share on other sites More sharing options...
dennismcc Posted June 4, 2022 Share Posted June 4, 2022 Good to see that you are back at the bench even if it is limited, it would have been a great loss of such talent as yours if you did not use it. Cheers Dennis MikeC, Pastor John, mozart and 1 other 4 Link to comment Share on other sites More sharing options...
scvrobeson Posted June 4, 2022 Share Posted June 4, 2022 Glad to see you persevering and building John. Will be following this one closely. Matt mozart and Pastor John 2 Link to comment Share on other sites More sharing options...
chrish Posted June 4, 2022 Share Posted June 4, 2022 Good to know you’re on the bench! Pastor John 1 Link to comment Share on other sites More sharing options...
Fanes Posted June 5, 2022 Share Posted June 5, 2022 A photo recon Spitfire - count me in! Thrilled to see what you can an will do with all that beatiful resin and your skills, John. MikeC and Pastor John 2 Link to comment Share on other sites More sharing options...
AndrewE Posted June 6, 2022 Share Posted June 6, 2022 Hi John, I am very pleased my build has provided you with some inspiration to start another build despite your current difficulties. I look forward very much to seeing the final build here on the forum and hopefully next year in the flesh! Happy modelling Andrew MikeC and Pastor John 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 7, 2022 Share Posted June 7, 2022 Jolly good ! Just make sure you have fun Pastor John 1 Link to comment Share on other sites More sharing options...
Pastor John Posted June 10, 2022 Author Share Posted June 10, 2022 A little time here and there - fixing the terrible upper cowl, removing and then building back up cockpit details as well as adding the missing top corners - and finally the utter madness of looking into the possibility of using 0.3mm solder balls where the Spitfire frame has the raised rivets. This will be done when the model is almost ready for the painting stage as too many will be lost from handling before that as you can already see. I have also started to thin out the cockpit lower wall sections as they stand too proud for real life otherwise. Never made a 1/48 spitfire before - never mind a 1/32 one so would like to get the details right if I can TAG, MikeMaben, BiggTim and 13 others 16 Link to comment Share on other sites More sharing options...
Fanes Posted June 10, 2022 Share Posted June 10, 2022 Fantastic work on the interior and the engine cowling. Now the solder ball rivets are just insane! Pastor John 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted June 11, 2022 Share Posted June 11, 2022 Not a bad idea re the solder balls. I have some but never thot of using them for rivets. Hopefully they stay where you want them. Pastor John 1 Link to comment Share on other sites More sharing options...
Nighthawk Calling 1 Posted June 11, 2022 Share Posted June 11, 2022 Not finished a Spitfire in a very long time, I did start the Revell kit but it never made it to the finishing line there are bits of it in a box somewhere. I hope the pain subsides for you, good to see you back at the bench creating some art. Going to watch this with interest. Pastor John 1 Link to comment Share on other sites More sharing options...
Hoss FL Posted June 11, 2022 Share Posted June 11, 2022 Cockpit interior looking good so far. Pastor John 1 Link to comment Share on other sites More sharing options...
Pastor John Posted June 12, 2022 Author Share Posted June 12, 2022 AIMS 1/32 Spitfire PR 1G conversion update Hi everyone - done a little more and next up is the plumbing. Note that as a result of Revell's top corners being missing so that their thick canopy can sit in the closed position - they went on to design the pilots bulkhead 1.5mm too far back - i.e - aft of their cut-outs. To fix this I removed 1.5mm from the backs of the lower cockpit side wall parts and increased the hole in the floor 1.5mm further forward. The only other thing to do is then scratch build a new upper rear brace the correct length. I enjoyed the Barracuda parts but so much more needs added. The PR 1G I am making was a Mk I airframe but when it received a Merlin 45 perhaps some of the cockpit parts were upgraded? So I have a mixture really. I scratch built today an early style Regulator as you can still see these on early Mk V's. I am not a Spitfire expert but have enjoyed so far trying to make the Revell kit as good as possible, thanks John Derek B, TAG, Fanes and 14 others 17 Link to comment Share on other sites More sharing options...
